Posted: Tue Apr 27, 2010 9:09 am Post subject: Europa stall warner |
With the benign stall characteristics of the PH-DIY and plenty of
natural warning before stalling, a stall warner is not really necessary.
But I had already installed the stall warner before the plane was
finished, so I decided to adjust it anyway.
After I adjusted the Europa stall warner to 6 knots above the stall, I
noticed that the stall warner warns when I'm parked at the ground.
Technically this is correct of course, a non flying airplane is
permanently in a stall condition, but is it supposed to work this way?
Frans
zwakie
terrys(at)cisco.com Guest
Posted: Tue Apr 27, 2010 12:17 pm Post subject: Europa stall warner |
Hi Frans,
Ours did that as well, so we adjusted the sensitivity until it stopped
beeping on the ground. It still gave us the in-flight margin we had
originally set it for. I suspect the stall 'speed' is more a function
of the placement of the hole in the wing than the sensitivity
adjustment.
Terry Seaver
A135
Posted: Tue Apr 27, 2010 3:45 pm Post subject: Europa stall warner |
Frans
Do you have stall strips fitted? You should have a stall warner if you don't. Their setting will also affect the stall, sounds like yours are well adjusted.
If you don't have them, rain or bug contamination could have a bad effect on stall behavior so be careful and don't assume anything is constant.
Graham
Sent: Tuesday, 27 April, 2010 11:16:34
Subject: Europa-List: Europa stall warner
--> Europa-List message posted by: Frans Veldman <frans(at)privatepilots.nl (frans(at)privatepilots.nl)>
graeme bird
Posted: Fri Oct 08, 2010 9:37 am Post subject: Re: Europa stall warner |
Hi, I am interested in fitting a stall warner to my plane in build, where can I find details of approved type and fitting?
_________________ Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk |
pjeffers(at)talktalk.net Guest
Posted: Fri Oct 08, 2010 10:58 am Post subject: Europa stall warner |
Hi Graeme,
There is a standard Europa mod for this. You can find details on the Europa
web site. Go to http://www.europa-aircraft.com/ . Follow links to
Technical then mods and then look at Mod 61A. I think you will find all
you need in there.
Pete Jeffers LAA Inspector Europa Club
