luis(at)cristabelle.net Guest
Posted: Fri Feb 05, 2010 12:43 pm Post subject: Torque Wrench |
How soon is the torque wrench needed and what size is needed?
thanks
Luis
On Jan 31, 2010, at 12:03 AM, Michael Kraus wrote:
| Quote: | I have a MT, but not flying yet. Bought it because it is smoooooth..... Wish I hadn't because it makes taking the lower cowl off a biotch..... Since the blended airfoil Hartzell is faster and makes the cowl infinitely easier to get off, I wish I'd have purchased it....
That is just my opinion.....
-Mike
On Jan 30, 2010, at 9:54 PM, Roxanne and Mike Lefever <roxianmike(at)msn.com (roxianmike(at)msn.com)> wrote:
| Quote: | Anyone on the list purchase the three blade MT and if so what is the opinion of this set up versus the Hartzell which is about 50%more expensive?
jeff(at)westcottpress.com Guest
Posted: Fri Feb 05, 2010 2:08 pm Post subject: Torque Wrench |
Hi Luis,
You'll need to torque the counter balance weight on the rudder, but that can be done later... you get in to much more significant use of the wrench on the wings/fuel tanks and a painful amount when joining the fuselage halves.
A ratchet style wrench, 1/4" or 1/2" drive measuring in inch lbs from Craftsman suffers a little bit for accuracy, but you'll have to monkey around quite a bit with the more accurate beam style wrench to access the nuts when joining the spar pass-throughs. I'm sure Snap-On has the perfect tool. I'm also sure I can't afford it.
Jeff Carpenter
40304
On Feb 5, 2010, at 12:42 PM, Luis wrote:
| Quote: | How soon is the torque wrench needed and what size is needed?
thanks
Luis
-Mike
Bob Turner
Posted: Fri Feb 05, 2010 6:22 pm Post subject: Re: Torque Wrench |
Smaller is better. A foot-lb wrench is nearly useless. AN3 bolts only go to 25 inch pounds. I suggest a 1/4" drive, inch pound one. It is easy enough to check their calibration.
_________________ Bob Turner
RV-10 QB |
johngoodman
Posted: Sat Feb 06, 2010 7:04 am Post subject: Re: Torque Wrench |
Luis,
Definitely go for a 1/4" drive that measures in inch-pounds. I use mine a lot, while my 3/8" drive I've only used once or twice. A 1/2" drive is virtually useless for our kind of work, except maybe the engine.
You can probably find a decent one on ebay:
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1311&_nkw=torque+wrench&_sacat=See-All-Categories
Hope the link works,
AirMike
Posted: Sat Feb 06, 2010 11:16 pm Post subject: Torque Wrench |
You will be using it a lot, so you might as well get it now. The 1/4" drive is the most used, but as you move to final assembly you need the others sizes also. Since you are literally betting your life on it's measurement get a good one that is calibrated. Otherwise buy a good used one that is calibrated or get it calibrated. Cleveland tools
( cleavelandtoolstore.com )
sells a very good CDI branded wrench (calibrated) that is actually a snap-on wrench (identical) except for the logo. It is not cheap (about $189) but do you want to trust your torque values to a Harbor Freight wrench. Also a couple of tubes of torque lacquer, so that you do not forget what you worked on.
_________________ See you OSH '18
Q/B - sold. |
bwestfall
Posted: Sun Feb 07, 2010 8:55 am Post subject: Torque Wrench |
I'd second that. The CDI brand torque wrenches work great. The only thing
I'd add it that you get the model that starts at 10 in/lbs instead of 20
in/lbs. AN3 nuts get tightened to 20-25 in/lbs and it best not to use a
wrench right at the starting value. I got a brand new cdi wrench on ebay
for $89. Deals can be had if you have the time to wait and look.
-Ben
