Flight Testing Process
Nick Leonard
PostPosted: Tue Oct 13, 2009 1:29 pm    Post subject: Flight Testing Process Reply with quote
Does any have a good flight testing process document that they could share. Ideally, it would go through a stepped (flight-by-flight) process covering all of the items that should/could be checked, verified, calibrated and/or documented in a logical and thorough process.
Thanks in advance,
Nick
Nick Leonard
RV-10 (40015) Flying
kearney
PostPosted: Tue Oct 13, 2009 2:13 pm    Post subject: Flight Testing Process Reply with quote
Nick
I received the ASA Flight Testing Homebuilt Aircraft book by Vaughan Askue
as my Matronics "premium" when I donated a few $$ last year. It looks
thorough enough but I haven't put it to the test yet!
Cheers
Les
#40643
kearney
PostPosted: Tue Oct 13, 2009 2:24 pm    Post subject: Flight Testing Process Reply with quote
Nick
Here is another book you might find useful. http://www.javifix.com/index.php
It is written by a Czech jet pilot I met at Kosh many years ago. He was in
the process of writing it at the time and I was impressed with what I saw.
Jerry (the author) was staying at the same house as me and was a very
engaging person - he had a very interesting story about how he defected to
France before coming to Canada.
Cheers
Les
#40643
coop85(at)verizon.net
PostPosted: Tue Oct 13, 2009 8:33 pm    Post subject: Flight Testing Process Reply with quote
Nick,
Here's a couple things I've sent out before, one from when I was a First
Flight Advisor and another stolen from an RV-6 driver. I recommend you
check with your local EAA chapter to see if they have an advisor as there
might be more current info.
Have fun testing!
Marcus
40286
First_Flight_Script0001.pdf
 Filename:  First_Flight_Script0001.pdf
 Filesize:  624.14 KB
 Downloaded:  398 Time(s)
FLIGHT_TEST_PROGRAM_BP.doc
 Filename:  FLIGHT_TEST_PROGRAM_BP.doc
 Filesize:  54 KB
 Downloaded:  427 Time(s)
tgesele(at)optonline.net
PostPosted: Thu Oct 15, 2009 5:23 am    Post subject: Flight Testing Process Reply with quote
Nick C
6nbsp; Attached is the un-filled out version of the flight test program I 7m using E It 7s based on what others have done and the advice of local builders E I 7ve been doing one test card per flight and limit the testing to 2 per day max E
6nbsp;
6nbsp; Hope this helps E E
6nbsp;
- Tom Gesele N629RV Phase I
N629RV-Flight-Test.doc
 Filename:  N629RV-Flight-Test.doc
 Filesize:  254.5 KB
 Downloaded:  458 Time(s)
