		luis(at)cristabelle.net Guest
				 Posted: Fri Feb 05, 2010 12:43 pm    Post subject: Torque Wrench |
				How soon is the torque wrench needed and what size is needed?
 thanks
 Luis
 On Jan 31, 2010, at 12:03 AM, Michael Kraus wrote:
  	  | Quote: | 	 		  I have a MT, but not flying yet.  Bought it because it is smoooooth.....  Wish I hadn't because it makes taking the lower cowl off a biotch.....  Since the blended airfoil Hartzell is faster and makes the cowl infinitely easier to get off, I wish I'd have purchased it....
 That is just my opinion.....
 -Mike
 On Jan 30, 2010, at 9:54 PM, Roxanne and Mike Lefever <roxianmike(at)msn.com (roxianmike(at)msn.com)> wrote:
  	  | Quote: | 	 		   Anyone on the list purchase the three blade MT and if so what is the opinion of this set up versus the Hartzell which is about 50%more expensive?
		jeff(at)westcottpress.com Guest
				 Posted: Fri Feb 05, 2010 2:08 pm    Post subject: Torque Wrench |
				Hi Luis,
 You'll need to torque the counter balance weight on the rudder, but that can be done later... you get in to much more significant use of the wrench on the wings/fuel tanks and a painful amount when joining the fuselage halves.
 A ratchet style wrench, 1/4" or 1/2" drive measuring in inch lbs from Craftsman suffers a little bit for accuracy, but you'll have to monkey around quite a bit with the more accurate beam style wrench to access the nuts when joining the spar pass-throughs.  I'm sure Snap-On has the perfect tool.  I'm also sure I can't afford it.
 Jeff Carpenter
 40304
 On Feb 5, 2010, at 12:42 PM, Luis wrote:
  	  | Quote: | 	 		  How soon is the torque wrench needed and what size is needed?
 thanks
 Luis
 -Mike
		Bob Turner
				 Posted: Fri Feb 05, 2010 6:22 pm    Post subject: Re: Torque Wrench |
				Smaller is better. A foot-lb wrench is nearly useless. AN3 bolts only go to 25 inch pounds. I suggest a 1/4" drive, inch pound one. It is easy enough to check their calibration.
  _________________ Bob Turner
RV-10 QB |
		johngoodman
				 Posted: Sat Feb 06, 2010 7:04 am    Post subject: Re: Torque Wrench |
				Luis,
 Definitely go for a 1/4" drive that measures in inch-pounds. I use mine a lot, while my 3/8" drive I've only used once or twice. A 1/2" drive is virtually useless for our kind of work, except maybe the engine.
 You can probably find a decent one on ebay:
 http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1311&_nkw=torque+wrench&_sacat=See-All-Categories
 Hope the link works,
 John
  _________________ #40572 Phase One complete in 2011 |
		AirMike
				 Posted: Sat Feb 06, 2010 11:16 pm    Post subject: Torque Wrench |
				You will be using it a lot, so you might as well get it now. The 1/4" drive is the most used, but as you move to final assembly you need the others sizes also. Since you are literally betting your life on it's measurement get a good one that is calibrated. Otherwise buy a good used one that is calibrated or get it calibrated. Cleveland tools
  ( cleavelandtoolstore.com )
  sells a very good CDI branded wrench  (calibrated) that is actually a snap-on wrench (identical) except for the logo. It is not cheap (about $189) but do you want to trust your torque values to a Harbor Freight wrench. Also a couple of tubes of torque lacquer, so that you do not forget what you worked on.
  _________________ See you OSH '18
Q/B - sold. |
		bwestfall
  Joined: 22 Oct 2008 Posts: 131 Location: Portland, OR
				 Posted: Sun Feb 07, 2010 8:55 am    Post subject: Torque Wrench |
				I'd second that.  The CDI brand torque wrenches work great.  The only thing
 I'd add it that you get the model that starts at 10 in/lbs instead of 20
 in/lbs.  AN3 nuts get tightened to 20-25 in/lbs and it best not to use a
 wrench right at the starting value.  I got a brand new cdi wrench on ebay
 for $89.  Deals can be had if you have the time to wait and look.
 -Ben
