Posted: Thu Feb 04, 2010 7:27 pm Post subject: Loose Bushing - Was Proper Technique to Tighten Nose Wheel |
As long as you have the nose up ..... measure the side breakout force at
the wheel axle. I'm guessing that the 'break-in wear' has loosened up
your original setting.
Linn
Rick wrote:
I use my tow bar, never tried to do it without because the nose wheel wants
to turn where I don't want it! Looking forward to Robins video, I only
recently picked up the dreaded shimmy, I might add it crept in, not all the
sudden...going to follow Scott's recommendation and balance the nose wheel
this weekend. I really don't like shoving on my spinner cowl to align the
aircraft while putting it in the hangar...that's why I have the tow bar..
Rick
ricksked(at)cox.net Guest
Posted: Thu Feb 04, 2010 8:10 pm Post subject: Loose Bushing - Was Proper Technique to Tighten Nose Wheel |
I've adjusted it three times...even relocated the cotter pin hole one flat over...it stays close but with the added hole it hits right at 25 lbs
Sent via BlackBerry by AT&T
Posted: Fri Feb 05, 2010 7:40 am Post subject: Loose Bushing - Was Proper Technique to Tighten Nose Wheel |
Robin Marks wrote:
Linn, I don't know how to access remaining bow. They look like two BV
washers to me
As long as they look like two BV washers, then they're not compressed
flat. If they were flat, they'd look like plain washers. The BV
washers when installed outside to outside will look like the fork isn't
tightened ....... space between the fork washers and the BV washers.
I've seen them squished flat, all stacked back to belly ..... you name it.
| Quote: | Rick, I only use my tow bar to get the plane in and out of my tight,
narrow, rusty walled LA hangar. Yuck. Pushing the plane in and out of my
larger hangar I use the prop and can easily maneuver the plane. I never
place force on the spinner.
Someday when the plane is left in the care of an FBO, the lineman WILL
move it and he'll use the spinner. It's best to make it easy for him
(or her) to move it by hand without a towbar.
Linn
| Quote: | To all re: the video. Be forewarned It's me holding a heavy flashlight
between my shoulder and chin under the engine while jiggling the bushing
with one hand and probably holding the video recorder too close for
proper focus in the other hand. This is more Felini than Kubrick (I just
watched Clockwork Orange)
Robin
robin1(at)mrmoisture.com Guest
Posted: Fri Feb 05, 2010 4:06 pm Post subject: Loose Bushing - Was Proper Technique to Tighten Nose Wheel |
Here is the video I promised:
http://www.youtube.com/watch?v=EmT38rDenwA
Robin
Jim Berry
Posted: Fri Feb 05, 2010 9:23 pm Post subject: Loose Bushing - Was Proper Technique to Tighten Nose Wheel |
That's quite a bit of slop, any idea what may have caused that wear on the
bushing or the inner portion of the mount? IIRC it was a nice snug fit when
originally installed. Do you think may a side load condition? I would think
the wheel would caster to prevent that. Got me thinking. Gotta jack it up
and see now...
Posted: Sat Feb 06, 2010 3:31 pm Post subject: Loose Bushing - Was Proper Technique to Tighten Nose Wheel |
At this point my thinking is that nothing changed the dimensions of the
busing or mount. We were probably focusing so much on placing tension on
compressing the gear leg that we must have overlooked the slop. Add a
little grease and the fit seems acceptably tight (for a while). Oh well,
one custom bushing later and all is well.
I plan to test fly once these storms pass.
Robin
