		dlm46007(at)cox.net Guest
				 Posted: Fri Jan 15, 2010 2:55 pm    Post subject: Door safety latch |
				Fortunately the "mandatory " nature of this does not apply nor  does the compliance timeframe. undoubtedly there will be builders who will offer  the obligatory "yes sir three bags full" but this should be considered for each  particular situation and aircraft. After all, the beauty of this is that  the builder is the manufacturer. You did specify that you or your organization  was the manufacturer on the airworthiness forms.
    From: owner-rv10-list-server(at)matronics.com  [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott  Schmidt
 Sent: Friday, January 15, 2010 3:31 PM
 To:  rv10-list(at)matronics.com
 Subject: Re: Re: Door safety  latch
  (I  posted this at VAF, I also am not very impressed)
 I am going to have to  think about this SB before installing.
 It would have been nice to talk with  the whole community of RV-10 builders before launching this SB. I do not feel it  is necessary and is just an extra device that if not installed properly will not  function correctly I would suspect. If you drive to root cause on the door issue  it comes down to people not installing the warning lights, and not properly  completing their pre-flight.
 I don't want to offend anyone that has had  their door come off but I have heard many stories about the doors that have come  off, especially the one that hit the horizontal stabilizer and there were many  other factors involved with that incident. Most of them will admit that the door  was never fully closed before taking off. All of them should have been prevented  through proper preflight and checklists.
 If the current system is  installed correctly, the indicator lights installed, it is very unlikely and  almost impossible to have a problem. The only way for the door to open is if you  squeezed the interlock on the handle and opened the door. I know there are many  RV-10's flying around with no indicator lights on the doors and I don't  understand why. They work so great. On my doors if the pin moves 1/8" away from  fully closed the lights come on.
 My preflight includes the following:
 -Confirm door handle has locked into place
 -Check all four corners for  any obvious gap
 -Check door ajar light
 -Before takeoff, check all warning  lights (includes the door ajar light)
 If the proximity sensors are  installed correctly it is IMPOSSIBLE not to have each of the four pins in their  proper spot. If one is caught outside the cabin (which has happened to me when  passengers try to shut the door before I get there) the light is on and there is  an obvious gap.
 Another concern I read about is the handle not locking  into place. If yours does not, take it apart and fix it. Once mine snaps into  place it will not rotate and is very safe.
 I may find that this is a  great addition after I have played with someones door that has this new addition  but I won't be adding this to my experimental plane anytime soon. I worry about  emergencies and having someone on the outside who is trying to get me and my  family out try to understand that you have to lift the little handle, push the  button and rotate the handle.
 I agree that the door can be improved but  this is a very poor band-aid. I don't want to get flamed here, I just want new  builders to understand that the doors are not unsafe and if installed correctly  with the warning lights and properly locking handles they are safe. New builders  have this perception that the doors need a 100% redesign, and I don't want  anyone to be scared off.
 Scott  Schmidtscottmschmidt(at)yahoo.com
 Sent: Fri, January 15, 2010 3:01:38  PM
 --> RV10-List message posted by: Linn Walters  <pitts_pilot(at)bellsouth.net (pitts_pilot(at)bellsouth.net)>
 I  find it rather ludicrous to build an efficient airplane only to hang the handle  and a speed brake on the outside of the door.  IMHO, it's a poor solution  at best.
 Linn
 Jim Berry wrote:
		ricksked(at)cox.net Guest
				 Posted: Fri Jan 15, 2010 3:05 pm    Post subject: Door safety latch |
				I agree totally Scott,  most people aren't familiar with root cause analysis...If you have been involved with any sort of "incident" this type of investigation, many times shows weak spots not necessarily the result of a poor design but in the operation of the designed equipment or training. If many doors were just flying the RV-10 that showed a weakness in the product then the root cause would lean towards product defect. Could the latch system be designed better? Maybe...I go back to my own also near miss....flying with a friend and fellow pilot with many hours of fighter time failed to engage the aft pin...previously I didn't think I could do that on my RV, but he did it and I immediately saw his door locked light on as we taxied out...system worked but he never saw it...I did...and when I said check your door he was dumbfounded...said he never saw the light although it was bright and shining right there above the MFD. We need to quit expecting our equipment to be fool proof, use the checklist, don't assume Sierra and check and double check. Someone once told me their thoughts on time management that applies pretty close to flying..." You need a system.,.all systems are pretty good...unless you don't use them"Rick S
 Sent via BlackBerry by AT&TFrom:  Scott Schmidt <scottmschmidt(at)yahoo.com>
 Date: Fri, 15 Jan 2010 14:30:38 -0800 (PST)
 Subject: Re: RV10-List: Re: Door safety latch
 Linn
 Jim Berry wrote:
 [quote] --> RV10-List message posted by: "Jim Berry" <jimberry(at)qwest.net (jimberry(at)qwest.net)>
  Attached are photos of the new door safety latch, which I think are self explanatory. It is my understanding that everyone with a finish kit will have their parts and drawings by the end of next week. The only thing I would consider changing is to increase the angle between the legs of the springs that you will fabricate. My personal preference would be for a stronger spring loading of the latch. I don't  have a way to scan the large format drawings, but will try to photograph them and get them posted later today.
  Jim Berry
  40482
  N15JB
  http://forums.matronics.com/viewtopic.php?p=281668#281668
  http://forums.matronics.com//files/img_0441_836.jpg
  http://forums.matronics.com//files/img_0440_915.jpg
  http://forums.matronics.com//files/img_0439_172.jpg
		jdriggs49(at)msn.com Guest
		jcumins(at)jcis.net Guest
				 Posted: Fri Jan 15, 2010 3:59 pm    Post subject: Door safety latch |
				Deems that's a great idea.
 John G. Cumins
				Scott;
  I have to admit I've been thinking about this SB as  well. I was actually waiting for Tim to chime in and was quite glad to see  your response.
  Thanks for taking time to give that feedback.
  Pascal
  Sent: Friday, January 15, 2010 2:30 PM
 Linn
		ddddsp1(at)juno.com Guest
				 Posted: Fri Jan 15, 2010 4:17 pm    Post subject: Door safety latch |
				Beings I dont have an outside passenger door handle anyway.............guess I will not have an outside safety latch on the passenger door either.
 Let's get creative with the looks of the outside latch...............think I will make it look like the arm on a Vegas slot machine.  Every time you pull it down to get in you are taking a gamble OR by getting in and flyng the RV10 you have hit the Jackpot of all 4 place planes!
 Dean
 805HL     "400 Hours with a goal of 500 by 2011"
 ____________________________________________________________
 Weight Loss Program
 Best Weight Loss Program - Click Here!
				 Posted: Fri Jan 15, 2010 4:36 pm    Post subject: Door safety latch |
				I fully agree with  Scott and his post.  I would add to the reasons the doors may be opening is poor construction and/or amending the door pin measurements to make the pins not protrude out so far and scratch the paint when shut accidently.  Look at some of the GAPS in these doors on some finished planes and the way the door seal is attached.
 These planes are not aerobatic either.  Doors made per the plans and flown per the specs will not accidently come open during flight.  I am sure LIABILITY is driving this SB and I am also sure the RV community will engineer a much better fix (if needed) than what is proposed.
 My 2 cents to a senseless issue.
 DEAN
 Weight Loss Program
		Jim Berry
				 Posted: Fri Jan 15, 2010 4:43 pm    Post subject: Re: Door safety latch |
				The beauty of being experimental is that we can each decide whether we want to install the safety latch; although your insurance company might disagree if you had a door opening incident.
 Deems idea of a grab strap would be very easy to incorporate. Since the latch kit includes an aluminum sheet on both sides of the fiberglass, it would make a good hard point to mount a handle.
 When the door handle is opened, the latch allows the bottom of the door to open approximately 1/2 to 3/4 inch.
 Someone commented that the latch cannot be opened from the inside. Not true, just lift the latch.
 The exterior latch is 1/8 inch thick, and requires very little force to open. It could probably be smallified top to bottom without compromising strength or function.
 Someone with CNC capabilities could make a much more attractive version of the latch.
 Jim Berry
 40482
 N15JB
				 Posted: Fri Jan 15, 2010 4:48 pm    Post subject: Door safety latch |
				There is no way I’m putting that piece of Frankenstein crap on my aircraft.  Jeeez…WTF is Van’s thinking except putting this out to cover their ass. I think a bungee cord between the two door handles inside would work much better. Sorry but I’ll check the lights, check the doors and continue on. So far my policy and procedures have worked fine and have proven that too!!
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLM
  Sent: Friday, January 15, 2010 2:53 PM
  Subject: RE: Re: Door safety latch
 Scott Schmidt
  Linn
  > Jim Berry
  > 40482
  > N15JB
  > http://www.matronics.com/Navigator?RV10-List Web href="http://forums.matronics.com">http://forums.matronics.com -Matt href="http://www.matronics.com/contribution">http://www.matronics.com/c===========
		jeff(at)westcottpress.com Guest
				 Posted: Fri Jan 15, 2010 4:55 pm    Post subject: Door safety latch |
				Anyone thinking of integrating the interior aspect of the latch with
 the fore/aft movement of the door pin and omit the exterior aspect of
 the latch all together?
 Jeff Carpenter
 40304
 Suddenly happy my doors aren't quite finished yet
		partner14
				 Posted: Fri Jan 15, 2010 6:32 pm    Post subject: Door safety latch |
				Rick, I totally agree with you....  although my Van's idiot lights are not functioning.  Van's sent out a number of micro switches which were ass backwards.  I tried everything to get them to work, then just gave up on them.  Then Van's sends out a bulletin saying if you received a specific part numbered micro switch, let them know and they'd send out the correct ones.  Well, in the meantime, my pre-takeoff procedure was, and is, to personally verify that each door is totally closed, and locked.... pretty simple... I do it EVERYTIME.  After a very short time, it's a total habit.  That coupled with the fact that  I threw away the Van's plastic/nylon receivers and replaced them with the billeted replacements, leaves me feeling very confident with my RV10 doors.
  My 4cents worth....
  Don McDonald
 --- On Fri, 1/15/10, Rick <ricksked(at)cox.net> wrote:
 Date: Friday, January 15, 2010, 4:46 PM
 Scott Schmidt
 Linn
 Jim Berry wrote:
 get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List
 =nofollow>http://forums.matronics.com
 blank rel=nofollow>http://www.matronics.com/contribution
40636 |
		ronrvbuilder(at)bigpond.c Guest
				 Posted: Fri Jan 15, 2010 9:02 pm    Post subject: Door safety latch |
				I would be really interested in hearing from anyone with a background in insurance.  Yes we are the builder, and only airworthiness bodies may be able to ground aircraft.  But if you intentionally fail to comply with an instruction from the kit supplier and a door departs in flight, what are the chances of a successful claim??
 Ron
  Sent: Saturday, 16 January 2010 9:53 AM
 Scott Schmidt
  Linn
  > Jim Berry
  > 40482
  > N15JB
    [quote][b]  --> http://forums.matronics.com -Matt href="http://www.matronics.com/contribution">http://www.matronics.com/c===========
		flysrv10(at)gmail.com Guest
				 Posted: Sat Jan 16, 2010 4:14 am    Post subject: Door safety latch |
				I am not in the insurance business but I can tell you that I had a prompt, fair and no-fault settlement with my insurance company and my insurance rate has decreased every year!
 I not trying to influence  anyone's decision on installing the SB but I am with Scott - I in't doing it!
 He has described the circumstance under which my door departed and the functionality of the warning lights very accurately.  His check list also looks exactly like mine.
 Do not fly the plane without the warning lights, don't skip lines on your check list and if you want "belts and suspenders"  instal the latch.
 One last thing:  Let's not wake up the insurance companies and have them tell us what we need to do with our planes.
 Do not Archive.
 On Jan 15, 2010, at 10:28 PM, Ron McGann wrote:
  	  | Quote: | 	 		  I would be really interested in hearing from anyone with a background in insurance.  Yes we are the builder, and only airworthiness bodies may be able to ground aircraft.  But if you intentionally fail to comply with an instruction from the kit supplier and a door departs in flight, what are the chances of a successful claim??
 Ron
 From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLM
 From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt
 Subject: Re: Re: Door safety latch(I posted this at VAF, I also am not very impressed)
 Scott Schmidt
 scottmschmidt(at)yahoo.com (scottmschmidt(at)yahoo.com)
 From: Linn Walters <pitts_pilot(at)bellsouth.net (pitts_pilot(at)bellsouth.net)>
 Linn
 Jim Berry wrote:
 [url=http://www.matronics.com/Navigator?RV10-List]
  	  | Quote: | 	 		  [b]
 style="color: blue; text-decoration: underline; ">http://www.matronics.com/Navigator?RV10-List
 blue; text-decoration: underline; ">http://forums.matronics.com
 style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
  | 	  [/b]
