b.carl@sympatico.ca
Posted: Tue Jan 12, 2010 2:53 pm Post subject: Filter Removal Tool |
List
I've collected a half dozen filter tools during the years but for the last
ten years I always reach for one that is made of a short piece of square
tubing attached to a loop of nylon strapping. The square tube fits perfectly
over a 1/2" ratchet and can be used with an extension. I use it to install
and remove filters on the plane and cars, and if careful, without damage. I
always witness mark and date the filter with a permanent marker.
I'm pretty sure I bought it at Princess Auto or Canadian Tire.
Carl
R912ul
| Quote: | During the course of a normal oil change I was trying to get the right
tool to loosen my oil filter. It is a tight fit in there. I was told that
they can be a bear to remove and also told there is no reason to safety
wire the filter.(> I now safety wire the oil filter with a large clamp
around it and also torque mark it.
I know I have mentioned this before but for new members you might want to
keep a check on yours.
Now I go at least a full turn and no more than 1 1/4 turns and never see
leaks.
Getting the old filter off is a struggle no way around it. The regular
wrench that fits onto the end of the filter isn't enough (it just strips)
even when I was tightening it down only 3/4 turn.
I have to use the pliars-style wrench from Pep-boys that destroys the
filter to get it loose (with strong support underneath the filter with the
other hand to prevent strong downward bending pressure on the oil
pump).....
LS
rampil
Posted: Tue Jan 12, 2010 3:25 pm Post subject: Re: Filter Removal Tool |
The filter should not be so difficult to unscrew, as the Rotax
manual specifies that it should be turned only a partial turn past
finger tight.
pjeffers(at)talktalk.net Guest
Posted: Wed Jan 13, 2010 1:47 am Post subject: Filter Removal Tool |
Posted: Wed Jan 13, 2010 1:50 am Post subject: Filter Removal Tool |
The latest instruction re tightening the filter is to screw it on till the rubber seal makes contact with the housing and then to tighten a further 270 degrees.
Pete
