Float Flyr
Posted: Sat Oct 23, 2010 2:09 pm Post subject: Washing Ethanol out of Gas |
Now if we can just get politicians on both sides of the border to see it
that way! We might then come up with a good reliable fuel.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Roger Lee
Posted: Sat Oct 23, 2010 2:25 pm Post subject: Re: Washing Ethanol out of Gas |
Hi All,
If you all are washing gas for the 912ULS 100 hp then you should stop and I wouldn't put another drop of washed fuel in my 912ULS. I just got with some people that work with this as a business and did some real testing at a lab. The washed gas looses octane and the 91 oct. went from 91 to 88.3 oct. It also took out some of the additives. That 88.3 Oct. is too low for the 912ULS 100 hp. You will eventually ruin your engine. For the guys with the 912UL 80 hp you could still use this fuel at 88 oct.
I just saw the lab results a few hours ago. These guys really did their homework.
If you want to use this technique there are devices on the market.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Posted: Sat Oct 23, 2010 2:31 pm Post subject: Washing Ethanol out of Gas |
Noel- The Japanese used the same arrangement with charcoal. My father saw it on Okinawa and in China while with the Marines in 1945. He said they only went 10 or 15mph, but it was better than walking and carrying the load.
Bill Sullivan
dave
Posted: Sat Oct 23, 2010 2:42 pm Post subject: Re: Washing Ethanol out of Gas |
| Roger Lee wrote: | Hi All,
If you want to use this technique there are devices on the market. |
Roger I just passed 1100 hours in Rotax 2strokes with Ethanol gas.
is there a proble with ethanol gas ?
The ones that whine about it -heck might not fly much ?
Armchair captains
Check my videos -- Real time proof it works .
I am not a supporter of ethanol gas but it here and I ain't got no choice. SO I MAKE IT WORK
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
thilo.kind(at)gmx.net Guest
Posted: Sat Oct 23, 2010 3:02 pm Post subject: Washing Ethanol out of Gas |
During the war Germany used coal to produce methane based fuels, since crude
oil was hard to come by. The process was not very efficient, but since all
other fuel sources were not longer accessible to them, they had to go that
road.
The wood driven cars and trucks were mostly civilian vehicles during and
shortly after the war. Wood was loaded into a vessel and ignited. A small
hole at the bottom of the vessel provided air, but not enough to burn all
the wood. Hence, a good portion of the wood degraded into gas, which was
then used to drive an internal combustion engine. Not very efficient - the
energy content of the wood was very low and the gas didn't burn very clean
inside the engine (which significantly reduced the life time of the engine).
Not really an option for airplanes....
Sorry to hear about the trouble with the gas / ethanol in the US. For once,
we have an advantage here in Europe: our Mogas contains 5 % Ethanol max....
Thilo
lucien
Posted: Sun Oct 24, 2010 4:58 am Post subject: Re: Washing Ethanol out of Gas |
| dave wrote: |
Armchair captains
I am not a supporter of ethanol gas but it here and I ain't got no choice. SO I MAKE IT WORK |
Roger's talking about the 912ULS which has a higher octane requirement than the 2-strokes. The 2-strokes can pretty much run on anything as long there's 2 stroke oil in it
But in the end, you're much better off just running the E10 premium than the witches brew you get when you wash the gas. After it's washed, you don't really know what you got running through your 20 grand engine. At least you know what the octane rating of the gas is if you leave it alone.
For the 2-strokes you may still be ok, but you're still doing a whole lot of work and messing around than you need to do. E10 has been approved for the 2-strokes too (except the 447 of course) so I'd just gas up and fly....
LS
_________________ LS
Titan II SS |
Roger Lee
Posted: Sun Oct 24, 2010 8:30 pm Post subject: Re: Washing Ethanol out of Gas |
Lucien said it all.
Tucson, Az.
Cell 520-349-7056 |
dave
Posted: Sun Oct 24, 2010 9:59 pm Post subject: Re: Washing Ethanol out of Gas |
LS, I know the 912 s well. Reg mogas no good -- Premium works fine. Most here have no ethanol in it yet in Ontario Canada.
I know of many that use premium grade on 912 ul and 2 strokes because of what ever reason. - I never had troubles with 6 month old gas in 2 strokes but I do hear pinging once in a while if gas is old or new.
flyadive(at)gmail.com Guest
Posted: Mon Oct 25, 2010 2:37 pm Post subject: Washing Ethanol out of Gas |
Roger:
Interesting on this subject of gas. How was the 88.3 Octane level determined?
Barry
On Sat, Oct 23, 2010 at 6:42 PM, dave <dave(at)cfisher.com (dave(at)cfisher.com)> wrote:
| Quote: | --> RotaxEngines-List message posted by: "dave" <dave(at)cfisher.com (dave(at)cfisher.com)>
Roger Lee wrote:
> Hi All,
Armchair captains
Rotax Dealer, Ontario Canada
http://www.cfisher.com/
Awesome *New Forum *
http://rotaxaircraft.com/forum/
http://www.youtube.com/profile_videos?user=kitfoxflyer
http://forums.matronics.com/viewtopic.php?p=316801#316801
-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
le, List Admin.
Barry
"Chop'd Liver"
Roger Lee
Posted: Mon Oct 25, 2010 3:03 pm Post subject: Re: Washing Ethanol out of Gas |
Hi Barry,
The fuel was tested at a lab before washing and the same fuel tested after washing. I don't know the exact method the lab used to define the octane rating. The first sample of the untreated fuel was right on and the washed fuel test results looked right in line with what you would expect.
Tucson, Az.
Cell 520-349-7056 |
KeysFox
Posted: Mon Oct 25, 2010 4:00 pm Post subject: Washing Ethanol out of Gas |
Regarding 912 Rotax 4 - stroke, The 2 to 3 point octane loss seems to be
what multiple folks in the proprietary gasoline additive aftermarket
business have seen in their testing. I also heard that figure from one of
the major aftermarket additives companies two or three years ago while
talking with thier fuel additive engineers.
Amoco gas engineers working with the EAA on unleaded gas STCs for GA
engines were adamant that a little bit of lead from a small percentage of
100 LL (25%) mixed with unleaded auto fuel resulted in a very prominent
increase in octane and that additional increases in octane required
relatively dramatic increases in lead. In other words the increase in
octane with increase in lead content is not a straight line but an upswept
curve. 25 to 30 percent 100 LL seemed to provide enough lead to gain back
about 3 octane points according to what I remember and 50 % 100 LL seems
to be what others are hearing is required to regain octane lost thru
washing.
If Shell included some ashless dispersant qualities in thier new 4 -
stroke light sport aviation oil, plating out of lead may not be a big
issue if 25 hour oil changes are carried out.
I have to think that Shell at least tested some ashless dispersant
qualities for thier new 4 - stroke Light Sport aviation oil, because
Shell knows the fleet is predominantly Rotax 912s, that 100 LL use will be
common in these engines, and Shell engineers certainly have lots of
expertise in ashless dispersant technology for aviation oils.
If anyone knows the lead suspension qualities of Shells 4- stroke light
sport oil, fill us in.
BJ
Kitfox IV, 912 N154K
Twin Comanche PA 39 N626NR
Roger:
determined?
Barry
On Sat, Oct 23, 2010 at 6:42 PM, dave <dave(at)cfisher.com> wrote:
> Roger Lee wrote:
> > Hi All,
> and
> at a
> oct.
> the
> the
> their
> homework.
> Armchair captains
> choice.
> SO I MAKE IT WORK
Barry
"Chop'd Liver"
_________________ B Jones
N154K
443-480-1023 |
Float Flyr
Posted: Mon Oct 25, 2010 7:37 pm Post subject: Washing Ethanol out of Gas |
They use a process called a flash test. Basically they heat up a metal
plate to a specific temperature and then drop a single drop of fuel on it.
The temperature of the plate which causes the fuel to flash is what they are
looking for. The higher the octane rating the higher the temperature
required to flash. In the past volatility and high octane levels were
confused because older high octane gasoline was a lot more volatile than
lower octane gasoline.
BTW someone once told me that I could increase the octane of any fuel by
adding a bit of kerosene or Diesel fuel to it... This obviously is not
true. Diesel fuels are very low octane so they do not require a spark to
get them to flash inside the engine. Conversely Ethanol while very low in
btu per unit volume a is actually a high octane fuel (RON116) This is why
when you wash the ethanol out of your gas you will see a slight decrease in
RON. Using my grade two arithmatic I estimate the drop to be under three
points drop for removing 10% booze.
Noel
Kitfox III-A
KeysFox
Posted: Tue Oct 26, 2010 3:26 am Post subject: Washing Ethanol out of Gas |
Noel,
Nice to see some detail.
Thanks for the information.
BJ
<noelloveys(at)yahoo.ca>
are
in
Noel
N154K
443-480-1023 |
Posted: Sun Oct 31, 2010 11:37 pm Post subject: Washing Ethanol out of Gas |
Hello Roger:
Sorry for the long delay on getting back to you and the Gaggle.
I have spoken to a retired lab chemist for Exxon-Mobile and determining octane rating is not something any lab can perform. Mainly because of the cost. The way it is done is with a very specialized piece of equipment called a "Knock Engine".
I wanted to have some testing done and the answer was - You can't afford it.
The explanation on what a Knock Engine is and how it works was very interesting and took about a half hour with Q&A's.
Simply:
It is a Variable Compression Engine.
It is fuel injected.
And there are gages to read: Compression, Fuel Flow, Temps of all sorts and an audio system to detect Knock.
The engine is started - Run up to temp. And then the compression is increased until the Knock is detected.
There are all sorts of charts to compare fuels - ranges of operation - density altitude - and others.
What Noel is talking about is Flash Point - Which is used to determining the Flammability of a substance for chemical classification for things such as MSDS (Material Safety Data Sheet) and HMIS (Hazardous Material Identification System).
And it is done two ways:
Open and Closed...
Open is done with a OPEN metal petri dish and heated electrically so you can CONTROL the temperatures and without adding variables such as oxygen and an external combustion process.
Closed is done the same way except with a close petri dish.
The closed method is used for know explosive items. Gas being one of them.
Noel's idea of dropping gas on a hot metal plate has a huge variable as oxygen is being removed from the surrounding area. Which would raise the flash point. That is why the Closed method was developed.
I am still searching for a lab to perform a test that would hold up in court and not brake my bank.
Barry
On Mon, Oct 25, 2010 at 7:03 PM, Roger Lee <ssadiver1(at)yahoo.com (ssadiver1(at)yahoo.com)> wrote:
| Quote: | --> RotaxEngines-List message posted by: "Roger Lee" <ssadiver1(at)yahoo.com (ssadiver1(at)yahoo.com)>
Hi Barry,
Roger Lee
Tucson, Az.
Light Sport Repairman - Maintenance Rated
Rotax Repair Center
520-574-1080
http://forums.matronics.com/viewtopic.php?p=317024#317024
le, List Admin.
Barry
"Chop'd Liver"
Float Flyr
Posted: Mon Nov 01, 2010 7:14 am Post subject: Washing Ethanol out of Gas |
Unfortunately my friends lab was taken over and subsequently closed but I believe the Irving Oil co in New Brunswick still does octane testing. You may also want to contact the Newfoundland Constabulary. They had problems years ago with low octane fuel in their cars and I understand that they now do periodic octane testing of all high octane pumps in their jurisdictions. This far north you may find a lab that is more reasonable than where you live. Sending a vial of gas across an international border could be fun though!
Either way you can check with universities ( Chemistry profs usually know where to find things in industry) or local police or sheriffs departments. They may have come into problems with their high compression police cars. You could also check with the NHRA.
Noel
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of FLYaDIVE
Sent: November 1, 2010 4:59 AM
Subject: Re: Re: Washing Ethanol out of Gas
Hello Roger:
Simply:
Open and Closed...
Barry
Hi Barry,
Roger Lee
Tucson, Az.
Rotax Repair Center
520-574-1080
le, List Admin.
Barry
"Chop'd Liver"
0123456789012345678
Kitfox III-A
