				 Posted: Sun Feb 07, 2010 7:05 pm    Post subject: wiring |
				What route did you take to get wiring back to the tail/rudder?
 Linn
				 Posted: Sun Feb 07, 2010 7:21 pm    Post subject: wiring |
				Along one of the J-channels on the right side.  Just lay the wire in
 there and fasten with tie wraps through holes in the J-channel.  I
 believe that was how it was suggested in the Vans wiring plan.
 Great game
 Bill
 Linn Walters wrote:
  Linn
		LarryRosen
				 Posted: Sun Feb 07, 2010 7:31 pm    Post subject: wiring |
				Pilot (left) side, 2nd J channel down from the longeron.  laid the wire
 in the channel and drilled #40 holes to tie the wire down with wax lace.
 Larry Rosen
 Linn Walters wrote:
  Linn
  _________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
		Ron B.
				 Posted: Mon Feb 08, 2010 5:33 pm    Post subject: Re: wiring |
				Exactly where I am now. I have an 18 ga, three wire shielded cable for strobes. Two wire 16 ga (I think) for tail light . Five wire non shielded 26 ga rudder trim servo. They all have to exit the fuselage and enter the rudder. I have a 1/4" hole that passes through the alum extrusion that the tie down eye bolt screws into. It's in between the two top mount bolts. I would like to enlarge the hole to accommodate the above mentioned wires but that's pushing things. What would you recommend?
 Thanks Ron
		LarryRosen
				 Posted: Mon Feb 08, 2010 8:12 pm    Post subject: wiring |
				The optional wire harness plans call out a 3/16" hole, 11/16" inboard
 from the top left bolt that goes into the extrusion that the eye bolt
 screws into.  I have not yet drilled the hole, but it is off center and
 I would assume that it misses the center of the extrusion where the eye
 bolt goes into.  There is also a note that a snap bushing is not
 required, just shrink wrap the wires for protection.
 Larry
 Ron B. wrote:
  Thanks Ron
  http://forums.matronics.com/viewtopic.php?p 85519#285519
#40356
N205EN (reserved)
<http> |
		Ron B.
				 Posted: Tue Feb 09, 2010 3:24 pm    Post subject: Re: wiring |
				Thanks Larry
 The eye bolt does not go up into the extrusion that far so it does not become a problem. Weakening the extrusion is my only concern. With the extrusion a snap bushing would not snap into place. A alternative method of protection would have to be provided.
 Ron
