carlossa52(at)gmail.com Guest
Posted: Thu Dec 10, 2009 7:02 pm Post subject: stuck |
This is embarrassing.
I am stuck. Literally. See pictures - this is an A6 pop rivet. It won't budge, in or out.
Access from the back is rather difficult, as the rear and front rib are already riveted. The A6 is one of the two last rivets in this station.
I can remove the rear rib, but that's my last option - and I still will have a stuck A6 after I remove the rear rib.
Suggestions?
Carlos
CH601-HD, plans
stuck
279.8 KB |
11219 Time(s) |
120.51 KB |
11219 Time(s) |
psm(at)att.net Guest
Posted: Thu Dec 10, 2009 7:20 pm Post subject: stuck |
Hi Carlos,
The only idea I have is to use a dremel cutoff wheel to cut the
middle of the rivet. Then either pliers or drill it out.
Paul
XL awaiting upgrade kit
At 07:01 PM 12/10/2009, you wrote:
| Quote: | I am stuck. Literally. See pictures - this is an A6 pop rivet. It
Larry Webber
Joined: 05 Jun 2008 Posts: 63 Location: West Kingston Rhode Island
Posted: Thu Dec 10, 2009 7:51 pm Post subject: stuck |
Hi Carlos get on the band saw Cmake a two pronged tapered wedge
from some scrap aluminum so that it fits snugly around and under the head of the stuck rivet first apply some wax around the rivet warm (not hot) with apropane torch C then tap wedge aggressively while still warm this is how i unstuck several a6 stainless rivs good luck
Larry Webber 601xl /corvair chugger
Date: Thu C 10 Dec 2009 22:01:36 -0500
Subject: stuck
To: zenith-list(at)matronics.com; zenith701801-list(at)matronics.com
I am stuck. Literally. See pictures - this is an A6 pop rivet. It won't budge C in or out.
Access from the back is rather difficult C as the rear and front rib are already riveted. The A6 is one of the two last rivets in this station.
I can remove the rear rib C but that's my last option - and I still will have a stuck A6 after I remove the rear rib.
Suggestions?
Carlos
CH601-HD C plans
stuck
Chat with Messenger straight from your Hotmail inbox. Check it out
_________________ how do you eat an elephant ? one bite at a time |
heatonhe36(at)msn.com Guest
Posted: Fri Dec 11, 2009 9:01 am Post subject: stuck |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Hi Carlos,
I would try to drive the center mandril out through the rivet, pull it through with pliers or use a small punch to get it out. Then you should be able to drill the rivet out or maybe twist it out with pliers. Just a thought.
Good luck
Herb Heaton
601XL, Plans
wjones(at)brazoriainet.co Guest
Posted: Fri Dec 11, 2009 10:12 am Post subject: stuck |
I use a spring loaded center punch to drive the rivet stub out. Lot less pressure than driving out with a hammer & punch .
leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Fri Dec 11, 2009 5:18 pm Post subject: Re: stuck |
Carlos,
Glad you got it unstuck. Maybe I'm not up on the latest info from Zenith, but I think that should be a solid rivet. The drawings I have dated Dec 9 state "INSTALL EXTRUSION WITH SOLID RIVETS, SAME DIAMETER AS ORIGINAL HOLE IN EACH LOCATION", and gives part numbers:
MS20470AD-6-15 and MS20470AD-5-10.
Dan
| carlossa52(at)gmail.com wrote: | This is embarrassing.
Suggestions?
Carlos
CH601-HD, plans
stuck |
_________________ Scratch building XL with Corvair Engine |
Posted: Fri Dec 11, 2009 7:15 pm Post subject: stuck |
Dan, this is a 601-HD - you might be thinking 601-XL...?
The A6 are used to hold four L angles against the centre wing spar.
These L angles reinforce the attachment of four nose ribs to the spar at the landing gear stations.
Here's a close up, bottom right in this picture:
http://zodiac.pcperfect.com/images/CWing/cwing12.jpg
In this picture, you can see the ribs in question: the two outer ones, on each side. Four ribs, 2 rivets on each one.
http://zodiac.pcperfect.com/images/CWing/cwing15.jpg
BTW, the pictures are from Don Honabach's project.
Carlos
CH601-HD, plans
2009/12/11 leinad <leinad(at)hughes.net (leinad(at)hughes.net)>
[quote] --> Zenith-List message posted by: "leinad" <leinad(at)hughes.net (leinad(at)hughes.net)>
Carlos,
Glad you go it unstuck. Maybe I'm not up on the latest info from Zenith, but I think that should be a solid rivet. The drawings I have dated Dec 9 state "INSTALL EXTRUSION WITH SOLID RIVETS, SAME DIAMETER AS ORIGINAL HOLE IN EACH LOCATION", and gives part numbers:
Dan
