		Lew Gallagher
				 Posted: Sun Dec 06, 2009 7:01 am    Post subject: Stick centering |
				Hey Guys,
 Since I'm not a pilot, I'm asking this on behalf of my owner/pilot partner -- be gentle!
 He says this is the first plane he has seen that doesn't have a mechanism for bringing the stick back to center.  I.e. hands off, the plane should level out if trimmed correctly.   Keep in mind that he has not yet gone for his cross training in an RV-10, so this is all speculation.  Maybe in flight, it does center?
 I've read here about when "dialed in" the -10 flies itself, but it think that was in reference to AP discussions.  In spite of my strong encouragement that he should install an AP (after reading here about the advantages), he insists it's all about actively flying for him, not riding.
 So I guess the direct question is:  Without an AP installed, have others addressed this with springs, or whatever, or is it really not an issue?
 Thanks, - Lew
  _________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
		ricksked(at)embarqmail.co Guest
				 Posted: Sun Dec 06, 2009 7:33 am    Post subject: Stick centering |
				The AP adds some resistance to the system but doesn't hold the stick in position. When I remove my hand from the stick, if trimmed properly the aircraft continues to fly straight and level...I'm assuming the air pressures are keeping the control surfaces  in aerodynamic place I've never flown an aircraft with a spring return except the ones on my R/C transmitter Build it as designed it does work quite well
 Rick Sked
 Sent via BlackBerry by AT&T
		MauleDriver(at)nc.rr.com Guest
				 Posted: Sun Dec 06, 2009 9:23 am    Post subject: Stick centering |
				I don't thinks it's an issue.  Here's  the explanation that I have in my
 head  to understand what's happening-
 The aircraft we fly, when in flight, are positively stable in pitch.
 That is, once trimmed and then disturbed hands off, the aircraft will
 return to the trimmed state after a few oscillations.  This is
 accomplished in a variety of ways  that may include springs and weights
 in the control system.  But it doesn't have anything to do with the
 stick returning to a center.
 The same aircraft when in flight are not positively stable in roll.
 They may remain level if not disturbed in absolutely still air (no such
 thing).  Hands off, at some point, they will fall off in one direction
 or another and enter a spiral.   But that doesn't have anything to do
 with the stick returning to center either.
 Generally speaking, one of the neat things about experimental aircraft
 is that they can be less stable in certain ways than certified
 aircraft.  That often means less junk in the control system which means
 a more pleasant and responsive control experience.  But too little
 stability or too much responsiveness can mean trouble too.
 This is going to be interesting because there's a lot stuff to
 understand about stability - dynamic, static, longitudinal, lateral,
 convergent, divergent, etc. I only understand most of it when I'm
 staring at a text book.
 Lew Gallagher wrote:
  Hey Guys,
  Thanks, - Lew
  non-pilot
  Painting done!
  On with wiring and avionics.
  http://forums.matronics.com/viewtopic.php?p 76452#276452
				 Posted: Sun Dec 06, 2009 9:45 am    Post subject: Stick centering |
				Since I'm not flying mine ...... I don't think you'll need any 'spring
 trim'.  You have elevator trim available, and rudder trim can be as
 simple as a piece of wood taped to the rudder or aileron trailing edge.
   I'm going to have active rudder and aileron trim ..... a piece of hinge
 riveted to the trailing edge and driven by a model airplane servo.
 As to being 'dialed in' .... I think it's still referring to rigging
 ... which means all the stuff out in the air is really pointing in the
 correct direction, and in relation to each other.  So many things affect
 flying 'trim' so it's a fairly long process to tweak the surfaces so
 everything is aerodynamically correct.
 Linn
  <lewgall(at)charter.net>
  Hey Guys,
  not riding.
  an issue?
  Thanks, - Lew
  -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549
  Painting done! On with wiring and avionics.
		partner14
				 Posted: Sun Dec 06, 2009 10:51 am    Post subject: Stick centering |
				Hey Lew, Don here.....  I believe that actual "centering" would be of no hope for actually flying any aircraft on a distinct heading and altitude.  For every flight the wt & bal changes, and if that wasn't enough, the wt & bal changes during flight.  So say the stick returns to center,,,, the same center you'll have one day with a 250lb guy sitting next to you, and then the following day flying with yourself.  Or one day with no baggage and the next day with 100lbs.    Then what about fuel burn?  I suppose you could fly your heading based on fuel burn.... veering a little left, switch to the left tank for awhile.....
  I can't imagine anyone who was building a 10,,,,, for the reasons one would actually build a 10, and not install an AP.
  Although I was really leaning to rudder and aileron trim while building, now that I'm flying, I don't find much need for either one.  Plane flies almost perfect in the vast majority of conditions.... the rest of the time, it flies almost perfect!
  Ok, that's my 2cents
  Don McDonald
  New pilot, 90+ hours, and enjoying the %$&* out of it!
 --- On Sun, 12/6/09, Lew Gallagher <lewgall(at)charter.net> wrote:
 Subject: Stick centering
 Date: Sunday, December 6, 2009, 7:01 AM
  --> RV10-List message posted by: "Lew Gallagher" <lewgall(at)charter.net (lewgall(at)charter.net)>
 Hey Guys,
 Thanks, - Lew
 non-pilot
 Painting done!
 http://forums.matronics.com/viewtopic.php?pp; the Contribution link below to find out more "http://www.matronics.com/contribution" target=_blank>http://www.matronicsp;                   -Matt DrNavigator?RV10-List" target=_blank>http://www.matronics.com/Navigator?RV1bsp;            - MATRONICS WEB FORUMS -=====
40636 |
		coop85(at)verizon.net Guest
				 Posted: Sun Dec 06, 2009 1:33 pm    Post subject: Stick centering |
				Lew,
    I think the other messages may have answered your question, but the
 simple answer is airloads return the controls to neutral.  I don't know what
 your partner has been flying, but all the light general aviation airplanes
 I've ever flown don't have a spring centering system (with the exception of
 my Q-2 but it was a spring biased trim system so doesn't really count).  If
 you go out to any light Cessna or Piper and move the ailerons they will stay
 that way during preflight.  The elevator falls because of the weight.  The
 rudder may center but primarily due to springs that keep the rudder pedals
 forward.  Airborne it's a non-event and the stick will return to center
 based on trim settings.
 Don't give up on your pitch for the autopilot.  Lots of recent discussion
 about it regarding IFR flying, but while I am definitely a stick and rudder
 guy as much as possible, the autopilot has made longer trips very pleasant
 and less taxing allowing me to arrive more refreshed.
 Marcus
 40286
		robin1(at)mrmoisture.com Guest
				 Posted: Sun Dec 06, 2009 7:32 pm    Post subject: Stick centering |
				Lew,
 	I appreciate your partner wanting to actively fly the plane
 however safely flying the plane is also something to think about. I
 Cessna 152 class airplane may not need an AP but this serious cross
 country machine like this RV-10 does. Someone will fly this plane on
 regular cross countries and having tools like automatically holding
 altitude and heading is both a comfort and safety issue. Don't want it,
 then don't use it. Reducing pilot workload comes in many forms and not
 having to hold a plane within is couple hundred feet and on course for 4
 hours and then be fresh enough for a difficult landing conditions can be
 considered a safety issue. Auto pilots are also great for sightseeing,
 sapping a photo, reaching for the jug of water or the urine bottle.
 Without an AP you are have a statistically higher chance of taking a
 swig out of the urine bottle. How about resale? I don't think anyone
 wants to buy an RV-10 w/o and AP installed. I can think of many more
 important reasons to add the AP to your build. I can't think  of any to
 not install one. They don't have to be $15K budget busters. My RV-6A had
 a $1,700 AP driven by my Garmin 396 and it was the best thing that ever
 happened to that plane. Don't ask me what the worst thing was...
 Robin
		speckter(at)comcast.net Guest
				 Posted: Mon Dec 07, 2009 6:46 am    Post subject: Stick centering |
				I too would question "what is the experience level" of your pilot?  This is
 what I would call a neutrally stable aircraft i.e. if you put it into a bank
 it will stay there.  A 152 is a positively stable aircraft i.e. it will
 return to level flight after a while.
 Other homebuilt aircraft are even more unstable than the 10.  If your pilot
 doesn't have experience in this type of flying I would advise some
 transition training that specifically gets him to understand what type of
 aircraft this is and how it flys.
 I second the recommendation for an AP.  It will reward you with all kinds of
 benefits he as of now hasn't completely though through.
 Gary Specketer
				 Posted: Mon Dec 07, 2009 7:18 am    Post subject: Stick centering |
				Just to reiterate experience...I had about 130 hours all in a 172....and no real good stick time for two years before flying my -10 I can honestly say now I am proficient at flying the airplane...For me that meant almost 25 hours of dual...by my choice..The AP should almost be part of the MEL.  (some aircraft it is) if only for being a backup to, God forbid,  spatial disorientation...
		Phil.Perry(at)netapp.com Guest
				 Posted: Mon Dec 07, 2009 8:35 am    Post subject: Stick centering |
				Actually, springs have been used as a 'trim' function on a lot of
 homebuilts.  Varying the tension of the springs adjusts the 'center'
 position of the stick, and hence the 'trim'.  IMHO, it's crude, but
 effective.
 Far more elegant would be proper rigging coupled with remotely operated
 trim servos to take care of CG shifts in flight.  Better would be the
 addition of an autopilot if only for temporary control of the airplane
 (or for helping you out of a nasty situation such as a controlled 180),
 and better yet .... both trim and autopilot.  The better the rigging,
 and smaller the trim movement, the more efficient and faster your
 airplane will go.
 Linn
 Perry, Phil wrote:
  The only time I've heard of springs being used in these light planes is
  to help provide gradient forces with stick movement.  Meaning that the
  further you move the stick from center, the more pressure (feedback) it
  applies against you.  So it would be 0 at neutral and get stronger as
  you move to the outer limits.  The pressure of the springs should be
  uniform in all directions.
  Now the question is why would anyone do that?
  The answer is to keep the pilot from putting too many G's on the
  airframe.  Some aircraft designs are very light on the controls and
  provide very little feedback (or non-uniform feedback) in the terms of
  stick forces.  As a result it's very easy for a pilot to over control
  the airplane and put too many G's on it without realizing what they're
  really doing.  The springs are provided to insert a simple form of
  artificial feedback directly at the stick.
  There have been a handful of airplanes out there who've required
  springs.  I would guess most are retrofit's following accidents of the
  same type (I don't know), because I couldn't imagine designing a light
  plane that needed the springs intentionally.
  We're lucky to have a good airframe and control surface designer for the
  RV-10.
  Phil
		Lew Gallagher
				 Posted: Mon Dec 07, 2009 4:20 pm    Post subject: Re: Stick centering |
				Thanks for the replies.
 Phil, I think you nailed it closest, cuz when I passed on all the feedback to him, he responded that the cargo planes he flew in the AF and the Diamond he has been training in, have the artificial gradient resistance to help to not over steer.  I really think that once he gets his cross training in a -10, he will be more comfortable.
 On the AP issue, I don't fly and even I can see what an asset it is (see my response to Rob's post!).  I'll keep pushing it!
 Later, - Lew
				 Posted: Mon Dec 07, 2009 4:45 pm    Post subject: Stick centering |
				FYI......move the RV-10 stick 3 to 4 inches left or right and hold it you will be approaching 90 degrees of bank real quick and your brain won't even KNOW there's a spring there.....you fly this plane with a few fingers...not a fist full. and unless he flew the C-17...OMG...over steer? Well maybe he flew C-47.s. WTFDIK!!!
		Kelly McMullen
				 Posted: Mon Dec 07, 2009 4:46 pm    Post subject: Stick centering |
				The main reason for the AP is for cross country use, where holding a
 relatively sensitive stick would get old in a hurry. If he only plans
 breakfast and hamburger runs in local area, then AP is not cost
 effective. While I flew a plane without one for long cross countries
 for years, you don't realize how fatiguing it is until later. You just
 have to figure how to share the $5000 cost that will persuade him.
 On Mon, Dec 7, 2009 at 5:20 PM, Lew Gallagher <lewgall(at)charter.net> wrote:
  Later, - Lew
  non-pilot
  Painting done!
  http://forums.matronics.com/viewtopic.php?p 76635#276635
A&P/IA, EAA Tech Counselor
KCHD |
				 Posted: Mon Dec 07, 2009 5:04 pm    Post subject: Stick centering |
				Agreed.  He'll never know it's missing because those forces are designed
 into the airplane.
 And I agree.  WTFD(R)K??? LOL!!
 Phil
