Posted: Sun Feb 07, 2010 7:05 pm Post subject: wiring |
What route did you take to get wiring back to the tail/rudder?
Linn
MauleDriver(at)nc.rr.com Guest
Posted: Sun Feb 07, 2010 7:21 pm Post subject: wiring |
Along one of the J-channels on the right side. Just lay the wire in
there and fasten with tie wraps through holes in the J-channel. I
believe that was how it was suggested in the Vans wiring plan.
Great game
Linn Walters wrote:
Linn
LarryRosen
Posted: Sun Feb 07, 2010 7:31 pm Post subject: wiring |
Pilot (left) side, 2nd J channel down from the longeron. laid the wire
in the channel and drilled #40 holes to tie the wire down with wax lace.
Larry Rosen
Linn Walters wrote:
Linn
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Ron B.
Posted: Mon Feb 08, 2010 5:33 pm Post subject: Re: wiring |
Exactly where I am now. I have an 18 ga, three wire shielded cable for strobes. Two wire 16 ga (I think) for tail light . Five wire non shielded 26 ga rudder trim servo. They all have to exit the fuselage and enter the rudder. I have a 1/4" hole that passes through the alum extrusion that the tie down eye bolt screws into. It's in between the two top mount bolts. I would like to enlarge the hole to accommodate the above mentioned wires but that's pushing things. What would you recommend?
Thanks Ron
LarryRosen
Posted: Mon Feb 08, 2010 8:12 pm Post subject: wiring |
The optional wire harness plans call out a 3/16" hole, 11/16" inboard
from the top left bolt that goes into the extrusion that the eye bolt
screws into. I have not yet drilled the hole, but it is off center and
I would assume that it misses the center of the extrusion where the eye
bolt goes into. There is also a note that a snap bushing is not
required, just shrink wrap the wires for protection.
Larry
Ron B. wrote:
Thanks Ron
http://forums.matronics.com/viewtopic.php?p 85519#285519
#40356
N205EN (reserved)
<http> |
Ron B.
Posted: Tue Feb 09, 2010 3:24 pm Post subject: Re: wiring |
Thanks Larry
The eye bolt does not go up into the extrusion that far so it does not become a problem. Weakening the extrusion is my only concern. With the extrusion a snap bushing would not snap into place. A alternative method of protection would have to be provided.
Ron
