		| Author | Message |
		| frans(at)privatepilots.nl Guest
				|  Posted: Tue Apr 27, 2010 9:09 am    Post subject: Europa stall warner |   |
				| With the benign stall characteristics of the PH-DIY and plenty of
natural warning before stalling, a stall warner is not really necessary.
 But I had already installed the stall warner before the plane was
 finished, so I decided to adjust it anyway.
 After I adjusted the Europa stall warner to 6 knots above the stall, I
 noticed that the stall warner warns when I'm parked at the ground.
 Technically this is correct of course, a non flying airplane is
 permanently in a stall condition, but is it supposed to work this way?
 Frans
		| Back to top |  |
		| zwakie
		| Back to top |  |
		| terrys(at)cisco.com Guest
				|  Posted: Tue Apr 27, 2010 12:17 pm    Post subject: Europa stall warner |   |
				| Hi Frans,
 Ours did that as well, so we adjusted the sensitivity until it stopped
 beeping on the ground.  It still gave us the in-flight margin we had
 originally set it for.  I suspect the stall 'speed' is more a function
 of the placement of the hole in the wing than the sensitivity
 adjustment.
 Terry Seaver
 A135
		| Back to top |  |
		| grahamsingleton(at)btinte Guest
				|  Posted: Tue Apr 27, 2010 3:45 pm    Post subject: Europa stall warner |   |
				| Frans
Do you have stall strips fitted? You should have a stall warner if you don't. Their setting will also affect the stall, sounds like yours are well adjusted.
 If you don't have them, rain or bug contamination could have a bad effect on stall behavior so be careful and don't assume anything is constant.
 Graham
 Sent: Tuesday, 27 April, 2010  11:16:34
 Subject: Europa-List: Europa stall warner
 --> Europa-List message posted by: Frans Veldman <frans(at)privatepilots.nl (frans(at)privatepilots.nl)>
		| Back to top |  |
		| graeme bird
				|  Posted: Fri Oct 08, 2010 9:37 am    Post subject: Re: Europa stall warner |   |
				| Hi, I am interested in fitting a stall warner to my plane in build, where can I find details of approved type and fitting?
 Graeme Bird
 kit4 (Wagstaff) TBD
 Kit 1 G-UMPY -  Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
		| Back to top |  |
		| pjeffers(at)talktalk.net Guest
				|  Posted: Fri Oct 08, 2010 10:58 am    Post subject: Europa stall warner |   |
				| Hi Graeme,
 There is a standard Europa mod for this.  You can find details on the Europa
 web site.  Go to http://www.europa-aircraft.com/ .  Follow links to
 Technical then mods and then look at Mod 61A.   I think you will find all
 you need in there.
 Pete Jeffers   LAA Inspector Europa Club
		| Back to top |  |
