graeme bird
Posted: Sun Oct 10, 2010 12:23 am Post subject: Battery position Classic Mono XS FWFD |
I am building a classics without the baggage extension (dont want electric flaps or the pay 1000 for the mod) so where does the battery go. Its having a 912S so I would like to have it as close as possible. I only have the XS manual.
Also can I put the choke on the instrument panel?
_________________ Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk |
ward.t(at)xtra.co.nz Guest
Posted: Sun Oct 10, 2010 12:54 am Post subject: Battery position Classic Mono XS FWFD |
?Graeme,
I have the battery on the top of the starboard foot well.
Easy access, close to everything, and OK for C of G.
jrgowing(at)bigpond.net.a Guest
Posted: Sun Oct 10, 2010 3:15 am Post subject: Battery position Classic Mono XS FWFD |
Graham
You would probably do best to emulate the XS and make a raised addition to
the tunnel near the brake so you can leave the cable connected it you remove
the panel.
JR (Bob) Gowing Kit 327 in Oz
Troy Maynor
Posted: Sun Oct 10, 2010 5:51 pm Post subject: Re: Battery position Classic Mono XS FWFD |
Graham,
I have a Classic Monowheel, 912S. I put my choke cable on a piece of 1" angle aluminum and bolted it to the side of the tunnel to place the surface of it in line with the bottom of the instrument panel. I also have a carb heat knob there too beside it that operates a water shut off valve to the Skydrive carb heat system. My battery is on the starboard foot well. I have the extended baggage shelf and the XS style tailwheel. My CG is right in the middle of the range. Hope this helps.
Troy Maynor
N120EU
65 hours so far.
