		| Author | Message |
		| graeme bird
				|  Posted: Sun Oct 10, 2010 12:23 am    Post subject: Battery position Classic Mono XS FWFD |   |
				| I am building a classics without the baggage extension (dont want electric flaps or the pay 1000 for the mod) so where does the battery go. Its having a 912S so I would like to have it as close as possible. I only have the XS manual.
Also can I put the choke on the instrument panel?
 Graeme Bird
 kit4 (Wagstaff) TBD
 Kit 1 G-UMPY -  Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
		| Back to top |  |
		| ward.t(at)xtra.co.nz Guest
				|  Posted: Sun Oct 10, 2010 12:54 am    Post subject: Battery position Classic Mono XS FWFD |   |
				| ?Graeme,
I have the battery on the top of the starboard foot well.
 Easy access, close to everything, and OK for C of G.
 Cheers,
		| Back to top |  |
		| jrgowing(at)bigpond.net.a Guest
				|  Posted: Sun Oct 10, 2010 3:15 am    Post subject: Battery position Classic Mono XS FWFD |   |
				| Graham
You would probably do best to emulate the XS and make a raised addition to
 the tunnel near the brake so you can leave the cable connected it you remove
 the panel.
 JR (Bob) Gowing Kit 327 in Oz
		| Back to top |  |
		| Troy Maynor
				|  Posted: Sun Oct 10, 2010 5:51 pm    Post subject: Re: Battery position Classic Mono XS FWFD |   |
				| Graham,
I have a Classic Monowheel, 912S. I put my choke cable on a piece of 1" angle aluminum and bolted it to the side of the tunnel to place the surface of it in line with the bottom of the instrument panel. I also have a carb heat knob there too beside it that operates a water shut off valve to the Skydrive carb heat system. My battery is on the starboard foot well. I have the extended baggage shelf and the XS style tailwheel. My CG is right in the middle of the range. Hope this helps.
 Troy Maynor
 N120EU
 65 hours so far.
		| Back to top |  |
