Kelly McMullen
Posted: Sat Jan 16, 2010 6:44 am Post subject: 10 SB |
I for one am disappointed with this design. When I first saw the
description I was hoping the hook was operated by the door handle, and
had motion 90 degrees from what the pictures show. That would have
been a major improvement. Unfortunately, this isn't any better than
the solution I saw at Copperstate of installing a second handle inside
and out, that operated a bottom of door latch.
I'm not clear from the pictures, is the tab on the outside always
straight out, recessed when latched? or what? I sure hope one of our
fine CNC parts suppliers can engineer a better solution. Most of the
ideas that put another arm on the door handle to operate some sort of
bottom latch seem promising, perhaps difficult to make work cleanly.
On Sat, Jan 16, 2010 at 7:26 AM, orchidman <gary(at)wingscc.com> wrote:
Quote: |
sean(at)stephensville.com wrote:
> Mailing list only members enjoy the quoted portion. Each his own.
But not 10 million copies of the SB from Vans. [Laughing]
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
http://forums.matronics.com/viewtopic.php?p 81793#281793
A&P/IA, EAA Tech Counselor
KCHD |
Jim Berry
Posted: Sat Jan 16, 2010 10:24 am Post subject: Re: 10 SB |
Kelly,
The tab on the outside moves up and down in the slot, but does not retract at any time. The slot can be made smaller in both dimensions than as shown in Van's pictures. Mine is just big enough to get the job done.
If you want a prettier safety latch, look at the rear door latch on the new Diamond DA40.
Guys, the SB threads have been great. I have not seen such rancor since primer wars.
Jim Berry
40482
N15JB
luis(at)cristabelle.net Guest
Posted: Sat Jan 16, 2010 10:47 am Post subject: 10 SB |
How about VANS redesigning the door too make the doorsafer tobegin
with. If more doors fall off with this added latch (hypotheticaly),
what's next more SBs andmore "add-on" hardware? Anyone should be able
to lock a door! Time to redesign it!
Sent from my iPod
On Jan 16, 2010, at 1:24 PM, "Jim Berry" <jimberry(at)qwest.net> wrote:
Quote: |
Kelly,
job done.
since primer wars.
Jim Berry
40482
N15JB
http://forums.matronics.com/viewtopic.php?p 81813#281813
Posted: Sat Jan 16, 2010 11:12 am Post subject: 10 SB |
Luis;
No offense but the doors are built by the builder themselves. Many have
already made their own mods to hinges, the doors themselves, etc to the
doors and with proper planning (confirm passengers know how to close the
door) there really isn't an issue with the doors. The problem is the plastic
that Vans gives as hinges are simply not the right solution, the doors
naturally have an issue with the rear not closing correctly as the door is
pulled from the front more than the rear.
When you get to this point you'll know that the hinges are the first thing
that Vans should have modified.
Pascal
Sent: Saturday, January 16, 2010 10:47 AM
Subject: Re: Re: 10 SB
Quote: |
How about VANS redesigning the door too make the doorsafer tobegin with.
If more doors fall off with this added latch (hypotheticaly), what's next
more SBs andmore "add-on" hardware? Anyone should be able to lock a
Sent from my iPod
> Kelly,
> done.
> new Diamond DA40.
> primer wars.
> Jim Berry
> 40482
> N15JB
scottmschmidt(at)yahoo.co Guest
Posted: Sat Jan 16, 2010 11:32 am Post subject: 10 SB |
I suggest that all RV-10 builders and flyers with serial numbers write Van's at info(at)vansaircraft.com
I have done the same and have asked Van's to retract the Service Bulletin and offer the latch as an additional and optional latch just as the indicator lights were offered.
I want to summarize what I have heard here.
Issues with the door will arise if:
-Poor door construction causing a bow during flight (Construction error) (Fix: Re-build door or add Van's center latch)
-Pins are not inserted far enough into the aluminum frame (Construction error) (Fix: Re-build pins to extend into aluminum frame)
-Door handle interlock is not engaged (Construction error and/or pilot error) (Fix: Ensure handles are locked before flight, possible rebuild of interlock)
-Door pins were locked outside of cabin (Pilot error)(Fix: Add door check to checklist)
I am fine with Van's offering this as an optional kit but when they say on the service bulletin that it is mandatory, I have a problem.
This is 100% different from the previous SB where we added stiffeners to the vertical stabilizer and empenage.
I want everyone to fly safe and keep our insurance as low as possible, I don't see this as the solution though.
We need to take personal responsibility to build to the highest quality and use our checklists thoroughly.
Any system that is put into place (such as our checklists) is never fixed with more protection devices, system only work and are improved through training and discipline.
This solution is like adding a fixed gear to the bottom of a retractable landing gear aircraft. It will be there just in case you don't put the gear down.
The warnings lights and center latch should be optional as 100% safe flight can be accomplished with the stock system. I do feel there are may pilots flying safely without even the lights because of their training and checklist discipline. The experimental category will always have construction issues and must accept personal responsibility for that and not burden the whole fleet with the quality shortcomings of the few.
I want everyone to fly safe, have fun and explore this world with their planes and I appreciate Van's offering a system that solves a problem that a few of RV-10's have with the doors bowing as a total replacement of the door is very expensive.
Again, please write Van's and ask for the removal of this SB and make it optional.
Scott Schmidtscottmschmidt(at)yahoo.com
Sent: Sat, January 16, 2010 11:24:03 AM
Subject: Re: 10 SB
dlm46007(at)cox.net Guest
Posted: Sat Jan 16, 2010 11:39 am Post subject: 10 SB |
You mean you don't want a belt, suspenders, elasticized waist and special
Velcro adhesive? I measured my pins this morning and the OD of the pins
range from .436 to .438; theoretically they should be .4375. In 225 hours
they may have worn 15/10000 of an inch; I probably will replace them at
engine overhaul. Otherwise after door closure, I just touch each of them
twice before each departure.
Posted: Sat Jan 16, 2010 12:10 pm Post subject: 10 SB |
once again Scott I agree with your suggestion. Thinking through the letter and it will go out today, this isn't a solution it’s a bandaid. With the negative feedback seen it is obvious most of us have no intention of doing this mod so why force me as a builder to "have to".
Sent: Saturday, January 16, 2010 11:31 AM
I suggest that all RV-10 builders and flyers with serial numbers write Van's at info(at)vansaircraft.com (info(at)vansaircraft.com)
Subject: Re: 10 SB
bcondrey
Posted: Sat Jan 16, 2010 12:24 pm Post subject: 10 SB |
Scott,
I’m just now catching up on this but agree with all points below and have already sent an email to Van’s. I would also add (and did in my email) that many builders have also added door pin guides (IFLYRV10.com) which have conical receivers for the pins to address the potential issue of misalignment when the door is initially closed. Further, these increase the surface area that the pins contact which prevents the wallowing out of the hole in the door frame that some have experienced. Even with these guides installed though, the pins should extend through the actual door frame.
My point was also that the SB is fine, just don’t make it mandatory.
Bob
N442PM (flying with no door latching issues)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt
Sent: Saturday, January 16, 2010 12:31 PM
Scott Schmidt
Posted: Sat Jan 16, 2010 1:31 pm Post subject: 10 SB |
Pascal,
If vans plastic hinges are crappy, vans should upgrade the part. If
this is a concern from the factory, then why not fix it so new
assemblies (finish kits) reflect a safer door. Maybe they need to
consult with cesna on securing the doors. Ranting here.... I don't
know how much the builder has to create while constructing the doors.
I'm just gathering tools right now. But really, why not fix it from
the getgo.
Sent from my iPod
On Jan 16, 2010, at 2:09 PM, "Pascal" <rv10builder(at)verizon.net> wrote:
Quote: |
Luis;
have already made their own mods to hinges, the doors themselves,
etc to the doors and with proper planning (confirm passengers know
how to close the door) there really isn't an issue with the doors.
The problem is the plastic that Vans gives as hinges are simply not
the right solution, the doors naturally have an issue with the rear
not closing correctly as the door is pulled from the front more than
the rear.
thing that Vans should have modified.
Pascal
> <luis(at)cristabelle.net>
> (hypotheticaly), what's next more SBs andmore "add-on" hardware?
> Anyone should be able to lock a door! Time to redesign it!
> Sent from my iPod
>> Kelly,
>> since primer wars.
>> Jim Berry
>> 40482
>> N15JB
ricksked(at)cox.net Guest
Posted: Sat Jan 16, 2010 1:46 pm Post subject: 10 SB |
Man do you have a lot coming!!
Sent via BlackBerry by AT&T
bcondrey
Posted: Sat Jan 16, 2010 2:01 pm Post subject: 10 SB |
Plastic hinges? Parts WD-1018 & WD-1019 are steel - only part that is "plastic" are the blocks in the door for guiding the pins (C-1009 and C-1017) and the thin parts (C-1010 Cabin Pin Blocks) that cover the holes in the door frames. FWIW, the C-1010 parts are best replaced with the aluminum guide blocks supplied by IFLYRV10.com and others. These are supplied with bullet shaped pins that thread into the stock door pins (and the sensor magnet is built in instead of having to epoxy into the stock pin). The opening on the guide blocks have conical openings to guide the pins into place. This is the single best safety mod for the doors that exists.
There's a lot of hype about the doors and while they certainly could have been designed better, they are functional as long as the builder takes the time to get the doors built properly and the latching mechanism aligned properly. Finally, checking for doors properly latched is a standard preflight check for even most certified planes! Granted, a Cherokee or Piper door probably won't fly off if unlatched, but that's missing my point.
Besides, if you install the SB latch you'll have matching "fugly" with the interior door handle!
Bob
RV-10 N442PM (flying)
Posted: Sat Jan 16, 2010 2:41 pm Post subject: 10 SB |
Yea, don't remind me. But can't wait at the same time. It's nice to
see trials and tribulations. By the time I get to the doors, it will
be a non issue.
Sent from my iPod
kearney
Posted: Sat Jan 16, 2010 3:12 pm Post subject: 10 SB |
Bob
I can say with absolute certainty that a Piper door won't fly off if
unlatched. In fact, the off field landing checklist has the door being
unlatched and opened so it doesn't jam in case of an accident.
There are also aftermarket interior handles that remove the "fugly" from the
inside. After spending all this time getting Steve Deniri's billet handles
mounted, I now am being asked to install something that looks like it was
made by the Orcs of Mordor!
I would prefer to pay some $$$ to get better hinges (ala Cirrus) if they
could be made to work on a -10. Then door openings become the non event they
should be.
We can put all kinds of systems / proceduers etc in place but the reality is
that the VAN's door design is sub par. Even the most disciplined military
pilots make mistakes so why would we expect recreational GA pilots to
achieve perfection.
Quote: | From an esthetic point of view, I am disappointed. Surely Van's knows how
much effort builders are putting into their planes to make them look every
bit as polished and then some as "manufactured" a/c. Today I walked by an
SR22 and admired how nice its doors looked. Then I winched when I realized
that the SB has me cutting an unfinished hole into my door and then having a
stub of aluminium poking out. This seems like a Rube Goldberg answer to a
poor door design. At the very least they could have made a kit that gives a
more "finished" look.
I wish VAN's would bite the bullet and come up with a more "professional"
looking solution that deals with the real problem - a poor locking design.
The fact that every -10 builder (at least the ones I know of) are tossing
the delrin door blocks in favour solid AL door guides speaks volumes.
Just my $0.02
Les
Posted: Sat Jan 16, 2010 4:03 pm Post subject: 10 SB |
My mistake I did mean the Cabin pin blocks. Thanks for the correction. We
agree on every point I replaced the pins and blocks with Steve's Aluminum
as well.
My point is Vans should upgrade that piece and modify the plans with some
mods- easy ones before forcing a mandatory SB on some boat anchor concept, I
think there are other better ways. Write the letter Scott encourages us to
do. Scott at Vans obviously listened to one (1) builder ask to have the SB
plans put on the web, I think if many wrote with a request to change the SB
Vans might very well do so. Just offer a solution- like remove mandatory as
many have already made safety changes that do not need this SB.. replace
cheap parts with better parts, find ways to assure the rear closes
better..etc..
Pascal
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Sent: Saturday, January 16, 2010 2:00 PM
Subject: RE: Re: 10 SB
exists.
point.
Bob
Posted: Sat Jan 16, 2010 4:06 pm Post subject: 10 SB |
much of what you see here will be a non issue as most have better solutions
for parts, just make sure you take notes to not buy the landing gear parts-
specifically the front nose axles, rims.. all from Matco directly.. there's
more but I leave that to you to discover what they are as much is being
improved by Vans, FWF hoses being a start..
Take your time and enjoy the journey I spent months accumulating tools
before I ever started, took a Sportair class too.
Pascal
Sent: Saturday, January 16, 2010 2:40 PM
Yea, don't remind me. But can't wait at the same time. It's nice to see
trials and tribulations. By the time I get to the doors, it will be a
non issue.
Sent from my iPod
dmaib(at)mac.com Guest
Posted: Sat Jan 16, 2010 6:01 pm Post subject: 10 SB |
AD's for certified airplanes almost always contain language allowing
for "alternate means of compliance" and that is just how I am
treating this SB. I installed the iflyrv10 aluminum door pin blocks,
increased the travel of the rods, installed the door warning system,
and it plays beautifully through Vertical Power and gives me a master
warning, a separate pilot or co-pilot door message, and a warning
tone in the headsets. I consider that a robust alternate means of
compliance and will keep the kit, and perhaps install it if I ever
decide to sell the airplane. That's the end of the story as far as I
am concerned.
David Maib
40559
Flying
correction. We agree on every point I replaced the pins and blocks
with Steve's Aluminum as well.
some mods- easy ones before forcing a mandatory SB on some boat
anchor concept, I think there are other better ways. Write the
letter Scott encourages us to do. Scott at Vans obviously listened to
one (1) builder ask to have the SB plans put on the web, I think if
many wrote with a request to change the SB Vans might very well do
so. Just offer a solution- like remove mandatory as many have already
made safety changes that do not need this SB.. replace cheap parts
with better parts, find ways to assure the rear closes better..etc..
Pascal
exists.
Bob
Tim Olson
Posted: Sun Jan 17, 2010 9:41 am Post subject: 10 SB |
I've been following the SB thread since it started, deciding not
to get into it right away. It seems that usually people start
going off on tangents about how crappy the door design is, or
how various door designs would be superior...never mind that
without some major work/time/expense there's no real way any
builder will have an improved door design. The kit "is what it
is", and if you really want the pains of major door redesign,
then hey, I'm all for it, but I believe that when it comes right
down to reality, most of you would rather just finally have a
nice flying RV-10 to fly, for a reasonable price, in a minimal
amount of years of built time. Any departure from the plans
usually adds time and expense, and a door redesign would involve
both, and only lots of testing and time would end up proving
if it were even a successful modification.
Then it comes to handles, latches, locks, and all that stuff.
Sure, there are some nice flush latches. No, Van's didn't
design in door locks. Yeah, you can buy add-on internal
handles. In reality, I don't really view ANY of these things
as significant items. They're almost entirely cosmetic,
and many of those cosmetics may mean something to various
individuals, but others may not care a bit. For me, I'm
perfectly happy with the looks of the internal door handle.
I don't mind the external handle, although I've seen nicer
than mine. And, I don't mind the door not locking. I maintain
that I'd much prefer a door ALARM system to a door LOCK system,
because I just want to scare them away BEFORE they rip
my fiberglass apart on the door, or break the plexi on
my window. But that again is just a personal perspective.
None of these add-ons are really significant.
The exception to these insignificant add-ons is the addition
of the rivethead/iflyrv10.com door pin receivers made out
of aluminum. I really wish that during my build, I would
have had the opportunity to have these, and know all the things
we know today. I think a new builder is crazy not to build
those out of aluminum. I'm not necessarily convinced that
for someone like me, with completed doors, it's an easy
upgrade to try to cut my pin ends and thread in the magnetic
ones, so I haven't gone that route. I'm also not a huge
fan of permanent or electro magnets in the doors, as I know
that I've heard enough about how sensitive good magnetometers
are to know that I'd rather avoid magnets if possible. My
doors have glassed over screws on the outside, and I just
haven't wanted to tackle any pin modifications right now.
I really HAVE been meaning to order the aluminum guides
though. I'd love to have those, and I've lost enough to
chipped paint and fiberglass from that rear pin. My
original idea was an embedded stainless striker plate to
protect the paint, and some day I'd love to be motivated
enough to fix that.
From a functional standpoint I think the doors are fine.
They work, and I've flown now over 585 hours with them and
am not disappointed at all, other than the rear pins that
have chipped my paint. From a safety standpoint, I know
my pins go THROUGH the metal door frame, and I know that
when I latch the door all the way, it's a definite lock,
and I can't rotate my lever at all. So once I button my
family into the plane and inspect the door gaps, I know
that we're not going to lose the door.
My plane was doing it's first flight just before Van's
came out with the door warning lights. I still have the
bag of hardware on the bench, awaiting my installation.
I've read Scott's comments about how EVERYONE should
have warning lights. I can't disagree. I think warning
lights are a great idea. I also like Vic's idea of
adding a throttle position sensor to them so that they
don't light up when you're at low power for ground taxi...
because you don't want to become complacent. Personally
though, I feel that my extra-diligent operation of the
doors is REINFORCED by my lack of lights. I know a lot
about a lot of incidents that happen. People tend to
tell me when they hear things. I hadn't heard about the
recent one a couple weeks ago though. Anyway, there have
been enough departed doors that I share the concern deeply
that other builders have. But, I feel that the concern
is not for the doors....it's for the PILOTS. If you build
a door per original plans, and inspect it properly before
flight, and have pins that extend properly, you will NOT
lose a door. If I had lights, and started to look for
the lights every time in lieu of a door gap inspection,
I would become complacent and reliant on that circuitry.
Yes, you can make those light systems pretty bulletproof,
and perfectly aligned and activated...but you can't take
a sloppy pilot checklist who's rushing through his preflight
while trying to race against...well, any of the pressures
that push us, and force him to look at the lights. That
is NOT to say the lights aren't a good idea. But they
are NOT an acceptable substitute for a good door gap
inspection either. We know what happens to these doors if
they're not latched, so nothing short of a perfect
inspection is acceptable. If you give a perfect inspection,
then any and all hardware additions really, truly,
aren't necessary. They're all band-aids against poor
pilot awareness. But, for the record, I do think
the lights are a good idea. I actually have a to-do item
on my calendar that I look at weekly, to order a door
alarm system and once I find the right system, I plan
to install it with the door pin sensors and lights to
provide a loud horn alarm that I can engage with a key
FOB, as a theft deterrent, with the side benefit of having
door latch indicator lights.
Now on to the new SB. I agree, it shouldn't be mandatory.
It would have been nice to have them engage the RV-10
ownership for an acceptable fix, but they didn't. I agree
that the latch is ugly, especially from the outside.
I'm pretty confident that I won't be putting it in, at least
as-delivered. I don't want that rectangular tab outside
and the open slot for water entry any more than many people
do. I don't think it's a bad idea though, either. I think
it's not truly a NECESSARY addition, but it is a safety
device, and therefore it may prevent some operational issues
that are pilot induced, so I actually support those who feel
that it's necessary. I say GO FOR IT. If you like that
"feel good" addition to the door latching, great. I agree
that it should NOT be a mandatory SB...especially since
there are alternate methods to accomplish the same thing that
may actually look/work better and be far more visually
acceptable at the same time. Regardless, I don't think
I plan to install that particular design as delivered. I
would be more inclined to perhaps leave the slot on the
door, but NOT put the tab on the outside. Think about this
for a second, for all you people who want door locks....
Envision the same mechanism, but with just the slot.
through the slot you stick a long allen-key type key
rod. Inside the latch is a hole that this key fits
in. So, when you come up to the plane and want to
open the door, you insert the key and tip the latch.
What is the downside? Well, if you're unconscious
in the plane after a crash, rescuers can't open that
latch. But, if they can open the door handle, do you
REALLY think that one single latch is going to prevent
them from getting to you, considering how weak the
door attachment is anyway? I highly doubt it. A screwdriver
jammed in the door gap so they could open it enough to
rip the door off is about all it would take. Yeah, maybe
not perfect. You don't like the idea? I don't blame
you....I'd rather have no center latch at all.
Or how about this....you make the latch not just spring
loaded, but lock-openable from the inside. So now you
can have the "key" function as described above, but as
part of an emergency checklist you take the opportunity
to disengage that lock. Why worry about disengaging it...
the door pins will hold the door anyway. So you disengage
the lock, then do your emergency landing.
Or, take it another step further....leave an external
operating latch mechanism, but change it to a button of
some sort that has added mechanics to operate the latch.
I would be much more likely to leave a button on the outside
of my door than that square tab.
Still, none of those ideas really turn me on. I still
think that a properly latched door that is diligently
inspected, is not a worry. My final idea is one that
I've been bouncing around in my own head. I picture
attacking it from the other side...the bottom. How about
a door latch pin, L-shaped rod, that is built in to the
sidewall of the airframe by your seat. This pin can be
manually lifted, inserting the pin through the bottom
of the door. To reinforce the door, you drill a hole and
make a fiberglass hard point in the door at that spot.
So you lift the pin, it goes into the door bottom, and
then you fold the "L" tab of the pin to the side so it
isn't sticking out at you....maybe even add a machined
block into that sidewall that has 2 L-shaped recesses,
where it can recess slightly in the locked and unlocked
position. Again, this latch is only activated from inside
the cockpit, preventing rescuers from unlocking that
lock....but again, I'm SURE you could kick that door out
if that were the only pin, and I'm SURE that they could
rip it off from the outside if they needed to....and
that's in the much smaller chance that you have an
actual survivable crash....the chances are higher that
you'll be a sloppy pilot and lose the door. But, during
any portion of flight where you worry about off-airport
landings... (for instance, as I'm flying over water,
enroute to the Bahamas), you just pull that pin to the
un-latched position. You don't NEED that latch to be
secured, if the rest of the door is secured. In fact,
if you just TESTED that latch before flight, it would
PROVE your pins are secured on the door sides, and you
probably don't even need to leave the door center latch
in place. But, if you can JUST remember that this latch
is something you need to open before an emergency landing,
then it would be a fine method of compliance, and I
bet you could hide it visually better than most other
method.
I've also liked Seano's mechanical methods of adding a
3rd pin, operated by the latch. For people just starting
the build, I would actually think that if this issue
is one you're passionate about, then THAT is probably your
BEST way to deal with it. I'd LOVE to have that option
be one that an already built-and-painted door could have
added, but I doubt that's possible. I'm not obviously
passionate enough about it to rip open my door and build
such a thing, but for a new builder, hey, get him to
give you the drawings and spend some time on it...you
can avoid this ugly-a$$ latch that the SB calls for if you
do.
So the door stuff is an argument I really don't care to dive
in too deeply to. I think it all comes down to the pilot.
I think there are many good ways to prevent the problem
even with a stupid pilot. But to date, I'm not finding
any good ways to really fix the issue mechanically, in an
ideal way, on an already painted RV-10....so, I maintain
my added diligence. I have no big worries. I have 585
happy hours with the design as it is now. Can it be done
better? Sure. If I were building my doors today, would
I do it better? SURE! Is the difference in comfort level
worth me tearing it all apart now? Nope. I just want
to end up with those aluminum guides, and an alarm
system some day, and I'll be plenty satisfied. If I
add a 3rd pin now, it'll probably be through the bottom,
as I described.
Oh, and don't worry too much about me selling my plane
and having to implement the SB per plans...I don't plan
on selling.
Tim Olson - RV-10 N104CD
Posted: Sun Jan 17, 2010 11:51 am Post subject: 10 SB |
Tim, I have been thinking the exact same thing about a latch in the center that can only be engaged from inside the cockpit.
It would still require a high level of checklist discipline. I agree with you on the lock, if they want in, they will get in.
I find that a cover is plenty good (out of sight out of mind) and if I ever go to Mexico or the Baja my plan is to just take off the outside door handles.
I am getting the sense that this SB is a CYA for Van's more than anything from some of the comments here, VAF and personal e-mails.
Again, that is disappointing to me. From a great solution standpoint on a scale from 1-10 I give this solution a 1 or 2.
Oh well, I think a 10 can be achieved for the same cost as the proposed.
All I would hope for is the verbiage on the SB to change from:
Required Action: Install Door Safety Latch to Required Action: Optional Door Safety Latch
Time of Compliance: Before Further Flight to Time of Compliance: Optional
I do believe some great ideas and great solutions will and are coming out of this so this probably I won't take up any more of my time and I will start coming up with some ideas that we all can share. There are a ton of super smart and talented people on this list.
I just can't wait to see what comes out of Goeff's camp. I am expecting a voice activited with a thumb print sensor. And from Tim I am looking for an iPhone app that both opens and closes the doors and has a built in "Door Ajar" alarm that is displayed on the iPhone screen.
N104XP
675 Safe Hours
Sent: Sun, January 17, 2010 10:39:47 AM
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
enough to fix that.
method.
do.
better?
Posted: Sun Jan 17, 2010 1:03 pm Post subject: 10 SB |
I just realized that Van's has a "Letters and Notices" section which is where the RV-10 door indicator lights are.
This is where this center latch belongs. That would move it completely out of the SB section.
http://www.vansaircraft.com/public/notices.htm
Sent: Sun, January 17, 2010 12:49:41 PM
N104XP
675 Safe Hours
enough to fix that.
method.
do.
better?
gengrumpy(at)aol.com Guest
Posted: Sun Jan 17, 2010 1:30 pm Post subject: 10 SB |
I have just written Van's to support Scott's suggestion.
Remember that SBs are optional in the FAA's eyes, not mandatory.
And a previous post on keeping this in our hands rather than letting some insurance adjuster get their hand in the mix is good advice.
I'm waiting for a more elegant solution for retrofit from some of our excellent CNC engineers!!
grumpy
On Jan 16, 2010, at 1:31 PM, Scott Schmidt wrote:
Quote: | I suggest that all RV-10 builders and flyers with serial numbers write Van's at info(at)vansaircraft.com (info(at)vansaircraft.com)
Scott Schmidtscottmschmidt(at)yahoo.com (scottmschmidt(at)yahoo.com)
From: Jim Berry <jimberry(at)qwest.net (jimberry(at)qwest.net)>
Subject: Re: 10 SB
Quote: |
tp://www.matronics.com/Navigator?RV10-List
nics.com
w.matronics.com/contribution
= [quote][b]
