		Tim Juhl
  Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
				 Posted: Mon May 24, 2010 3:02 pm    Post subject: Aileron Stop after Mod |
				When I was fitting the doubler around the aileron pushrod hole I found it necessary to remove the external aileron stop (although it wasn't mentioned in the modification instructions.)
 I did a search and see that Zenith wants the external stop retained even though we're supposed to add a stop in the fuselage as well.
 Did the rest of you just move the stop outboard to clear the doubler or what?
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
		DaveG601XL
  Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
				 Posted: Mon May 24, 2010 5:42 pm    Post subject: Re: Aileron Stop after Mod |
				I retained the external aileron stops.
  _________________ David Gallagher
Cincinnati, OH area |
		Ron Lendon
				 Posted: Tue May 25, 2010 9:47 am    Post subject: Re: Aileron Stop after Mod |
				Keeping it in the same place only on top of the doubler.  I will check the deflection and correct as necessary at final assembly.
  _________________ Ron Lendon
CH 601 XLB
N601LT  - Flying
Corvair Engine Prints:
		Tim Juhl
				 Posted: Wed May 26, 2010 1:41 pm    Post subject: Re: Aileron Stop after Mod |
				I heard from Caleb on the issue.  It is OK to move the stop outboard enough to clear the aileron rod hole doubler.  It is also OK to trim back the edge of the upper rear spar angle where it protrudes above the doublers if you are concerned about interference with the aileron piano hinge.
 Also, had a nice visit with Roy Garrett in Port Huron, MI, today.  He has both wings off his XL and is well along in his mods.  You'd never believe Roy was 85 - he is still building and going strong.... an example to the rest of us.
CFII
Champ L16A flying
		philand
				 Posted: Wed May 26, 2010 6:04 pm    Post subject: Re: Aileron Stop after Mod |
				After installing the counterweights, if find that I am 10 mm. from the aileron stop, when the cw. hits the skin.  Spoke to Roger and he said that the stop had been "redesigned" a couple of yrs. ago and would send a new stop.  I'm drwg. # 6419.
  _________________ Phil |
		Ron Lendon
				 Posted: Thu May 27, 2010 6:19 am    Post subject: Re: Aileron Stop after Mod |
				This is from memory, I think the aileron movement is 11.5 degrees up and 11.5 degrees down.
CH 601 XLB
N601LT  - Flying
		chris Sinfield
  Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
				 Posted: Fri May 28, 2010 12:19 pm    Post subject: Re: Aileron Stop after Mod |
				well if there is a new stop designed,
  can someone with the latest version of the plans ( 650 I guess) scan in the aileron stop so we all can see how it is done? size wise / thickness?
 Chris.
		Alan Smith
  Joined: 10 Jan 2006 Posts: 12 Location: Anderson, Missouri
				 Posted: Sat May 29, 2010 10:38 am    Post subject: Aileron Stop after Mod |
				T=.040 6061-T6
 Bottom 108 deg bend 20 mm long,
 Vertical 15 mm long,
 56 deg bend 29 mm long,
 56 deg bend Vertical 15 mm
 Sorry I can not scan
 Brenda Smith CH650
 From: "chris Sinfield" <chris_sinfield(at)yahoo.com.au>
 Sent: Friday, May 28, 2010 3:19 PM
 To: <zenith601-list(at)matronics.com>
 Subject: Re: Aileron Stop after Mod
  Chris.
  http://forums.matronics.com/viewtopic.php?p=299195#299195
  _________________ alschief |
		chris Sinfield
				 Posted: Sat May 29, 2010 1:54 pm    Post subject: Re: Aileron Stop after Mod |
				thanks
  I / we should be able to work with that.
 Chris
