		bw12345(at)sbcglobal.net Guest
				 Posted: Mon Feb 08, 2010 4:49 am    Post subject: Prop Position |
				On the 2200 I purchased used the prop is mounted in the 7 o'clock position.On my other engines it was mounted in the 10 o'clock position on compression so they could be hand prop-ed. Does it make a difference as I would like to have the option to hand prop&==
  |  | - The Matronics Jabiru-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Jabiru-List |
		Clive J
				 Posted: Mon Feb 08, 2010 5:23 am    Post subject: Prop Position |
				You won't hand prop start a Jabiru, unless it's spinning on a starter it
 won't produce a spark good enough apparently. Not like an impulse mag,
 it's just a dumb coil.
 The best place to mount the prop is 9 o'clock, this so it's out the way
 if it ever stops and you have to land it in a field.
 Regards, Clive
				 Posted: Mon Feb 08, 2010 6:54 am    Post subject: Prop Position |
				Thanks Clive
 BOB
		Jaba-who
  Joined: 17 Feb 2010 Posts: 4 Location: Cairns, Australia
				 Posted: Tue May 18, 2010 1:17 am    Post subject: Re: Prop Position |
				Yep.
 The Jabiru engine has to have the prop turning at about the instantaneous equivalent of about 750 rpm to fire. Not possible by hand I'm afraid.
		info(at)flylightning.net Guest
				 Posted: Tue May 18, 2010 4:44 am    Post subject: Prop Position |
				Not sure what that means but it does take 295RPM for the Magnetos to produce
 the field and discharge needed to fire.
 Nick
