		FlyboyTR
  Joined: 04 Nov 2006 Posts: 215 Location: Mobile, Alabama
				 Posted: Sat Oct 31, 2009 2:34 pm    Post subject: Re: Fuel Flow Problems, Again! (Vixen, Series-5) |
				Lynn,
 I am considering cutting the fitting as you suggested.  However, looking at it, I really don't believe there is a finger strainer there!  I guess I need to check the builders log and see if the rib should be cut down.  The fuel line is about 3/4" higher than the fitting.
 Note...My system is NOT sucking air!  This last problem happened about 35 minutes flight time after both tanks were filled to the brim for a 400 mile flight.  I get air in my filters and they are AIR LOCKING...sort of like a vapor lock.  Don't know where the air comes from!  This problem doesn't happen very ofter...but when it does the fuel stops flowing.  Once I get the fuel to flow again, the air gets pushed out/down and all is well...until the next time it happens.
 Thanks again for the plastic under the fitting trick!
 OH...are there finger strainers still available for purchase?
 Travis
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Travis Rayner
Mobile, AL
Skystar Vixen, N-789DF
Continental IO-240,  Prince P-Tip Prop
ADI-II Autopilot
AnyWhereMap Navigation with weather
www.enotam.net (My Flying Info Website) |
		Fox5flyer Guest
				 Posted: Sat Oct 31, 2009 3:58 pm    Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
				Travis, that thing that looks like a brass bushing in your tank (the thing
 that your 90 degree fitting screws into) is probably your finger strainer.
 Deke
		FlyboyTR
				 Posted: Sat Oct 31, 2009 4:03 pm    Post subject: Re: Fuel Flow Problems, Again! (Vixen, Series-5) |
				Deke,
 If that's the case, then I will be unscrewing it from the tank itself...not another bushing?  Is that right?
Mobile, AL
ADI-II Autopilot
		Fox5flyer Guest
				 Posted: Sat Oct 31, 2009 5:03 pm    Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
				Correct.
 D
		Lynn Matteson
				 Posted: Sat Oct 31, 2009 5:14 pm    Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
				Can you stick a mirror into the tank and see the fitting area? Or is
 there a baffle in the way?
 In the case of my tank(s), that outer brass IS the finger strainer,
 like Deke suggested.
 Lynn Matteson
 Jabiru 2200, #2062, 804.3 hrs
 Countdown to 1000 hrs--196 to go
 Sensenich 62"x46" Wood prop
 Rotec TBI-40 injection
 Status: flying (and learning)
 On Oct 31, 2009, at 8:03 PM, FlyboyTR wrote:
  Deke,
  Travis Rayner
  Mobile, AL
  ADI-II Autopilot
  http://forums.matronics.com/viewtopic.php?p 70285#270285
  _________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
		Lynn Matteson
				 Posted: Sat Oct 31, 2009 5:58 pm    Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
				Sorry, I got the notion that *you* thought it was sucking air after I
 read this:
   " If by chance the system air-locks...at least now I can close the
 vent line and force the system to pull from the tanks, rather than
 sucking air."
 I see a bubble of air in my filters too, and I've seen this in almost
 every glass filter fuel system that I've owned...which is
 several....and in others that I've observed over the years. It never
 seems to bother the fuel flow, it just seems to bother people who
 look at it. Maybe that's why people like the filters that they can't
 see into....you know....out of sight, out of mind. I've seen glass
 filters standing almost straight up, like yours and mine, and I've
 seen them laying on their side, like my third filter which lays
 almost horizontally inside my center console. Seeing this air doesn't
 bother me as gravity keeps the fuel flowing in my system, and fuel is
 heavier than air, and a bubble of air isn't strong enough to keep the
 fuel from falling downhill inside that filter.....IF there is
 sufficient venting above to ALLOW the fuel to fall. If my brand of
 physics is wrong, I'd like to know why I haven't had any fuel-flow-
 related problems in over 800 hours and billions of gallons of
 fuel....oh, wait, that's that guy in Canada that uses all that
 fuel....let's says roughly 3200 gallons of fuel passed through the
 system in that time.
 Lynn Matteson
 On Oct 31, 2009, at 6:34 PM, FlyboyTR wrote:
  Lynn,
  fitting.
  it happens.
  Travis
  Travis Rayner
  Mobile, AL
  ADI-II Autopilot
  http://forums.matronics.com/viewtopic.php?p 70276#270276
N369LM |
		lcfitt(at)sbcglobal.net Guest
				 Posted: Sat Oct 31, 2009 7:10 pm    Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
				The more centric feed location was intended to reduce the tendency to unport
 in long descents.  The T is to direct the fuel line aft to position the fuel
 line for wing folding.
 There was discussion on the list about this issue when this mod came down.
 Some put inspection plates under the fitting.  I can agree that the mod
 helped in one area and hurt in another.  I guess the unintended consequences
 thing.
 :Lowell
		FlyboyTR
				 Posted: Sat Oct 31, 2009 7:58 pm    Post subject: Re: Fuel Flow Problems, Again! (Vixen, Series-5) |
				Lynn,
 This problem happens, usually, when my tanks are more than 1/2 - 3/4 full.  To my knowledge I've never "unported" the tank by descending at such an angle that the fuel moves away from the outlet.
 As so often happens on this forum, someone will reply to a post by starting a new post with the same title (as happened to this thread).  If you haven't read my original post, please take a look.    I tried to explain the details and history of this problem that comes and goes...I would prefer for it to go!
 Once I'm back in the air...should this happen again, I will remove the filter element but keep the glass filter housing in place for observation.
 Travis
Mobile, AL
ADI-II Autopilot
		FlyboyTR
				 Posted: Sat Oct 31, 2009 8:06 pm    Post subject: Re: Fuel Flow Problems, Again! (Vixen, Series-5) |
				Sorry...I missed that...  No, I have baffles in the tank.  Can't see that area of the tank.  ...which I could!
Mobile, AL
ADI-II Autopilot
		Lynn Matteson
				 Posted: Sun Nov 01, 2009 3:36 am    Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
				I've read all your posts, and all of any mail that comes into my
 email box....I don't go to the "site". The only thing problem that
 this creates is when somebody doesn't include a snippet of what they
 are replying to...like you did here. But this thread is current
 enough that even my poor memory allows me to "connect the dots." The
 other problem is when someone only gets the "digest" and includes 44
 messages in their reply, like I bitched about last week. : )
 I doubt that the filter element is your problem. I'm keeping all of
 my filters, no matter how much certain engineers might (for me)
 confuse the issue with talk of surface tension, etc., my system flows
 fuel as long as there's fuel in the system to flow...nudge, nudge,
 wink, wink. ; )
 Lynn Matteson
 On Oct 31, 2009, at 11:58 PM, FlyboyTR wrote:
  Lynn,
  problem that comes and goes...I would prefer for it to go!  [Laughing]
  observation.
  Travis
  Travis Rayner
  Mobile, AL
  ADI-II Autopilot
  http://forums.matronics.com/viewtopic.php?p 70317#270317
N369LM |
		FlyboyTR
				 Posted: Sun Nov 01, 2009 5:43 am    Post subject: Re: Fuel Flow Problems, Again! (Vixen, Series-5) |
				Lynn,
 ...you get to read a lot of email!
 I really don't want to get rid of my filters either.  We are still only talking about one filter between a wing tank and the header tank.  Once the fuel is in the header tank it should then benefit from the "suction" of the mechanical pump.
 My last two hurdles are removing the wing tank outlet fitting to check the finger strainers and cutting the root rib on the wing so the fuel line doesn't have to have a hump in it before descending down towards the header tank.  Thanks again for all your input...always appreciated!
 Travis
  	  | Lynn Matteson wrote: | 	 		  I've read all your posts, and all of any mail that comes into my  email box....I don't go to the "site".
 wink, wink. ; )
 Lynn Matteson
Mobile, AL
ADI-II Autopilot
		thesupe(at)hotmail.com Guest
		Fox5flyer Guest
				 Posted: Sun Nov 01, 2009 8:01 am    Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
				I know this thread has been going on forever and those who have wing tank
 filters will probably keep them.   Fuel flow is probably one of the most
 important parts of our airplane so talking this to death can't hurt a thing.
 Here's my take, for whatever it's worth.
 Ideally, "IMO" the lines from the wing tanks to the header should be as
 large as practicable...3/8 ID would be good.  To keep the head pressure as
 high as possible there should be no (unnecessary) restrictions between the
 tanks and the header, meaning no filters, valves, unnecessary fittings, or
 reducing fittings that restrict flow.  After the header, the same applies,
 however, it's obvious that one needs at minimum a shutoff valve and usually
 a fuel pump of some sort.  Since most fuel pumps are meant to push fuel, not
 suck, it should be at the lowest point in the system, generally just after
 the header and as close to it as practical.  After the fuel pump things are
 not so critical as most pumps can push fuel pressure and volume far beyond
 what static flow can provide.  Obviously, the 582s with diaphragm pumps
 wouldn't be very practical to be placed at this point, but to continue.
 There should be a shut off valve, generally on the console or wherever it's
 located that is easy to reach, again, IMO, the next restriction should be
 the filter.  This should be a high flow filter and could be located on the
 firewall and be the last line of defense before it goes to the carb/TB/etc.
 Again, I stated "ideally" and is only my opinion.  There are many other
 methods that work and some that don't, but as I recall a study was done at
 some point about forced landings and most were caused by fuel starvation.
 Everything that is put into the system between the fuel tanks and the engine
 is a restriction of some sort.  Add them all up and it can be significant
 and even though the system may be working it may be marginally close to
 failure without one knowing it.
 Personally, I don't feel the filters in the lines from the tanks to the
 header are necessary at all.  Between the finger strainers and the natural
 settling action of the header, plus the fuel sump at the bottom of the
 header, there is more than enough there to clean up the big stuff.  The
 final filter at the firewall will take care of anything that somehow reaches
 that point.
 I expect that some will take issue with this, and that is fine and I'd like
 to hear it.  Just be nice.
 Have a great day!
 Deke Morisse
 Mikado Michigan
 S5/Subaru/CAP 438+ TT
 "If you put the federal government in charge of the Sahara
 Desert, in five years there'd be a shortage of sand."
 -- Nobel prize-winning economist Milton Friedman (1912-2006)
		Lynn Matteson
				 Posted: Sun Nov 01, 2009 8:46 am    Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
				The only problem I have....and this is just a shade-tree mechanics
 view...is the paper filter. It is said that they will clog if water
 gets to them. I can see the benefit of not having a filter in the
 line to the header tank, as the header tank DOES work like a
 gascolator, and as such will catch (and allow for the sampling of)
 any crud that might get there. I put the filters in my down...to the
 header...lines because I wanted to see any crud that just got into
 those lines from airport A, or airport B, etc., or from my own 300-
 gallon tank at home.
 Like you said, to each his own, and future or current builders will
 be able to choose for themselves what they think is right. And of
 course, each DAR will have his/her own views on what they will allow.
 Lynn Matteson
 Jabiru 2200, #2062, 805.4 hrs
 Countdown to 1000 hrs--195 to go
 On Nov 1, 2009, at 10:06 AM, Jim_and_Lucy Chuk wrote:
  	  | Quote: | 	 		   When I first got my Avid MK IV, I put filters on both sides between
  the wing tanks and the header tank.  All was fine for a while
  (about 10-15 hrs) till one evening I took off from my strip and as
  I climbed out and got to 450', the engine started to miss and
  spit.  I ended up landing in a neighbors field with no dammage to
  me or the plane.  What had happened I found out the next day, was
  the filter on the tank I was using started to plug just a bit and
  so the flow was reduced.  The engine never did die, but would not
  run up above about 4000 rpm.  Durring the takeoff, it was turning
  up about 6200, and when the small header tank was emptied, things
  got "interesting".  I posted this account on the Avid list, and
  Steve Winder, who ran the Avid factory for years said NEVER HAVE
  FILTERS BETWEEN THE WING TANKS AND THE HEADER TANK.  He used all
  capitol letters also!  He said that it takes very little to stop or
  slow the gravity flow, and ofcourse that is what caused my
  problem.  He also said, that the header tank works as a gascolator
  to filter the fuel so the filters between the tanks aren't needed.
  I had a final filter between the header tank and the fuel pump, and
  so to gaurd against that one plugging and putting me in the trees,
  I put in a T in my fuel line and added a second filter alongside
  the first one and then a T back into the fuel line with a small
  valve to stop the flow through that filter.  When I'm taking off, I
  open that valve and then close it after I get up to 750' or so.  If
  the main filter ever starts to plug while in flight, I will open
  the valve for the second filter and the fuel will  be able to flow
  through that one and I will stay out of the trees.  So far that has
  worked good for me and I still have potentialy three filters to
  stop any crud getting to the carb.  The header tank, the inline
  filter, pluss the backup filter which will only be used if the
  first inline filter plugs.  To each his own, but this works for
  me.  I have always used the Fram paper filters and they have worked
  good for me.
  Take care,  Jim Chuk
  > Subject: Re: Fuel Flow Problems, Again! (Vixen,
  Series-5)
  > From: flyboytr(at)bellsouth.net
  > Date: Sun, 1 Nov 2009 05:43:45 -0800
  > To: kitfox-list(at)matronics.com
  <flyboytr(at)bellsouth.net>
  > Lynn,
  > ...you get to read a lot of email! [Shocked]
  > Travis
  all of
  flows
  > > wink, wink. ; )
  > > Lynn Matteson
  > > Kitfox IV Speedster, taildragger
  > > Electroair direct-fire ignition system
  > Travis Rayner
  > Mobile, AL
  > ADI-II Autopilot
  > http://forums.matronics.com/viewtopic.php?p 70420#270420
  New Windows 7: Find the right PC for you. Learn more._-
  ============================================================ _-
N369LM |
		Lynn Matteson
				 Posted: Sun Nov 01, 2009 9:17 am    Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
				Probably more important than where a person decides to place the
 filters, valves, etc., is the decision to do a flow test after all
 the plumbing is done. That might reveal more than all the theory in
 the world. If the flow test shows marginal flow, change something! If
 it doesn't......
 One of the discoveries that I made while changing to the TBI in place
 of the Bing carb, was I hadn't realized how far up the "flow chart"
 the carb/TBI was located. With my gravity flow ONLY system, if I have
 to point the nose up very steeply with low fuel....like when the
 header tank supply is the only fuel available....that fuel will not
 make it up to the TBI/carb. You folks with high-mounted carbs are
 almost certain candidates for a pumped system.
 If in doubt about the flow of your particular system, lay some
 masking paper on the side of the aircraft, and measure and plot where
 the various parts of the fuel system lie, and where the lines run.
 Draw these components onto the paper, then imagine the plane
 climbing, diving, banking, etc., and see where the fuel goes and also
 imagine a lower than normal fuel supply, and see where that leads you.
 Lynn Matteson
 On Nov 1, 2009, at 10:28 AM, fox5flyer wrote:
  <fox5flyer(at)idealwifi.net>
  wing tank filters will probably keep them.   Fuel flow is probably
  one of the most important parts of our airplane so talking this to
  death can't hurt a thing. Here's my take, for whatever it's worth.
  be as large as practicable...3/8 ID would be good.  To keep the
  head pressure as high as possible there should be no (unnecessary)
  restrictions between the tanks and the header, meaning no filters,
  valves, unnecessary fittings, or reducing fittings that restrict
  flow.  After the header, the same applies, however, it's obvious
  that one needs at minimum a shutoff valve and usually a fuel pump
  just after the header and as close to it as practical.  After the
  fuel pump things are not so critical as most pumps can push fuel
  pressure and volume far beyond what static flow can provide.
  Obviously, the 582s with diaphragm pumps wouldn't be very practical
  to be placed at this point, but to continue. There should be a shut
  off valve, generally on the console or wherever it's located that
  is easy to reach, again, IMO, the next restriction should be the
  the firewall and be the last line of defense before it goes to the
  carb/TB/etc. Again, I stated "ideally" and is only my opinion.
  There are many other methods that work and some that don't, but as
  I recall a study was done at some point about forced landings and
  most were caused by fuel starvation. Everything that is put into
  the system between the fuel tanks and the engine is a restriction
  of some sort.  Add them all up and it can be significant and even
  the header are necessary at all.  Between the finger strainers and
  the natural settling action of the header, plus the fuel sump at
  the bottom of the header, there is more than enough there to clean
  up the big stuff.  The final filter at the firewall will take care
  of anything that somehow reaches that point.
  I'd like to hear it.  Just be nice.
  Have a great day!
  Deke Morisse
  Mikado Michigan
N369LM |
		jareds(at)verizon.net Guest
				 Posted: Sun Nov 01, 2009 12:35 pm    Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
				I have not read most of the posts and you may have already gotten this info
 but I will never get rid of my glass filters at the wing tanks.. VITAL in
 flight to physically see the fuel flow and see whats maybe sitting in my
 tanks.  What I don't see unless I look very close is the little bits of
 fiberglass but I keep filter elements handy and change very often.
 As to the fuel flow..  Don Smythe cured my issues years ago when I was in
 DC.  He said "Always down hill" and even with a little bump in the hoses its
 ok but the critical one is the vent line.  And to me that's the biggest
 obstical because its always in the way to making a neat cockpit but when I
 am cruising along and my header tank fuel low light comes on I can always
 look at my vent line and know its got a dip in it!
 Hope that helps.
 Jared
 Nov 1, 2009 07:54:21 AM, kitfox-list(at)matronics.com wrote:
 Lynn,
 Travis
  	  | Quote: | 	 		   I've read all your posts, and all of any mail that comes into my  email box....I don't go to the "site".
  wink, wink. ; )
  Lynn Matteson
 Travis Rayner
 Mobile, AL
 ADI-II Autopilot
		dwight purdy
				 Posted: Sun Nov 01, 2009 1:58 pm    Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
				I do not comment often but listen a lot.
   On this subject of fuel filters will say that in my 32 years of flying I
 have never seen a filter on a GA certified aircraft. That does not include
 any of the newer fuel injected ones. I have had a paper filter for a short
 time on my model II. While running premix and some ethanol in the fuel I was
 forced to land off field. Once that paper gets oil soaked water will not
 pass properly. Took the filter out and no problem.
 Dwight Purdy
 Model II
  _________________ dwight
model II |
		Lynn Matteson
				 Posted: Sun Nov 01, 2009 3:58 pm    Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
				I think you'll find that the filter on a GA aircraft is disguised and
 called a gascolator...but I could be wrong.
 Inside my Rotec TBI is what is called a "last chance" filter. It
 catches the bad stuff that would otherwise try to plug the 50-some
 holes in the fuel discharge tube. These holes are reportedly .
 010" (ten-thousandths of an inch) in diameter. I trust my Purolator
 glass filters to keep the last chance filter, and thence the fuel
 discharge tube, clean. I won't take my "pre-filters" out unless
 something or someone proves that this is an incorrect design. And as
 long as my gravity system flows more than twice what is needed by the
 engine, that likelihood seems remote.
 Lynn Matteson
  flying I have never seen a filter on a GA certified aircraft. That
  does not include any of the newer fuel injected ones. I have had a
  paper filter for a short time on my model II. While running premix
  and some ethanol in the fuel I was forced to land off field. Once
  that paper gets oil soaked water will not pass properly. Took the
  Dwight Purdy
  Model II
N369LM |
		KeysFox
				 Posted: Mon Nov 02, 2009 4:47 am    Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
				This extended discussion on fuel flow issues has been just the sort of
 thing I want out of the list sereve.
 When I unport my right wing tank during a prolonged descent with low fuel
 (model IV with large tanks) I watch fuel drain down out of the vent line
 until the glass tube inline filter housing empties and does not refill
 unless I crack the seal on it on the ground, then fuel instantly flows.
 This has occurred several times  even with new filter elements, clean
 finger strainers in the tanks, new fuel lines throughout, and lots of
 attention to straight fuel lines between wing tanks and header tank.
 Rather than removing the in line filter elements, I may try placing some
 larger openings in the elements. The idea being less resistance but
 ability to monitor for crud.
 Thanks to those who have posted comments and to the list serve manager for
 making this (and other discussions possible.)
 B J
 N154K model IV
  Travis Rayner
  Mobile, AL
  ADI-II Autopilot
  http://forums.matronics.com/viewtopic.php?p 70320#270320
  _________________ B Jones
N154K
443-480-1023 |
		Lynn Matteson
				 Posted: Mon Nov 02, 2009 6:12 am    Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
				Could it be that your vent line has a uphill/downhill portion in it?
 That could be one reason that the fuel won't fill the filters. What I
 *think* is happening is this:   You run the header tank low by using
 fuel from it instead of the tanks when you unport the wing tanks in
 your descent. Then with the plane at ground attitude, fuel tries to
 come down the fuel lines through the filters and into the header
 tank. Some does (maybe), but apparently not all unless you "crack the
 seal". I believe that when the fuel tries to flow into the header
 tank it is trying to overcome air trapped inside the header
 tank....trapped because of fuel that is trapped in the uphill/
 downhill vent line, and can't be pushed uphill by the downflowing
 fuel in the fuel lines. I've had the same thing happen with my
 plane.....watching the vent line empty during the descent (and of
 course the fuel line is emptying at the same time....and I've been
 lucky enough to tip the plane to an attitude that allows for a "mid-
 air re-fueling" if you will. But I was very careful to make certain
 of there being NO uphill/downhill sections in my vent line.
 It would seem to me that this scenario that I just suggested would
 require just a certain amount of fuel trying to come down the fuel
 lines *versus* a certain amount of fuel trapped in the  uphill/
 downhill vent line, or a certain amount of volume of lines for this
 to happen.
 Lynn Matteson
 On Nov 2, 2009, at 7:38 AM, bjones(at)dmv.com wrote:
  low fuel
  line
  flows.
  some
  manager for
  B J
  N154K model IV
 > see that
 > Travis Rayner
 > Mobile, AL
 > ADI-II Autopilot
N369LM |
