		steven.pitt2(at)ntlworld. Guest
				 Posted: Thu Sep 23, 2010 6:57 am    Post subject: trim indicator |
				I have noticed that my trim LED has begun to  play up with several of the lights not showing up. Is this a problem others have  had and has anyone looked at alternatives?
  Steve Pitt
  G-SMDH
		Rocketman
				 Posted: Thu Sep 23, 2010 7:51 am    Post subject: trim indicator |
				Steve,
 Half of my lights are out.  I only get lights in cruise.  Replacement is
 over a hundred bucks...
 Jeff - Baby Blue
 On 9/23/2010 9:51 AM, Steven Pitt wrote:
  	  | Quote: | 	 		   I have noticed that my trim LED has begun to play up with several of the
  Steve Pitt
  G-SMDH
  Checked by AVG - www.avg.com
		Jeff(at)rmmm.net Guest
				 Posted: Thu Sep 23, 2010 8:06 am    Post subject: trim indicator |
				Steve,
 Mine did the same thing. I just push on the LED's with my finger and
 they all come back on. I think it's a printed circuit thing on the
 display.
 Jeff R.  N128LJ Gold Rush
 On Sep 23, 2010, at 10:24 AM, Jeff B wrote:
  Steve,
  Replacement is over a hundred bucks...
  Jeff - Baby Blue
 > of the
 > anyone
 > Steve Pitt
 > G-SMDH
		gregoryf.flyboy(at)comcas Guest
				 Posted: Thu Sep 23, 2010 10:53 am    Post subject: trim indicator |
				I have serviced a few of these already.  One was mine, right out of the box.
 In my case, one LED at the extreme range of travel would not light
 sometimes.
 All it required was a touch up of solder on one of the terminals on the back
 of the bar display, inside the unit.
 The other one was in someone else's plane, with quite a few hours. The
 symptom was that the two LED's (segment lights) in the middle would not
 light up. These two segments corresponded with cruise settings. I was sure
 that it was the dot/bar driver IC inside. On further inspection, it turned
 out to be that the two LED's on the lighted display were blown and the
 Integrated circuit was just fine.  Most LED's should last 100,000 hours.
 WOW, that was a stunner! (it could be that they are driven at high current
 levels, for maximum brightness in the cockpit on sunny days..but I did not
 check) Thus in this case, a new $2 10-segment Light display was called for.
  	  | Quote: | 	 		  From Jeff R's symptoms:
 I am almost positive that based on the intermittent symptoms in Gold Rush,
 it will just require a solder touch-up inside the display unit. Cost: about
 1 cent worth of solder.
 In the other two cases, there is not enough info to go on. If the LED's
 sometimes still work (from hand tapping), it is probably a solder Job. Tap
 on the display unit while it is operating, to see if you can get all of the
 LED's to come on. Once is enough, even if only a split second. It verifies
 the LED (Light Emitting Diode) is not burned out.
 An intermittent problem in flight that is not resolved by tapping on the
 display, could also reside in the position feedback inside the servo itself,
 back on the rear bulkhead, though I have as yet to see that failure.
 It is quite a simple circuit inside these display units. I used to play with
 the exact same circuit on a solder-less breadboard...way back in High
 School. In fact, I built a display for my Ford Pinto to verify the voltage
 in the car, just for fun. A cassette tape holder served as the case for it.
 If memory serves, it fell out of its berth and onto the floor when the car
 got rear-ended...
 Greg Fuchs, A050
				 Posted: Fri Sep 24, 2010 10:26 am    Post subject: Trim indicator |
				I am surprised and disappointed by the number of  replies I received to my query about LEDs packing up. Thankful for the number of  replies but disappointed that so many people have had or are having problems  with this part. At $100 a pop this does not seem right. Has anyone contacted Ray  Allen to ask why?
  Thanks especially to Greg for the detail and  potential repair strategy. We will have a look at that more in the  UK.
  Steve Pitt
  G-SMDH
		terrys(at)cisco.com Guest
				 Posted: Fri Sep 24, 2010 10:51 am    Post subject: Trim indicator |
				Hi Steve,
 I didn’t reply to your earlier email, but thought I would this time.  We also had the display go bad and replaced it.  It has been OK since.  One thing we notice is that the display is very sensitive to the radio, when we transmit, the LEDs flicker.  It might be that the long wiring run back to the tail is picking up enough RF to burn the things out.  Maybe the wiring needs shielding.  Just a thought.
 Terry
 A135/N135TD
 From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Steven Pitt
  Sent: Friday, September 24, 2010 10:22 AM
  Subject: Trim indicator
 Steve Pitt
 G-SMDH
    	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?Europa-List  | 	  0123456789
				 Posted: Fri Sep 24, 2010 12:04 pm    Post subject: Trim indicator |
				On Sep 24, 2010, at 11:46 AM, Terry Seaver (terrys) wrote:
  	  | Quote: | 	 		  |  Maybe the wiring needs shielding. |
 	...Bingo!...(?)...(at) RR I heard someone recommend shielding ALL wires...(?)
 Fred
				 Posted: Fri Sep 24, 2010 2:20 pm    Post subject: Trim indicator |
				Thanks Dale - it is good to see the power of the  forum and thanks for taking the initiative. I will contact Scott.
  My lights probably were issued by Europa in  1998 but I have only flown for the last 4 years (220 hours and  smiling).
  Steve Pitt
  [quote]   ---
		air.guerner(at)orange.fr Guest
				 Posted: Sat Sep 25, 2010 10:36 am    Post subject: trim indicator |
				Hi Steve,
 I have the same problem with my yaw trim indicator which I installed
 about two years ago. The pitch trim indicator which is ten years and
 800 flight hours old is still fine. May be  this indicates a decline
 in manufacturing quality of this product.
 Remi
 <<<<<I have noticed that my trim LED has begun to play up with several
 of the
 looked at alternatives?>>>>>>>>
				 Posted: Mon Sep 27, 2010 12:36 am    Post subject: trim indicator |
				I did not intend to knock the company around, as I personally don't feel
 there is much of a problem here. Others may think as they wish, of course.
 There are a lot of these in use, and there are bound to be some failures.
 Imagine how many would be failing if there were a billion of them sold. A
 percentage of units failing would be a more meaningful number to look at.
 The second failed unit I worked on was not from a Europa, but another
 well-known kit manufacturer with many many hours on the clock.   I still
 consider my out-of-box failure (shipped in late 2001) an outlier of sorts,
 and that most of these work fine at installation. EVERYTHING runs down or
 wears out eventually.. Its just a question of how long.
 Greg
		rparigoris
				 Posted: Mon Sep 27, 2010 7:40 am    Post subject: Trim indicator |
				Hi Fred"...Bingo!...(?)...(at) RR I heard someone recommend shielding ALL wires...(?) "Not a great idea to shield power cable for Kunzleman strobes, thats for sure. It brought a tremendous amount of noise into the radios! Twisted pair is the secret. Here was effort:http://www.europaowners.org/forums/gallery2.php?g2_itemId=31409Ron Parigoris   [quote][b]
				 Posted: Mon Sep 27, 2010 9:09 am    Post subject: Trim indicator |
				On Sep 24, 2010, at 4:00 PM, rparigor(at)suffolk.lib.ny.us wrote:
  	  | Quote: | 	 		   Not a great idea to shield power cable for Kunzleman strobes, thats
 Ron...now that IS a surprise...Kunzleman ships w/ shielded cable, and
 I would have thought that strobe wiring would be the one place where
 shielding would be essential...I understand proper grounding of
 shielded cable is critical, but my thoughts on all things electrical
 however should be taken w/ many grains of salt, as my knowledge could
 fit on the head of a pin.
 Fred
		rparigoris
