		Ianrat
  Joined: 31 Mar 2008 Posts: 43 Location: Brisbane AUSTRALIA
		vk3eka(at)bigpond.net.au Guest
				 Posted: Sun Oct 04, 2009 1:49 am    Post subject: Weights and Balances |
				Ian,
 A W&B calculation is a measurement of ratios. The weight of four bananas,
 one cucumber length from a pivot will balance eight bananas, one half of a
 cucumber length from the pivot (assuming the weight of the bananas and the
 lengths of the cucumber are similar).
 Just use the same parameters throughout the calculation.
 Cheers
 Peter
 Wonthaggi Australia
 http://zodiac.cpc-world.com
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		jaybannist(at)cs.com Guest
				 Posted: Sun Oct 04, 2009 5:47 am    Post subject: Weights and Balances |
				Ian,
  Numbers is numbers.  I used the same spreadsheet to run W&B in pounds and mm (for me); and in pounds and inches (for the FAA). I don't think your program will know the difference, unless you make an issue of it.
  Of course, your numbers will be upside down  (;>)
  Jay Bannister
    	  | Quote: | 	 		  --> Zenith601-List message posted by: "Ianrat" <ianrat(at)powerup.com.au (ianrat(at)powerup.com.au)>
 I have found a number of programs that will work out the weights and
 balances of the 601 XL. But they are all in pounds and mm. Is there any
 difference in just using Kilos instead of pounds or is there some other
 formula to use. We have submit our findings to the RAA here in OZ in Kilos
 and mm
 [Question]
 Thank you
 Ianrat
 CH601XL
 Australia.
		psm(at)att.net Guest
				 Posted: Sun Oct 04, 2009 6:11 am    Post subject: Weights and Balances |
				Hi Ian,
 I'm not sure the responses to your weight and balance question were
 really clear.  I agree with all of the ones I've seen, but they don't
 tell you what to do.
 I believe you can use any set of units for your calculations and you
 will still get the correct CG result.  The key is to convert ALL
 measurements to the same new units.  This includes the empty weight
 and moment for your plane and the weight and location of all added items.
 Good luck,
 Paul
 XL awaiting engineering changes
 At 12:35 AM 10/4/2009, you wrote:
  	  | Quote: | 	 		  I have found a number of programs that will work out the weights and
 any difference in just using Kilos instead of pounds or is there
 some other formula to use. We have submit our findings to the RAA
 here in OZ in Kilos and mm
		bryanmmartin
				 Posted: Sun Oct 04, 2009 9:31 am    Post subject: Weights and Balances |
				Like others have said, just plug in kilos and mm into the program and
 the result will be in kilos and mm regardless of what the output from
 the program says. If you are using an Excel spreadsheet for your
 calculations, you can change the text labels from pounds to kilos and
 then everything will look right. It won't change the calculations one
 bit.
  [Question]
  Thank you
  Ianrat
  CH601XL
  Australia.
 Bryan Martin
 N61BM, CH 601 XL,
 RAM Subaru, Stratus redrive.
  _________________ --
Bryan Martin
do not archive. |
		Ianrat
