lcfitt(at)sbcglobal.net Guest
Posted: Sun Apr 18, 2010 9:40 am Post subject: N-number Inquiry |
I need a bit of advice.
I will be shortly in need of an N-number for my Model IV project and for some reason, the N-Number inquiry site just won't work for me. No matter what I put into the search fields, I get "No records found for your request please try again".
What am I doing wrong?
Lowell
Jimz
Posted: Sun Apr 18, 2010 10:02 am Post subject: N-number Inquiry |
I just went to this site http://registry.faa.gov/aircraftinquiry/ then to N-Number availability then I put in the info for numbers near my N number and it shows the one not taken. Hope this helps. Jim Series 5 0-200 21D MN.
nail13zg(at)centurytel.ne Guest
Posted: Sun Apr 18, 2010 10:48 am Post subject: N-number Inquiry |
Lowell
Sounds like you are asking the database to identify an aircraft assigned a specific number and you're getting back an answer that says there is no aircraft assigned that number. So it is available.
Trey Moran
N13ZG, still in construction
Sent: Sunday, April 18, 2010 11:29 AM
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Subject: N-number Inquiry
Lowell
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Posted: Sun Apr 18, 2010 11:43 am Post subject: N-number Inquiry |
Thanks for the replies. I have tried it both ways. Using the inquiry page, I input the trailing characters, for example SM then the starting range 1 and ending range 9 and get the unavailable message. By randomly submitting the numbers 115SM, I find it is available, but I can't find it on the availability page. This is over several weeks and with two different computers.
Lowell
Sent: Sunday, April 18, 2010 11:47 AM
Subject: Re: N-number Inquiry
Lowell
Trey Moran
Lowell
Posted: Sun Apr 18, 2010 11:58 am Post subject: N-number Inquiry |
Lowell,
Go to http://aircraft.faa.gov/e.gov/NN/. you can enter up to 5 proposed numbers.
Trey
Sent: Sunday, April 18, 2010 1:43 PM
Lowell
Lowell
Trey Moran
Lowell
Tom Jones
Posted: Sun Apr 18, 2010 12:23 pm Post subject: Re: N-number Inquiry |
Lowell, is this the page you are using?
Click on N Number
Enter the number you want.
One of two results will appear, "Assigned" or "Not Assigned/Reserved"
If "Not Assigned/Reserved" you will see the link to reserve it on line or by mail.
If you click the "On Line" option you will get a page with an option to request up to 5 numbers, Scroll all the way over to the right and fill in Just one of the five boxes with the number you want. That worked for me just now.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Jimz
Posted: Sun Apr 18, 2010 1:21 pm Post subject: N-number Inquiry |
Try 40 thru 90. All the low numbers are probably taken. Thats what I ran into when I got my number. Had to go to 44.
Posted: Sun Apr 18, 2010 4:22 pm Post subject: N-number Inquiry |
Ha!
Thanks, My simple mind said that if the starting range was 1 and the end was 9, I would get everything. Maybe everything was not what I really wanted.
Lowell
Sent: Sunday, April 18, 2010 2:19 PM
