jonlaury
Posted: Fri Oct 15, 2010 2:33 pm Post subject: Catch diode location |
In the attached, I don't understand the pathway for the inductive spike of the Grnd Pwr contactor to dissipate. I thought that the diode symbol always pointed to positive.
And where does the catch diode go/orient on the Stby Alt Contactor?
Thank you,
 Download |
| Filename: |
Z8 w-SB ALT-GPJ conceptual rev b .pdf |
434.21 KB |
| Downloaded: |
660 Time(s) |
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Fri Oct 15, 2010 2:46 pm Post subject: Re: Catch diode location |
Or use bidirectional Zeners like you should and don't worry about it.
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
Bob McC
Posted: Fri Oct 15, 2010 3:46 pm Post subject: Catch diode location |
John;
In all cases the "spike catcher" diode goes across the coil just as it does and is shown on the battery contactor and with that same orientation. The drawing you've attached has no "spike catcher" on the ground power contactor. If you wish that feature it would have to be added. The diodes currently shown are for polarity protection to prevent energizing the contactor should the connect ground power be reverse polarity, and to allow the light to indicate polarity.
The direction of the diode symbol depends on what use you are trying to make of the diode. Its orientation to prevent "reverse flow" may be different than if its purpose is to provide an alternate path for induced voltages. You can also use a bidirectional zener as Eric suggests for spike suppression, but these won't work for directing current flow such as in the reverse polarity protection circuit. Different purpose, different characteristics, different functions, different connections. (Sometimes able to be achieved by the same component however)
Bob McC
> -----Original Message-----
> From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-
> server(at)matronics.com] On Behalf Of jonlaury
> Sent: Friday, October 15, 2010 6:34 PM
> To: aeroelectric-list(at)matronics.com
> Subject: Catch diode location
> --> AeroElectric-List message posted by: "jonlaury" <jonlaury(at)impulse.net>
> positive.
> Thank you,
> John
> http://forums.matronics.com/viewtopic.php?p=315902#315902
> http://forums.matronics.com//files/z8_w_sb_alt_gpj_conceptual_rev_b__838.pdf
> _-
> style='mso-spacerun:yes'> - The AeroElectric-List Email Forum -
[b]> style='mso-spacerun:yes'> --> http://www.matronics.com/Navigator?AeroElectric-List
[b]> _-
> style='mso-spacerun:yes'> - MATRONICS WEB FORUMS -
[b]> style='mso-spacerun:yes'> --> http://forums.matronics.com
[b]> _-
> style='mso-spacerun:yes'> - List Contribution Web Site -
> style='mso-spacerun:yes'> Thank you for your generous support!
> style='mso-spacerun:yes'> -Matt Dralle, List Admin.
> style='mso-spacerun:yes'> --> http://www.matronics.com/contribution
> _-
_________________ Bob McC
Falco #908
(just starting) |
jonlaury
Posted: Fri Oct 15, 2010 5:00 pm Post subject: Re: Catch diode location |
Eric and Bob McC,
My EFIS maker, Advanced Flight Systems, wants spike suppression on every relay.
OK, so I can just put a bi-directional zener across all the relay/contactor coils in the plane and I'm good for spike catching? Including the Alt 2 relay?
I've also got a small 5vdc coil (40ma) driven by an optical switch (another relay). Does it get a spike catcher too?
So how does one size a bi-di-zener for spike catching?
Bob McC
Posted: Fri Oct 15, 2010 7:23 pm Post subject: Catch diode location |
John;
Yes, or just use the 1N5400's you've already shown for your battery
contactor on everything. Either will work. The perceived disadvantage to the
plain diode is that it does slow the reaction time of the device slightly,
but this will be undetectable for all practical intents and purposes.
(Advantages, really cheap, available anywhere)
Check Eric's website for explanations of the zeners. (Which he happens to
sell under the name "snapjack". They are also available from the major
electronics suppliers as bi-directional zeners)
http://www.periheliondesign.com/suppressors.htm
Any coil carrying a current will generate some level of reverse voltage when
switched off. So technically, yes, your small 5vdc coil will exhibit the
effect. Is it of any significance? Most likely not, especially as many
optical switches have suppression built in. The greatest effects are from
relatively large currents in relatively large inductors. (Like the one amp
of holding current in the multi turn winding of the battery contactor)
Bob McC
[quote] --
Falco #908
(just starting) |
Eric M. Jones
Posted: Sat Oct 16, 2010 5:04 am Post subject: Re: Catch diode location |
Modern relay and contactor manufacturers recommend using bidirectional Zeners for coil suppression, NOT diodes.
Mechanical relays and contactors depend upon magnetism generated by an electric current running through a wire coil. When the current stops, the magnetic field collapses. But the relay does not know the difference between a wire coil moving in a magnetic field (as in a generator) or a magnetic field moving in a wire coil (as in a collapsing magnetic field). Thus a large voltage—1000V to 1500V typically—is induced in the coil. This current goes the same direction the original current did—so it slows the contact opening—allowing arcing, chatter, bouncing, contact welding and even re-closure.
http://www.periheliondesign.com/suppressors/SnapJack.pdf
Or buy your own, I recommend P6KE18CA for general purposes. Another advantage is you can't put them in the wrong direction. They are symmetrical.
113 Brentwood Drive
(508) 764-2072
Posted: Sat Oct 16, 2010 6:19 am Post subject: Catch diode location |
At 08:04 AM 10/16/2010, you wrote:
. . . an assertion that appears to be based
upon a paper published by Tyco authors that
in-expertly speak to issues not relevant
to the manner in which we use diodes on
our relays and contactors. Furhter, they
made mis-interpreted the significance of
their own data.
This was examined at length some years
ago Eric and you offered no evidence
or analysis contrary to the explanations
I demonstrated and published. If you have
some personally developed rationale for
contradicting what I wrote, please bring
it forward.
jonlaury
Posted: Sat Oct 16, 2010 7:11 am Post subject: Re: Catch diode location |
Eric and Bob McC,
Thank you both for spelling it all out for me. I like the bi-di- zener solution because it's idiot proof and perfect for people like me that have just enough electronic knowledge to be dangerous.
Eric, your schematics of all the different scenarios are priceless. With all the other sorts of subjective decisions involved in building my plane, it's REALLY a luxury to have an experienced person say "Here, do it this way".
Contributions, like yours, to this forum, really make it sing.
Eric M. Jones
Posted: Sat Oct 16, 2010 8:56 am Post subject: Catch diode location |
At 10:39 AM 10/16/2010, you wrote:
Using diodes for coil suppression is Soooooooooooo 1900's Bob. Come
on board to the next century.
Eric. Those papers were crafted for exploring
the tradeoffs for relays designed to operate
under rated loads for tens to hundreds of
thousands of cycles. And yes, SOME of the
studies show a benefit for not clamping the
recoil spike at near zero volts with a diode and
instead allowing it to rise to some level determined
by a zener.
THIS forum of discussion is not about crafting
electrical systems for military or space-grade
vehicles. On average, the GA light aircraft
flies 50 hours a year. OBAM aircraft as a class
are probably higher. So let us say after 20
years, the airplane MIGHT have 3000 hours on
it. How many THOUSANDS of operations might
any given relay or contactor see on such a
vehicle? Certainly not hundreds of thousands
nor even tens of thousands. How many of our
relays are loaded such that they switch rated
loads for every cycle?
Adding super-suppression to a relay might
produce a 10-20% improvement in laboratory
life tests running at rated loads . . . probably
NO improvement for lightly loaded or dry-circuit
switching.
The point is my friend that there is no value
to be secured for NOT buying coil suppression
devices at Radio Shack as opposed to the
"ideal" device ordered in from remote sources
for more money and time.
You have taken a few facts and morphed them
into a level of significance that is simply
not applicable to the customers you and I
serve for the airplanes they are building.
The next century? Hammers have been around for
thousands of years . . . but that does not mean that
the task of driving a nail is not well served
by keeping a few hammers in my toolbox.
The point of my writing for this audience is
to tailor a suggestion for adequate performance
at the least cost and time . . . i.e. the
elegant solution. The solutions may or may not
comport with findings produced in a laboratory
that will never study what we do on the OBAM
GA aircraft.
