		lcfitt(at)sbcglobal.net Guest
				 Posted: Sun Apr 18, 2010 9:40 am    Post subject: N-number Inquiry |
				I need a bit of advice.
  I will be shortly in need of an N-number for my Model IV  project and for some reason, the N-Number inquiry site just won't work for  me.  No matter what I put into the search fields, I get  "No records  found for your request please try again".
  What am I doing wrong?
  Lowell
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Jimz
				 Posted: Sun Apr 18, 2010 10:02 am    Post subject: N-number Inquiry |
				I just went to this site http://registry.faa.gov/aircraftinquiry/ then  to N-Number availability then I put in the info for numbers near my N number and  it shows the one not taken. Hope this helps.  Jim Series 5 0-200 21D  MN.
  [quote]   ---
		nail13zg(at)centurytel.ne Guest
				 Posted: Sun Apr 18, 2010 10:48 am    Post subject: N-number Inquiry |
				Lowell
  Sounds like you are asking the database to  identify an aircraft assigned a specific number and you're getting back an  answer that says there is no aircraft assigned that number. So it is  available.
  Trey Moran
  N13ZG, still in construction
  Sent: Sunday, April 18, 2010 11:29 AM
  To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
  Subject: N-number Inquiry
  Lowell
 href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
				 Posted: Sun Apr 18, 2010 11:43 am    Post subject: N-number Inquiry |
				Thanks for the replies.  I have tried it both  ways.  Using the inquiry page, I input the trailing characters, for example  SM then the starting range 1 and ending range 9 and get the unavailable  message.  By randomly submitting the numbers 115SM, I find it is available,  but I can't find it on the availability page.  This is over several weeks  and with two different computers.
  Lowell
  Sent: Sunday, April 18, 2010 11:47 AM
  Subject: Re: N-number Inquiry
  Lowell
  Trey Moran
  Lowell
				 Posted: Sun Apr 18, 2010 11:58 am    Post subject: N-number Inquiry |
				Lowell,
  Go to http://aircraft.faa.gov/e.gov/NN/.  you can enter up to 5 proposed numbers.
  Trey
  Sent: Sunday, April 18, 2010 1:43 PM
  Lowell
  Lowell
  Trey Moran
  Lowell
		Tom Jones
				 Posted: Sun Apr 18, 2010 12:23 pm    Post subject: Re: N-number Inquiry |
				Lowell, is this the page you are using?
 Click on N Number
 Enter the number you want.
 One of two results will appear, "Assigned" or "Not Assigned/Reserved"
 If "Not Assigned/Reserved" you will see the link to reserve it on line or by mail.
 If you click the "On Line" option you will get a page with an option to request up to 5 numbers,  Scroll all the way over to the right and fill in Just one of the five boxes with the number you want.  That worked for me just now.
  _________________ Tom Jones
Classic IV
Ellensburg, WA |
		Jimz
				 Posted: Sun Apr 18, 2010 1:21 pm    Post subject: N-number Inquiry |
				Try 40 thru 90. All the low numbers are probably taken. Thats  what I ran into when I got my number. Had to go to 44.
  [quote]   ---
				 Posted: Sun Apr 18, 2010 4:22 pm    Post subject: N-number Inquiry |
				Ha!
  Thanks,  My simple mind said that if the starting  range was 1 and the end was 9, I would get everything.  Maybe everything  was not what I really wanted.
  Lowell
  Sent: Sunday, April 18, 2010 2:19 PM
  [quote]   ---
