Ianrat
Joined: 31 Mar 2008 Posts: 43 Location: Brisbane AUSTRALIA
vk3eka(at)bigpond.net.au Guest
Posted: Sun Oct 04, 2009 1:49 am Post subject: Weights and Balances |
Ian,
A W&B calculation is a measurement of ratios. The weight of four bananas,
one cucumber length from a pivot will balance eight bananas, one half of a
cucumber length from the pivot (assuming the weight of the bananas and the
lengths of the cucumber are similar).
Just use the same parameters throughout the calculation.
Cheers
Peter
Wonthaggi Australia
http://zodiac.cpc-world.com
jaybannist(at)cs.com Guest
Posted: Sun Oct 04, 2009 5:47 am Post subject: Weights and Balances |
Ian,
Numbers is numbers. I used the same spreadsheet to run W&B in pounds and mm (for me); and in pounds and inches (for the FAA). I don't think your program will know the difference, unless you make an issue of it.
Of course, your numbers will be upside down (;>)
Jay Bannister
| Quote: | --> Zenith601-List message posted by: "Ianrat" <ianrat(at)powerup.com.au (ianrat(at)powerup.com.au)>
I have found a number of programs that will work out the weights and
balances of the 601 XL. But they are all in pounds and mm. Is there any
difference in just using Kilos instead of pounds or is there some other
formula to use. We have submit our findings to the RAA here in OZ in Kilos
and mm
[Question]
Thank you
Ianrat
CH601XL
Australia.
psm(at)att.net Guest
Posted: Sun Oct 04, 2009 6:11 am Post subject: Weights and Balances |
Hi Ian,
I'm not sure the responses to your weight and balance question were
really clear. I agree with all of the ones I've seen, but they don't
tell you what to do.
I believe you can use any set of units for your calculations and you
will still get the correct CG result. The key is to convert ALL
measurements to the same new units. This includes the empty weight
and moment for your plane and the weight and location of all added items.
Good luck,
Paul
XL awaiting engineering changes
At 12:35 AM 10/4/2009, you wrote:
| Quote: | I have found a number of programs that will work out the weights and
any difference in just using Kilos instead of pounds or is there
some other formula to use. We have submit our findings to the RAA
here in OZ in Kilos and mm
bryanmmartin
Posted: Sun Oct 04, 2009 9:31 am Post subject: Weights and Balances |
Like others have said, just plug in kilos and mm into the program and
the result will be in kilos and mm regardless of what the output from
the program says. If you are using an Excel spreadsheet for your
calculations, you can change the text labels from pounds to kilos and
then everything will look right. It won't change the calculations one
bit.
[Question]
Thank you
Ianrat
CH601XL
Australia.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
_________________ --
Bryan Martin
do not archive. |
Ianrat
