		Ken Potter
  Joined: 18 Aug 2007 Posts: 85 Location: Lanark, Ontario
				 Posted: Sat Nov 21, 2009 5:11 am    Post subject: Fuel Line Size |
				Hi folks;
 I was installing my fire-wall-forward fuel lines yesterday (Rotax 582).  The plans for my model II show the line from the gascolator to fuel pump as 5/16" however both the gascolator and fuel pump have 1/4" fittings.
 What size does everyone else out there use for this line??
 Cheers
 Ken
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Ken Potter
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario |
		dave
				 Posted: Sun Nov 22, 2009 3:19 am    Post subject: Re: Fuel Line Size |
				Ken,
 I would suggest  1/4 " lines throughout.  Wing tank fittings might need 5/16s depending fittings.  Larger line would be over kill on the 582
 Once plumbed run a gravity flow fuel test.  Your 582 will burn up to 30 litres/ hour at wide open. I Think you should see about 40 litres/hour with gravity test alone.
 1/4" from gascolator forward will do you fine. Use fire sleeve forward of firewall but if you registered as Ultralight in Canada you don't have to but it a good idea. Blue urethane fuel line is a great choice. Use safety wire double looped and not tie wraps as they don't seal as well.  Don't use plastic or gear clamps either.
 Impulse line 1/4" heavy wall urethane or  fuel injection line up to 12 " long .
  _________________ Realtime Kitfox movies to separate  the internet  chatter from the truth
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
		Ken Potter
				 Posted: Sun Nov 22, 2009 6:38 am    Post subject: Re: Fuel Line Size |
				Thanks Dave;
 Yesterday I installed 1/4" Bing blue fuel line from the gascolator to the pump, and from the pump to the carbs.  I used a piece of R-9 injector hose for the impulse line.  All lines, including primer, impulse, and oil injection are fire shielded.
 In addition,  I removed the header tank behind the seat and replaced the hoses that the previous builder had installed with ethanal resistant 5/16" R-9 injector hose.  As well I replaced the vent line with 1/4" Bing.
 Cheers,
 Ken
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario |
		Guy Buchanan
				 Posted: Sun Nov 22, 2009 9:50 pm    Post subject: Fuel Line Size |
				At 05:11 AM 11/21/2009, you wrote:
  	  | Quote: | 	 		  What size does everyone else out there use for this line??
 1/4".
 Guy Buchanan
 San Diego, CA
 K-IV 1200 / 582-C / Warp / 400 hrs. and counting
Deceased K-IV 1200
A glider pilot too. |
