		b.carl@sympatico.ca
				 Posted: Tue Jan 12, 2010 2:53 pm    Post subject: Filter Removal Tool |
				List
 I've collected a half dozen filter tools during the years but for the last
 ten years I always reach for one that is made of a short piece of square
 tubing attached to a loop of nylon strapping. The square tube fits perfectly
 over a 1/2" ratchet and can be used with an extension. I use it to install
 and remove filters on the plane and cars, and if careful, without damage. I
 always witness mark and date the filter with a permanent marker.
 I'm pretty sure I bought it at Princess Auto or Canadian Tire.
 Carl
 R912ul
  	  | Quote: | 	 		    During the course of a normal oil change I was trying to get the right
  tool to loosen my oil filter. It is a tight fit in there. I was told that
  they can be a bear to remove and also told there is no reason to safety
  wire the filter.(>  I now safety wire the oil filter with a large clamp
  around it and also torque mark it.
   I know I have mentioned this before but for new members you might want to
  keep a check on yours.
  Now I go at least a full turn and no more than 1 1/4 turns and never see
  leaks.
  Getting the old filter off is a struggle no way around it. The regular
  wrench that fits onto the end of the filter isn't enough (it just strips)
  even when I was tightening it down only 3/4 turn.
  I have to use the pliars-style wrench from Pep-boys that destroys the
  filter to get it loose (with strong support underneath the filter with the
  other hand to prevent strong downward bending pressure on the oil
  pump).....
  LS
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		rampil
				 Posted: Tue Jan 12, 2010 3:25 pm    Post subject: Re: Filter Removal Tool |
				The filter should not be so difficult to unscrew, as the Rotax
 manual specifies that it should be turned only a partial turn past
 finger tight.
		pjeffers(at)talktalk.net Guest
				 Posted: Wed Jan 13, 2010 1:47 am    Post subject: Filter Removal Tool |
				 Posted: Wed Jan 13, 2010 1:50 am    Post subject: Filter Removal Tool |
				The latest instruction re tightening the filter is to screw it on till the rubber seal makes contact with the housing and then to tighten a further 270 degrees.
  Pete
