Lew Gallagher
Posted: Sun Dec 06, 2009 7:01 am Post subject: Stick centering |
Hey Guys,
Since I'm not a pilot, I'm asking this on behalf of my owner/pilot partner -- be gentle!
He says this is the first plane he has seen that doesn't have a mechanism for bringing the stick back to center. I.e. hands off, the plane should level out if trimmed correctly. Keep in mind that he has not yet gone for his cross training in an RV-10, so this is all speculation. Maybe in flight, it does center?
I've read here about when "dialed in" the -10 flies itself, but it think that was in reference to AP discussions. In spite of my strong encouragement that he should install an AP (after reading here about the advantages), he insists it's all about actively flying for him, not riding.
So I guess the direct question is: Without an AP installed, have others addressed this with springs, or whatever, or is it really not an issue?
Thanks, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
Posted: Sun Dec 06, 2009 7:33 am Post subject: Stick centering |
The AP adds some resistance to the system but doesn't hold the stick in position. When I remove my hand from the stick, if trimmed properly the aircraft continues to fly straight and level...I'm assuming the air pressures are keeping the control surfaces in aerodynamic place I've never flown an aircraft with a spring return except the ones on my R/C transmitter Build it as designed it does work quite well
Rick Sked
Sent via BlackBerry by AT&T
Posted: Sun Dec 06, 2009 9:23 am Post subject: Stick centering |
I don't thinks it's an issue. Here's the explanation that I have in my
head to understand what's happening-
The aircraft we fly, when in flight, are positively stable in pitch.
That is, once trimmed and then disturbed hands off, the aircraft will
return to the trimmed state after a few oscillations. This is
accomplished in a variety of ways that may include springs and weights
in the control system. But it doesn't have anything to do with the
stick returning to a center.
The same aircraft when in flight are not positively stable in roll.
They may remain level if not disturbed in absolutely still air (no such
thing). Hands off, at some point, they will fall off in one direction
or another and enter a spiral. But that doesn't have anything to do
with the stick returning to center either.
Generally speaking, one of the neat things about experimental aircraft
is that they can be less stable in certain ways than certified
aircraft. That often means less junk in the control system which means
a more pleasant and responsive control experience. But too little
stability or too much responsiveness can mean trouble too.
This is going to be interesting because there's a lot stuff to
understand about stability - dynamic, static, longitudinal, lateral,
convergent, divergent, etc. I only understand most of it when I'm
staring at a text book.
Bill
Lew Gallagher wrote:
Hey Guys,
Thanks, - Lew
non-pilot
Painting done!
On with wiring and avionics.
http://forums.matronics.com/viewtopic.php?p 76452#276452
Posted: Sun Dec 06, 2009 9:45 am Post subject: Stick centering |
Since I'm not flying mine ...... I don't think you'll need any 'spring
trim'. You have elevator trim available, and rudder trim can be as
simple as a piece of wood taped to the rudder or aileron trailing edge.
I'm going to have active rudder and aileron trim ..... a piece of hinge
riveted to the trailing edge and driven by a model airplane servo.
As to being 'dialed in' .... I think it's still referring to rigging
... which means all the stuff out in the air is really pointing in the
correct direction, and in relation to each other. So many things affect
flying 'trim' so it's a fairly long process to tweak the surfaces so
everything is aerodynamically correct.
Linn
<lewgall(at)charter.net>
Hey Guys,
not riding.
an issue?
Thanks, - Lew
-------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549
Painting done! On with wiring and avionics.
partner14
Posted: Sun Dec 06, 2009 10:51 am Post subject: Stick centering |
Hey Lew, Don here..... I believe that actual "centering" would be of no hope for actually flying any aircraft on a distinct heading and altitude. For every flight the wt & bal changes, and if that wasn't enough, the wt & bal changes during flight. So say the stick returns to center,,,, the same center you'll have one day with a 250lb guy sitting next to you, and then the following day flying with yourself. Or one day with no baggage and the next day with 100lbs. Then what about fuel burn? I suppose you could fly your heading based on fuel burn.... veering a little left, switch to the left tank for awhile.....
I can't imagine anyone who was building a 10,,,,, for the reasons one would actually build a 10, and not install an AP.
Although I was really leaning to rudder and aileron trim while building, now that I'm flying, I don't find much need for either one. Plane flies almost perfect in the vast majority of conditions.... the rest of the time, it flies almost perfect!
Ok, that's my 2cents
Don McDonald
New pilot, 90+ hours, and enjoying the %$&* out of it!
--- On Sun, 12/6/09, Lew Gallagher <lewgall(at)charter.net> wrote:
Subject: Stick centering
Date: Sunday, December 6, 2009, 7:01 AM
--> RV10-List message posted by: "Lew Gallagher" <lewgall(at)charter.net (lewgall(at)charter.net)>
Hey Guys,
Thanks, - Lew
non-pilot
Painting done!
http://forums.matronics.com/viewtopic.php?pp; the Contribution link below to find out more "http://www.matronics.com/contribution" target=_blank>http://www.matronicsp; -Matt DrNavigator?RV10-List" target=_blank>http://www.matronics.com/Navigator?RV1bsp; - MATRONICS WEB FORUMS -=====
40636 |
coop85(at)verizon.net Guest
Posted: Sun Dec 06, 2009 1:33 pm Post subject: Stick centering |
Lew,
I think the other messages may have answered your question, but the
simple answer is airloads return the controls to neutral. I don't know what
your partner has been flying, but all the light general aviation airplanes
I've ever flown don't have a spring centering system (with the exception of
my Q-2 but it was a spring biased trim system so doesn't really count). If
you go out to any light Cessna or Piper and move the ailerons they will stay
that way during preflight. The elevator falls because of the weight. The
rudder may center but primarily due to springs that keep the rudder pedals
forward. Airborne it's a non-event and the stick will return to center
based on trim settings.
Don't give up on your pitch for the autopilot. Lots of recent discussion
about it regarding IFR flying, but while I am definitely a stick and rudder
guy as much as possible, the autopilot has made longer trips very pleasant
and less taxing allowing me to arrive more refreshed.
Marcus
40286
Posted: Sun Dec 06, 2009 7:32 pm Post subject: Stick centering |
Lew,
I appreciate your partner wanting to actively fly the plane
however safely flying the plane is also something to think about. I
Cessna 152 class airplane may not need an AP but this serious cross
country machine like this RV-10 does. Someone will fly this plane on
regular cross countries and having tools like automatically holding
altitude and heading is both a comfort and safety issue. Don't want it,
then don't use it. Reducing pilot workload comes in many forms and not
having to hold a plane within is couple hundred feet and on course for 4
hours and then be fresh enough for a difficult landing conditions can be
considered a safety issue. Auto pilots are also great for sightseeing,
sapping a photo, reaching for the jug of water or the urine bottle.
Without an AP you are have a statistically higher chance of taking a
swig out of the urine bottle. How about resale? I don't think anyone
wants to buy an RV-10 w/o and AP installed. I can think of many more
important reasons to add the AP to your build. I can't think of any to
not install one. They don't have to be $15K budget busters. My RV-6A had
a $1,700 AP driven by my Garmin 396 and it was the best thing that ever
happened to that plane. Don't ask me what the worst thing was...
Robin
speckter(at)comcast.net Guest
Posted: Mon Dec 07, 2009 6:46 am Post subject: Stick centering |
I too would question "what is the experience level" of your pilot? This is
what I would call a neutrally stable aircraft i.e. if you put it into a bank
it will stay there. A 152 is a positively stable aircraft i.e. it will
return to level flight after a while.
Other homebuilt aircraft are even more unstable than the 10. If your pilot
doesn't have experience in this type of flying I would advise some
transition training that specifically gets him to understand what type of
aircraft this is and how it flys.
I second the recommendation for an AP. It will reward you with all kinds of
benefits he as of now hasn't completely though through.
Gary Specketer
Posted: Mon Dec 07, 2009 7:18 am Post subject: Stick centering |
Just to reiterate experience...I had about 130 hours all in a 172....and no real good stick time for two years before flying my -10 I can honestly say now I am proficient at flying the airplane...For me that meant almost 25 hours of dual...by my choice..The AP should almost be part of the MEL. (some aircraft it is) if only for being a backup to, God forbid, spatial disorientation...
Phil.Perry(at)netapp.com Guest
Posted: Mon Dec 07, 2009 8:35 am Post subject: Stick centering |
Actually, springs have been used as a 'trim' function on a lot of
homebuilts. Varying the tension of the springs adjusts the 'center'
position of the stick, and hence the 'trim'. IMHO, it's crude, but
effective.
Far more elegant would be proper rigging coupled with remotely operated
trim servos to take care of CG shifts in flight. Better would be the
addition of an autopilot if only for temporary control of the airplane
(or for helping you out of a nasty situation such as a controlled 180),
and better yet .... both trim and autopilot. The better the rigging,
and smaller the trim movement, the more efficient and faster your
airplane will go.
Linn
Perry, Phil wrote:
The only time I've heard of springs being used in these light planes is
to help provide gradient forces with stick movement. Meaning that the
further you move the stick from center, the more pressure (feedback) it
applies against you. So it would be 0 at neutral and get stronger as
you move to the outer limits. The pressure of the springs should be
uniform in all directions.
Now the question is why would anyone do that?
The answer is to keep the pilot from putting too many G's on the
airframe. Some aircraft designs are very light on the controls and
provide very little feedback (or non-uniform feedback) in the terms of
stick forces. As a result it's very easy for a pilot to over control
the airplane and put too many G's on it without realizing what they're
really doing. The springs are provided to insert a simple form of
artificial feedback directly at the stick.
There have been a handful of airplanes out there who've required
springs. I would guess most are retrofit's following accidents of the
same type (I don't know), because I couldn't imagine designing a light
plane that needed the springs intentionally.
We're lucky to have a good airframe and control surface designer for the
RV-10.
Phil
Lew Gallagher
Posted: Mon Dec 07, 2009 4:20 pm Post subject: Re: Stick centering |
Thanks for the replies.
Phil, I think you nailed it closest, cuz when I passed on all the feedback to him, he responded that the cargo planes he flew in the AF and the Diamond he has been training in, have the artificial gradient resistance to help to not over steer. I really think that once he gets his cross training in a -10, he will be more comfortable.
On the AP issue, I don't fly and even I can see what an asset it is (see my response to Rob's post!). I'll keep pushing it!
Later, - Lew
Posted: Mon Dec 07, 2009 4:45 pm Post subject: Stick centering |
FYI......move the RV-10 stick 3 to 4 inches left or right and hold it you will be approaching 90 degrees of bank real quick and your brain won't even KNOW there's a spring there.....you fly this plane with a few fingers...not a fist full. and unless he flew the C-17...OMG...over steer? Well maybe he flew C-47.s. WTFDIK!!!
Kelly McMullen
Posted: Mon Dec 07, 2009 4:46 pm Post subject: Stick centering |
The main reason for the AP is for cross country use, where holding a
relatively sensitive stick would get old in a hurry. If he only plans
breakfast and hamburger runs in local area, then AP is not cost
effective. While I flew a plane without one for long cross countries
for years, you don't realize how fatiguing it is until later. You just
have to figure how to share the $5000 cost that will persuade him.
On Mon, Dec 7, 2009 at 5:20 PM, Lew Gallagher <lewgall(at)charter.net> wrote:
Later, - Lew
non-pilot
Painting done!
http://forums.matronics.com/viewtopic.php?p 76635#276635
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Mon Dec 07, 2009 5:04 pm Post subject: Stick centering |
Agreed. He'll never know it's missing because those forces are designed
into the airplane.
And I agree. WTFD(R)K??? LOL!!
Phil
