				 Posted: Thu Feb 04, 2010 7:27 pm    Post subject: Loose Bushing - Was Proper Technique to Tighten Nose   Wheel |
				As long as you have the nose up ..... measure the side breakout force at
 the wheel axle.  I'm guessing that the 'break-in wear' has loosened up
 your original setting.
 Linn
 Rick wrote:
  I use my tow bar, never tried to do it without because the nose wheel wants
  to turn where I don't want it! Looking forward to Robins video, I only
  recently picked up the dreaded shimmy, I might add it crept in, not all the
  sudden...going to follow Scott's recommendation and balance the nose wheel
  this weekend. I really don't like shoving on my spinner cowl to align the
  aircraft while putting it in the hangar...that's why I have the tow bar..
  Rick
		ricksked(at)cox.net Guest
				 Posted: Thu Feb 04, 2010 8:10 pm    Post subject: Loose Bushing - Was Proper Technique to Tighten Nose   Wheel |
				I've adjusted it three times...even relocated the cotter pin hole one flat over...it stays close but with the added hole it hits right at 25 lbs
 Sent via BlackBerry by AT&T
				 Posted: Fri Feb 05, 2010 7:40 am    Post subject: Loose Bushing - Was Proper Technique to Tighten Nose   Wheel |
				Robin Marks wrote:
  Linn, I don't know how to access remaining bow. They look like two BV
  washers to me
 As long as they look like two BV washers, then they're not compressed
 flat.  If they were flat, they'd look like plain washers.  The BV
 washers when installed outside to outside will look like the fork isn't
 tightened ....... space between the fork washers and the BV washers.
 I've seen them squished flat, all stacked back to belly ..... you name it.
  	  | Quote: | 	 		   Rick, I only use my tow bar to get the plane in and out of my tight,
  narrow, rusty walled LA hangar. Yuck. Pushing the plane in and out of my
  larger hangar I use the prop and can easily maneuver the plane. I never
  place force on the spinner.
 Someday when the plane is left in the care of an FBO, the lineman WILL
 move it and he'll use the spinner.  It's best to make it easy for him
 (or her) to move it by hand without a towbar.
 Linn
  	  | Quote: | 	 		   To all re: the video. Be forewarned It's me holding a heavy flashlight
  between my shoulder and chin under the engine while jiggling the bushing
  with one hand and probably holding the video recorder too close for
  proper focus in the other hand. This is more Felini than Kubrick (I just
  watched Clockwork Orange)
  Robin
				 Posted: Fri Feb 05, 2010 4:06 pm    Post subject: Loose Bushing - Was Proper Technique to Tighten Nose   Wheel |
				Here is the video I promised:
 http://www.youtube.com/watch?v=EmT38rDenwA
 Robin
		Jim Berry
				 Posted: Fri Feb 05, 2010 9:23 pm    Post subject: Loose Bushing - Was Proper Technique to Tighten Nose   Wheel |
				That's quite a bit of slop, any idea what may have caused that wear on the
 bushing or the inner portion of the mount? IIRC it was a nice snug fit when
 originally installed. Do you think may a side load condition? I would think
 the wheel would caster to prevent that.  Got me thinking. Gotta jack it up
 and see now...
				 Posted: Sat Feb 06, 2010 3:31 pm    Post subject: Loose Bushing - Was Proper Technique to Tighten Nose   Wheel |
				At this point my thinking is that nothing changed the dimensions of the
 busing or mount. We were probably focusing so much on placing tension on
 compressing the gear leg that we must have overlooked the slop. Add a
 little grease and the fit seems acceptably tight (for a while). Oh well,
 one custom bushing later and all is well.
 I plan to test fly once these storms pass.
 Robin
