Jim Berry
Posted: Thu Mar 18, 2010 7:02 pm Post subject: Re: Finish Kit Question |
Get the wiring kit instructions for $10, but not the kit itself. Consider dropping the door handles, if you are going to upgrade to one of the after market options. Drop the engine baffle material and get the silicone stuff. If you are going to use the magneto key switch and two door locks combination, you can special order the same thing from ACS with three locks so you can lock both doors and baggage door.
Jim Berry
40482
rleffler
Posted: Thu Mar 18, 2010 7:08 pm Post subject: Finish Kit Question |
I’m getting ready to place the order for my finish kit. The following is what I’m looking to substitute in the kit.
1.00 UNW501.25 NOSE WHEEL W/BEARINGS ( getting Matco wheel)
2.00 VENT SV-10 VENT FRESH AIR (don’t need since I’m going to use the vents from Steinair)
1.00 RUBBER DOOR SEALX25' VA-198 DOOR SEAL ( using a different door seal)
2.00 C-1016 DOOR STRUT GAS STRUT FOR RV-10 (upgrading to the heavy duty strut)
1.00 U-1009 AXLE ( getting Matco axle)
Is there anything else that I’ve overlooked that I should substitute or source from another vendor?
_________________ Bob Leffler
N410BL - Phase I
ricksked(at)cox.net Guest
Posted: Thu Mar 18, 2010 10:16 pm Post subject: Finish Kit Question |
OP-37 should be out there for free somewhere save ten bucks if someone
has a copy...I posted it several times.
Rick
On Mar 18, 2010, at 11:02 PM, "Jim Berry" <jimberry(at)qwest.net> wrote:
baggage door.
Jim Berry
40482
http://forums.matronics.com/viewtopic.php?p=290821#290821
rleffler
Posted: Fri Mar 19, 2010 2:24 am Post subject: Finish Kit Question |
Thanks for the handle reminder. I already have the flush handles from
iflyrv10.com.
The other items are in the FWF, not the Finish kit, but I'll keep them in
mind. I'm implementing a VP-200 so most of these aren't applicable to my
installation.
N410BL - Phase I
conradb
Joined: 02 Jun 2008 Posts: 11 Location: warner robins, georgia
Posted: Fri Mar 19, 2010 5:19 am Post subject: Re: Finish Kit Question |
I too am just about to order the RV-10 Finishing kit from the Van's factory. Do you know what the kit contains or where there is itemized list of the Finishing Kit's contents. I would like to know what I will be getting.
_________________ Conrad Booze
P. O. Box 7028
Warner Robins, GA. 31095
(478)-335-4264
conradbooze@cox.net |
tsts4
Posted: Fri Mar 19, 2010 5:28 am Post subject: Re: Finish Kit Question |
Conrad,
Tim Olson has it posted on his site. Here's the link:
http://www.myrv10.com/tips/kits/index.html
_________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
LarryRosen
Posted: Fri Mar 19, 2010 5:51 am Post subject: Finish Kit Question |
You still need the NACA scoop. Stein sells the swivel eyeball air vent
that mounts to the scoop.
Larry Rosen
Bob Leffler wrote:
duty strut)
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Posted: Fri Mar 19, 2010 8:39 am Post subject: Finish Kit Question |
I have a copy ...... that I got from rick (I think)!!!
I'll post it when I fiond where I put it!
Linn
Rick wrote:
Rick
> baggage door.
> Jim Berry
> 40482
Posted: Fri Mar 19, 2010 9:51 am Post subject: Finish Kit Question |
As a reminder- when in doubt- look on Tim's site- he has everything- The
deal is people scan the plans and send to Tim to add to the RV-10 plans
link- as an example- anyone with the new FF-6 plans (newer than 2/24/2005)
please scan them and send to Tim to post I don't have a way of doing it or I
would have, The current version, on his site, shows the old "original"
plans with one exhaust. I have the newer two muffler exhaust, as most do. I
really like to have all the plans on pdf for reference.
In the meantime here is OP-37
http://www.myrv10.com/Plans/pdfs/Section_Wiring_Harness.pdf
Thanks!
Pascal
From: "Linn Walters" <pitts_pilot(at)bellsouth.net>
Sent: Friday, March 19, 2010 9:37 AM
Subject: Re: Re: Finish Kit Question
Linn
> Rick
>> Jim Berry
>> 40482
Tim Olson
Posted: Fri Mar 19, 2010 1:31 pm Post subject: Finish Kit Question |
Man, you really got me upset.
I'm going to close down that part of the site now.
Pascal wrote:
2/24/2005) please scan them and send to Tim to post I don't have a way
of doing it or I would have, The current version, on his site, shows
the old "original" plans with one exhaust. I have the newer two muffler
exhaust, as most do. I really like to have all the plans on pdf for
reference.
Thanks!
Pascal
> Linn
>> someone has a copy...I posted it several times.
>> Rick
>>> baggage door.
>>> Jim Berry
>>> 40482
>>> Read this topic online here:
Posted: Fri Mar 19, 2010 1:47 pm Post subject: Finish Kit Question |
My apologies, that link to Tim's site is not valid anymore.
Please disregard.
Pascal
Sent: Friday, March 19, 2010 10:50 AM
I would have, The current version, on his site, shows the old "original"
I really like to have all the plans on pdf for reference.
Thanks!
Pascal
> Linn
>> Rick
>>> Jim Berry
>>> 40482
stuewe
Posted: Sat Mar 20, 2010 6:40 am Post subject: Re: Finish Kit Question |
| Tim Olson wrote: | Man, you really got me upset.
Tim,
Obviously you are upset. Although I am not sure why. I do not want to upset you any further, but I do want to ask you to please reconsider shutting down the builder's section of your site. It was and could continue to be a great resource for those of us still following in your footsteps. There is some TERRIFIC info there. Please reconsider.
Stuewe
stuewe(at)gmail.com
Bob Turner
Posted: Sat Mar 20, 2010 4:47 pm Post subject: Re: Finish Kit Question |
Stuewe: I trust Tim was writing tongue in cheek.
Pascal: I bought my FFW kit at the end of last summer (2009). The exhaust instructions say, "...these instructions are for the old exhaust, not the one you received. But they go together similarly.." (!)
_________________ Bob Turner
RV-10 QB |
Kelly McMullen
Posted: Sat Mar 20, 2010 4:53 pm Post subject: Finish Kit Question |
I could be wrong, but I believe Tim wanted to limit access to the
plans pages to those that have registered with him with builder
numbers. So direct linking is not appropriate, if I understand
correctly...copy right issues, etc.
On Sat, Mar 20, 2010 at 6:47 PM, Bob Turner <bobturner(at)alum.rpi.edu> wrote:
Bob Turner
RV-10 QB
A&P/IA, EAA Tech Counselor
KCHD |
jeff(at)westcottpress.com Guest
Posted: Sat Mar 20, 2010 7:04 pm Post subject: Finish Kit Question |
It was not tongue in cheek... it's down.
On Mar 20, 2010, at 5:47 PM, Bob Turner wrote:
similarly.." (!)
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=291103#291103
Nick Nafsinger
Posted: Sun Mar 21, 2010 10:27 am Post subject: Re: Finish Kit Question |
I'm confused. Tim's plans have always been linked directly off his site, no login or such required. Did I miss why he is so upset?
Oh well, I guess he'll go in the same group with Checkoway as a good resource now gone.
Nick Nafsinger
40569, Flying. 50+ Hrs
_________________ RV-10 40569
Flying! |
