FlyboyTR
Joined: 04 Nov 2006 Posts: 215 Location: Mobile, Alabama
Posted: Sat Oct 31, 2009 2:34 pm Post subject: Re: Fuel Flow Problems, Again! (Vixen, Series-5) |
Lynn,
I am considering cutting the fitting as you suggested. However, looking at it, I really don't believe there is a finger strainer there! I guess I need to check the builders log and see if the rib should be cut down. The fuel line is about 3/4" higher than the fitting.
Note...My system is NOT sucking air! This last problem happened about 35 minutes flight time after both tanks were filled to the brim for a 400 mile flight. I get air in my filters and they are AIR LOCKING...sort of like a vapor lock. Don't know where the air comes from! This problem doesn't happen very ofter...but when it does the fuel stops flowing. Once I get the fuel to flow again, the air gets pushed out/down and all is well...until the next time it happens.
Thanks again for the plastic under the fitting trick!
OH...are there finger strainers still available for purchase?
Travis
_________________ Travis Rayner
Mobile, AL
Skystar Vixen, N-789DF
Continental IO-240, Prince P-Tip Prop
ADI-II Autopilot
AnyWhereMap Navigation with weather
www.enotam.net (My Flying Info Website) |
Fox5flyer Guest
Posted: Sat Oct 31, 2009 3:58 pm Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
Travis, that thing that looks like a brass bushing in your tank (the thing
that your 90 degree fitting screws into) is probably your finger strainer.
Deke
FlyboyTR
Posted: Sat Oct 31, 2009 4:03 pm Post subject: Re: Fuel Flow Problems, Again! (Vixen, Series-5) |
Deke,
If that's the case, then I will be unscrewing it from the tank itself...not another bushing? Is that right?
Mobile, AL
ADI-II Autopilot
Fox5flyer Guest
Posted: Sat Oct 31, 2009 5:03 pm Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
Correct.
D
Lynn Matteson
Posted: Sat Oct 31, 2009 5:14 pm Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
Can you stick a mirror into the tank and see the fitting area? Or is
there a baffle in the way?
In the case of my tank(s), that outer brass IS the finger strainer,
like Deke suggested.
Lynn Matteson
Jabiru 2200, #2062, 804.3 hrs
Countdown to 1000 hrs--196 to go
Sensenich 62"x46" Wood prop
Rotec TBI-40 injection
Status: flying (and learning)
On Oct 31, 2009, at 8:03 PM, FlyboyTR wrote:
Deke,
Travis Rayner
Mobile, AL
ADI-II Autopilot
http://forums.matronics.com/viewtopic.php?p 70285#270285
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Lynn Matteson
Posted: Sat Oct 31, 2009 5:58 pm Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
Sorry, I got the notion that *you* thought it was sucking air after I
read this:
" If by chance the system air-locks...at least now I can close the
vent line and force the system to pull from the tanks, rather than
sucking air."
I see a bubble of air in my filters too, and I've seen this in almost
every glass filter fuel system that I've owned...which is
several....and in others that I've observed over the years. It never
seems to bother the fuel flow, it just seems to bother people who
look at it. Maybe that's why people like the filters that they can't
see into....you know....out of sight, out of mind. I've seen glass
filters standing almost straight up, like yours and mine, and I've
seen them laying on their side, like my third filter which lays
almost horizontally inside my center console. Seeing this air doesn't
bother me as gravity keeps the fuel flowing in my system, and fuel is
heavier than air, and a bubble of air isn't strong enough to keep the
fuel from falling downhill inside that filter.....IF there is
sufficient venting above to ALLOW the fuel to fall. If my brand of
physics is wrong, I'd like to know why I haven't had any fuel-flow-
related problems in over 800 hours and billions of gallons of
fuel....oh, wait, that's that guy in Canada that uses all that
fuel....let's says roughly 3200 gallons of fuel passed through the
system in that time.
Lynn Matteson
On Oct 31, 2009, at 6:34 PM, FlyboyTR wrote:
Lynn,
fitting.
it happens.
Travis
Travis Rayner
Mobile, AL
ADI-II Autopilot
http://forums.matronics.com/viewtopic.php?p 70276#270276
N369LM |
lcfitt(at)sbcglobal.net Guest
Posted: Sat Oct 31, 2009 7:10 pm Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
The more centric feed location was intended to reduce the tendency to unport
in long descents. The T is to direct the fuel line aft to position the fuel
line for wing folding.
There was discussion on the list about this issue when this mod came down.
Some put inspection plates under the fitting. I can agree that the mod
helped in one area and hurt in another. I guess the unintended consequences
thing.
:Lowell
FlyboyTR
Posted: Sat Oct 31, 2009 7:58 pm Post subject: Re: Fuel Flow Problems, Again! (Vixen, Series-5) |
Lynn,
This problem happens, usually, when my tanks are more than 1/2 - 3/4 full. To my knowledge I've never "unported" the tank by descending at such an angle that the fuel moves away from the outlet.
As so often happens on this forum, someone will reply to a post by starting a new post with the same title (as happened to this thread). If you haven't read my original post, please take a look. I tried to explain the details and history of this problem that comes and goes...I would prefer for it to go!
Once I'm back in the air...should this happen again, I will remove the filter element but keep the glass filter housing in place for observation.
Travis
Mobile, AL
ADI-II Autopilot
FlyboyTR
Posted: Sat Oct 31, 2009 8:06 pm Post subject: Re: Fuel Flow Problems, Again! (Vixen, Series-5) |
Sorry...I missed that... No, I have baffles in the tank. Can't see that area of the tank. ...which I could!
Mobile, AL
ADI-II Autopilot
Lynn Matteson
Posted: Sun Nov 01, 2009 3:36 am Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
I've read all your posts, and all of any mail that comes into my
email box....I don't go to the "site". The only thing problem that
this creates is when somebody doesn't include a snippet of what they
are replying to...like you did here. But this thread is current
enough that even my poor memory allows me to "connect the dots." The
other problem is when someone only gets the "digest" and includes 44
messages in their reply, like I bitched about last week. : )
I doubt that the filter element is your problem. I'm keeping all of
my filters, no matter how much certain engineers might (for me)
confuse the issue with talk of surface tension, etc., my system flows
fuel as long as there's fuel in the system to flow...nudge, nudge,
wink, wink. ; )
Lynn Matteson
On Oct 31, 2009, at 11:58 PM, FlyboyTR wrote:
Lynn,
problem that comes and goes...I would prefer for it to go! [Laughing]
observation.
Travis
Travis Rayner
Mobile, AL
ADI-II Autopilot
http://forums.matronics.com/viewtopic.php?p 70317#270317
N369LM |
FlyboyTR
Posted: Sun Nov 01, 2009 5:43 am Post subject: Re: Fuel Flow Problems, Again! (Vixen, Series-5) |
Lynn,
...you get to read a lot of email!
I really don't want to get rid of my filters either. We are still only talking about one filter between a wing tank and the header tank. Once the fuel is in the header tank it should then benefit from the "suction" of the mechanical pump.
My last two hurdles are removing the wing tank outlet fitting to check the finger strainers and cutting the root rib on the wing so the fuel line doesn't have to have a hump in it before descending down towards the header tank. Thanks again for all your input...always appreciated!
Travis
| Lynn Matteson wrote: | I've read all your posts, and all of any mail that comes into my email box....I don't go to the "site".
wink, wink. ; )
Lynn Matteson
Mobile, AL
ADI-II Autopilot
thesupe(at)hotmail.com Guest
Fox5flyer Guest
Posted: Sun Nov 01, 2009 8:01 am Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
I know this thread has been going on forever and those who have wing tank
filters will probably keep them. Fuel flow is probably one of the most
important parts of our airplane so talking this to death can't hurt a thing.
Here's my take, for whatever it's worth.
Ideally, "IMO" the lines from the wing tanks to the header should be as
large as practicable...3/8 ID would be good. To keep the head pressure as
high as possible there should be no (unnecessary) restrictions between the
tanks and the header, meaning no filters, valves, unnecessary fittings, or
reducing fittings that restrict flow. After the header, the same applies,
however, it's obvious that one needs at minimum a shutoff valve and usually
a fuel pump of some sort. Since most fuel pumps are meant to push fuel, not
suck, it should be at the lowest point in the system, generally just after
the header and as close to it as practical. After the fuel pump things are
not so critical as most pumps can push fuel pressure and volume far beyond
what static flow can provide. Obviously, the 582s with diaphragm pumps
wouldn't be very practical to be placed at this point, but to continue.
There should be a shut off valve, generally on the console or wherever it's
located that is easy to reach, again, IMO, the next restriction should be
the filter. This should be a high flow filter and could be located on the
firewall and be the last line of defense before it goes to the carb/TB/etc.
Again, I stated "ideally" and is only my opinion. There are many other
methods that work and some that don't, but as I recall a study was done at
some point about forced landings and most were caused by fuel starvation.
Everything that is put into the system between the fuel tanks and the engine
is a restriction of some sort. Add them all up and it can be significant
and even though the system may be working it may be marginally close to
failure without one knowing it.
Personally, I don't feel the filters in the lines from the tanks to the
header are necessary at all. Between the finger strainers and the natural
settling action of the header, plus the fuel sump at the bottom of the
header, there is more than enough there to clean up the big stuff. The
final filter at the firewall will take care of anything that somehow reaches
that point.
I expect that some will take issue with this, and that is fine and I'd like
to hear it. Just be nice.
Have a great day!
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 438+ TT
"If you put the federal government in charge of the Sahara
Desert, in five years there'd be a shortage of sand."
-- Nobel prize-winning economist Milton Friedman (1912-2006)
Lynn Matteson
Posted: Sun Nov 01, 2009 8:46 am Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
The only problem I have....and this is just a shade-tree mechanics
view...is the paper filter. It is said that they will clog if water
gets to them. I can see the benefit of not having a filter in the
line to the header tank, as the header tank DOES work like a
gascolator, and as such will catch (and allow for the sampling of)
any crud that might get there. I put the filters in my down...to the
header...lines because I wanted to see any crud that just got into
those lines from airport A, or airport B, etc., or from my own 300-
gallon tank at home.
Like you said, to each his own, and future or current builders will
be able to choose for themselves what they think is right. And of
course, each DAR will have his/her own views on what they will allow.
Lynn Matteson
Jabiru 2200, #2062, 805.4 hrs
Countdown to 1000 hrs--195 to go
On Nov 1, 2009, at 10:06 AM, Jim_and_Lucy Chuk wrote:
| Quote: | When I first got my Avid MK IV, I put filters on both sides between
the wing tanks and the header tank. All was fine for a while
(about 10-15 hrs) till one evening I took off from my strip and as
I climbed out and got to 450', the engine started to miss and
spit. I ended up landing in a neighbors field with no dammage to
me or the plane. What had happened I found out the next day, was
the filter on the tank I was using started to plug just a bit and
so the flow was reduced. The engine never did die, but would not
run up above about 4000 rpm. Durring the takeoff, it was turning
up about 6200, and when the small header tank was emptied, things
got "interesting". I posted this account on the Avid list, and
Steve Winder, who ran the Avid factory for years said NEVER HAVE
FILTERS BETWEEN THE WING TANKS AND THE HEADER TANK. He used all
capitol letters also! He said that it takes very little to stop or
slow the gravity flow, and ofcourse that is what caused my
problem. He also said, that the header tank works as a gascolator
to filter the fuel so the filters between the tanks aren't needed.
I had a final filter between the header tank and the fuel pump, and
so to gaurd against that one plugging and putting me in the trees,
I put in a T in my fuel line and added a second filter alongside
the first one and then a T back into the fuel line with a small
valve to stop the flow through that filter. When I'm taking off, I
open that valve and then close it after I get up to 750' or so. If
the main filter ever starts to plug while in flight, I will open
the valve for the second filter and the fuel will be able to flow
through that one and I will stay out of the trees. So far that has
worked good for me and I still have potentialy three filters to
stop any crud getting to the carb. The header tank, the inline
filter, pluss the backup filter which will only be used if the
first inline filter plugs. To each his own, but this works for
me. I have always used the Fram paper filters and they have worked
good for me.
Take care, Jim Chuk
> Subject: Re: Fuel Flow Problems, Again! (Vixen,
Series-5)
> From: flyboytr(at)bellsouth.net
> Date: Sun, 1 Nov 2009 05:43:45 -0800
> To: kitfox-list(at)matronics.com
<flyboytr(at)bellsouth.net>
> Lynn,
> ...you get to read a lot of email! [Shocked]
> Travis
all of
flows
> > wink, wink. ; )
> > Lynn Matteson
> > Kitfox IV Speedster, taildragger
> > Electroair direct-fire ignition system
> Travis Rayner
> Mobile, AL
> ADI-II Autopilot
> http://forums.matronics.com/viewtopic.php?p 70420#270420
New Windows 7: Find the right PC for you. Learn more._-
N369LM |
Lynn Matteson
Posted: Sun Nov 01, 2009 9:17 am Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
Probably more important than where a person decides to place the
filters, valves, etc., is the decision to do a flow test after all
the plumbing is done. That might reveal more than all the theory in
the world. If the flow test shows marginal flow, change something! If
it doesn't......
One of the discoveries that I made while changing to the TBI in place
of the Bing carb, was I hadn't realized how far up the "flow chart"
the carb/TBI was located. With my gravity flow ONLY system, if I have
to point the nose up very steeply with low fuel....like when the
header tank supply is the only fuel available....that fuel will not
make it up to the TBI/carb. You folks with high-mounted carbs are
almost certain candidates for a pumped system.
If in doubt about the flow of your particular system, lay some
masking paper on the side of the aircraft, and measure and plot where
the various parts of the fuel system lie, and where the lines run.
Draw these components onto the paper, then imagine the plane
climbing, diving, banking, etc., and see where the fuel goes and also
imagine a lower than normal fuel supply, and see where that leads you.
Lynn Matteson
On Nov 1, 2009, at 10:28 AM, fox5flyer wrote:
<fox5flyer(at)idealwifi.net>
wing tank filters will probably keep them. Fuel flow is probably
one of the most important parts of our airplane so talking this to
death can't hurt a thing. Here's my take, for whatever it's worth.
be as large as practicable...3/8 ID would be good. To keep the
head pressure as high as possible there should be no (unnecessary)
restrictions between the tanks and the header, meaning no filters,
valves, unnecessary fittings, or reducing fittings that restrict
flow. After the header, the same applies, however, it's obvious
that one needs at minimum a shutoff valve and usually a fuel pump
just after the header and as close to it as practical. After the
fuel pump things are not so critical as most pumps can push fuel
pressure and volume far beyond what static flow can provide.
Obviously, the 582s with diaphragm pumps wouldn't be very practical
to be placed at this point, but to continue. There should be a shut
off valve, generally on the console or wherever it's located that
is easy to reach, again, IMO, the next restriction should be the
the firewall and be the last line of defense before it goes to the
carb/TB/etc. Again, I stated "ideally" and is only my opinion.
There are many other methods that work and some that don't, but as
I recall a study was done at some point about forced landings and
most were caused by fuel starvation. Everything that is put into
the system between the fuel tanks and the engine is a restriction
of some sort. Add them all up and it can be significant and even
the header are necessary at all. Between the finger strainers and
the natural settling action of the header, plus the fuel sump at
the bottom of the header, there is more than enough there to clean
up the big stuff. The final filter at the firewall will take care
of anything that somehow reaches that point.
I'd like to hear it. Just be nice.
Have a great day!
Deke Morisse
Mikado Michigan
N369LM |
jareds(at)verizon.net Guest
Posted: Sun Nov 01, 2009 12:35 pm Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
I have not read most of the posts and you may have already gotten this info
but I will never get rid of my glass filters at the wing tanks.. VITAL in
flight to physically see the fuel flow and see whats maybe sitting in my
tanks. What I don't see unless I look very close is the little bits of
fiberglass but I keep filter elements handy and change very often.
As to the fuel flow.. Don Smythe cured my issues years ago when I was in
DC. He said "Always down hill" and even with a little bump in the hoses its
ok but the critical one is the vent line. And to me that's the biggest
obstical because its always in the way to making a neat cockpit but when I
am cruising along and my header tank fuel low light comes on I can always
look at my vent line and know its got a dip in it!
Hope that helps.
Jared
Nov 1, 2009 07:54:21 AM, kitfox-list(at)matronics.com wrote:
Lynn,
Travis
| Quote: | I've read all your posts, and all of any mail that comes into my email box....I don't go to the "site".
wink, wink. ; )
Lynn Matteson
Travis Rayner
Mobile, AL
ADI-II Autopilot
dwight purdy
Posted: Sun Nov 01, 2009 1:58 pm Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
I do not comment often but listen a lot.
On this subject of fuel filters will say that in my 32 years of flying I
have never seen a filter on a GA certified aircraft. That does not include
any of the newer fuel injected ones. I have had a paper filter for a short
time on my model II. While running premix and some ethanol in the fuel I was
forced to land off field. Once that paper gets oil soaked water will not
pass properly. Took the filter out and no problem.
Dwight Purdy
Model II
_________________ dwight
model II |
Lynn Matteson
Posted: Sun Nov 01, 2009 3:58 pm Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
I think you'll find that the filter on a GA aircraft is disguised and
called a gascolator...but I could be wrong.
Inside my Rotec TBI is what is called a "last chance" filter. It
catches the bad stuff that would otherwise try to plug the 50-some
holes in the fuel discharge tube. These holes are reportedly .
010" (ten-thousandths of an inch) in diameter. I trust my Purolator
glass filters to keep the last chance filter, and thence the fuel
discharge tube, clean. I won't take my "pre-filters" out unless
something or someone proves that this is an incorrect design. And as
long as my gravity system flows more than twice what is needed by the
engine, that likelihood seems remote.
Lynn Matteson
flying I have never seen a filter on a GA certified aircraft. That
does not include any of the newer fuel injected ones. I have had a
paper filter for a short time on my model II. While running premix
and some ethanol in the fuel I was forced to land off field. Once
that paper gets oil soaked water will not pass properly. Took the
Dwight Purdy
Model II
N369LM |
KeysFox
Posted: Mon Nov 02, 2009 4:47 am Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
This extended discussion on fuel flow issues has been just the sort of
thing I want out of the list sereve.
When I unport my right wing tank during a prolonged descent with low fuel
(model IV with large tanks) I watch fuel drain down out of the vent line
until the glass tube inline filter housing empties and does not refill
unless I crack the seal on it on the ground, then fuel instantly flows.
This has occurred several times even with new filter elements, clean
finger strainers in the tanks, new fuel lines throughout, and lots of
attention to straight fuel lines between wing tanks and header tank.
Rather than removing the in line filter elements, I may try placing some
larger openings in the elements. The idea being less resistance but
ability to monitor for crud.
Thanks to those who have posted comments and to the list serve manager for
making this (and other discussions possible.)
B J
N154K model IV
Travis Rayner
Mobile, AL
ADI-II Autopilot
http://forums.matronics.com/viewtopic.php?p 70320#270320
_________________ B Jones
N154K
443-480-1023 |
Lynn Matteson
Posted: Mon Nov 02, 2009 6:12 am Post subject: Fuel Flow Problems, Again! (Vixen, Series-5) |
Could it be that your vent line has a uphill/downhill portion in it?
That could be one reason that the fuel won't fill the filters. What I
*think* is happening is this: You run the header tank low by using
fuel from it instead of the tanks when you unport the wing tanks in
your descent. Then with the plane at ground attitude, fuel tries to
come down the fuel lines through the filters and into the header
tank. Some does (maybe), but apparently not all unless you "crack the
seal". I believe that when the fuel tries to flow into the header
tank it is trying to overcome air trapped inside the header
tank....trapped because of fuel that is trapped in the uphill/
downhill vent line, and can't be pushed uphill by the downflowing
fuel in the fuel lines. I've had the same thing happen with my
plane.....watching the vent line empty during the descent (and of
course the fuel line is emptying at the same time....and I've been
lucky enough to tip the plane to an attitude that allows for a "mid-
air re-fueling" if you will. But I was very careful to make certain
of there being NO uphill/downhill sections in my vent line.
It would seem to me that this scenario that I just suggested would
require just a certain amount of fuel trying to come down the fuel
lines *versus* a certain amount of fuel trapped in the uphill/
downhill vent line, or a certain amount of volume of lines for this
to happen.
Lynn Matteson
On Nov 2, 2009, at 7:38 AM, bjones(at)dmv.com wrote:
low fuel
line
flows.
some
manager for
B J
N154K model IV
> see that
> Travis Rayner
> Mobile, AL
> ADI-II Autopilot
N369LM |
