Ken Potter
Joined: 18 Aug 2007 Posts: 85 Location: Lanark, Ontario
Posted: Sat Nov 21, 2009 5:11 am Post subject: Fuel Line Size |
Hi folks;
I was installing my fire-wall-forward fuel lines yesterday (Rotax 582). The plans for my model II show the line from the gascolator to fuel pump as 5/16" however both the gascolator and fuel pump have 1/4" fittings.
What size does everyone else out there use for this line??
Cheers
Ken
_________________ Ken Potter
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario |
dave
Posted: Sun Nov 22, 2009 3:19 am Post subject: Re: Fuel Line Size |
Ken,
I would suggest 1/4 " lines throughout. Wing tank fittings might need 5/16s depending fittings. Larger line would be over kill on the 582
Once plumbed run a gravity flow fuel test. Your 582 will burn up to 30 litres/ hour at wide open. I Think you should see about 40 litres/hour with gravity test alone.
1/4" from gascolator forward will do you fine. Use fire sleeve forward of firewall but if you registered as Ultralight in Canada you don't have to but it a good idea. Blue urethane fuel line is a great choice. Use safety wire double looped and not tie wraps as they don't seal as well. Don't use plastic or gear clamps either.
Impulse line 1/4" heavy wall urethane or fuel injection line up to 12 " long .
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Ken Potter
Posted: Sun Nov 22, 2009 6:38 am Post subject: Re: Fuel Line Size |
Thanks Dave;
Yesterday I installed 1/4" Bing blue fuel line from the gascolator to the pump, and from the pump to the carbs. I used a piece of R-9 injector hose for the impulse line. All lines, including primer, impulse, and oil injection are fire shielded.
In addition, I removed the header tank behind the seat and replaced the hoses that the previous builder had installed with ethanal resistant 5/16" R-9 injector hose. As well I replaced the vent line with 1/4" Bing.
Cheers,
Ken
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario |
Guy Buchanan
Posted: Sun Nov 22, 2009 9:50 pm Post subject: Fuel Line Size |
At 05:11 AM 11/21/2009, you wrote:
| Quote: | What size does everyone else out there use for this line??
1/4".
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 400 hrs. and counting
Deceased K-IV 1200
A glider pilot too. |
