Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Mon May 24, 2010 3:02 pm Post subject: Aileron Stop after Mod |
When I was fitting the doubler around the aileron pushrod hole I found it necessary to remove the external aileron stop (although it wasn't mentioned in the modification instructions.)
I did a search and see that Zenith wants the external stop retained even though we're supposed to add a stop in the fuselage as well.
Did the rest of you just move the stop outboard to clear the doubler or what?
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Mon May 24, 2010 5:42 pm Post subject: Re: Aileron Stop after Mod |
I retained the external aileron stops.
_________________ David Gallagher
Cincinnati, OH area |
Ron Lendon
Posted: Tue May 25, 2010 9:47 am Post subject: Re: Aileron Stop after Mod |
Keeping it in the same place only on top of the doubler. I will check the deflection and correct as necessary at final assembly.
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
Tim Juhl
Posted: Wed May 26, 2010 1:41 pm Post subject: Re: Aileron Stop after Mod |
I heard from Caleb on the issue. It is OK to move the stop outboard enough to clear the aileron rod hole doubler. It is also OK to trim back the edge of the upper rear spar angle where it protrudes above the doublers if you are concerned about interference with the aileron piano hinge.
Also, had a nice visit with Roy Garrett in Port Huron, MI, today. He has both wings off his XL and is well along in his mods. You'd never believe Roy was 85 - he is still building and going strong.... an example to the rest of us.
CFII
Champ L16A flying
philand
Posted: Wed May 26, 2010 6:04 pm Post subject: Re: Aileron Stop after Mod |
After installing the counterweights, if find that I am 10 mm. from the aileron stop, when the cw. hits the skin. Spoke to Roger and he said that the stop had been "redesigned" a couple of yrs. ago and would send a new stop. I'm drwg. # 6419.
_________________ Phil |
Ron Lendon
Posted: Thu May 27, 2010 6:19 am Post subject: Re: Aileron Stop after Mod |
This is from memory, I think the aileron movement is 11.5 degrees up and 11.5 degrees down.
CH 601 XLB
N601LT - Flying
chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Fri May 28, 2010 12:19 pm Post subject: Re: Aileron Stop after Mod |
well if there is a new stop designed,
can someone with the latest version of the plans ( 650 I guess) scan in the aileron stop so we all can see how it is done? size wise / thickness?
Chris.
Alan Smith
Joined: 10 Jan 2006 Posts: 12 Location: Anderson, Missouri
Posted: Sat May 29, 2010 10:38 am Post subject: Aileron Stop after Mod |
T=.040 6061-T6
Bottom 108 deg bend 20 mm long,
Vertical 15 mm long,
56 deg bend 29 mm long,
56 deg bend Vertical 15 mm
Sorry I can not scan
Brenda Smith CH650
From: "chris Sinfield" <chris_sinfield(at)yahoo.com.au>
Sent: Friday, May 28, 2010 3:19 PM
To: <zenith601-list(at)matronics.com>
Subject: Re: Aileron Stop after Mod
Chris.
http://forums.matronics.com/viewtopic.php?p=299195#299195
_________________ alschief |
chris Sinfield
Posted: Sat May 29, 2010 1:54 pm Post subject: Re: Aileron Stop after Mod |
thanks
I / we should be able to work with that.
Chris
