Prop Position
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Jabiru-List
bw12345(at)sbcglobal.net
PostPosted: Mon Feb 08, 2010 4:49 am    Post subject: Prop Position Reply with quote
On the 2200 I purchased used the prop is mounted in the 7 o'clock position.On my other engines it was mounted in the 10 o'clock position on compression so they could be hand prop-ed. Does it make a difference as I would like to have the option to hand prop&==
- The Matronics Jabiru-List Email Forum -
http://www.matronics.com/Navigator?Jabiru-List
Clive J
PostPosted: Mon Feb 08, 2010 5:23 am    Post subject: Prop Position Reply with quote
You won't hand prop start a Jabiru, unless it's spinning on a starter it
won't produce a spark good enough apparently. Not like an impulse mag,
it's just a dumb coil.
The best place to mount the prop is 9 o'clock, this so it's out the way
if it ever stops and you have to land it in a field.
Regards, Clive
PostPosted: Mon Feb 08, 2010 6:54 am    Post subject: Prop Position Reply with quote
Thanks Clive
BOB
Jaba-who
PostPosted: Tue May 18, 2010 1:17 am    Post subject: Re: Prop Position Reply with quote
Yep.
The Jabiru engine has to have the prop turning at about the instantaneous equivalent of about 750 rpm to fire. Not possible by hand I'm afraid.
info(at)flylightning.net
PostPosted: Tue May 18, 2010 4:44 am    Post subject: Prop Position Reply with quote
Not sure what that means but it does take 295RPM for the Magnetos to produce
the field and discharge needed to fire.
Nick
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Jabiru-List All times are GMT - 8 Hours
