fklein(at)orcasonline.com Guest
Posted: Wed Oct 27, 2010 2:53 pm Post subject: zolatone |
Hi...I note that zolatone recommends a 2.0 to 2.4mm nozzle in a
pressure-feed type gun for spraying their multicolor material.
I'm finding that, short of spending way more for a gun than I'd like
to, the guns in my price range have 1.4mm to 1.8mm nozzles.
Has anyone tried to enlarge the nozzle size of a spray gun
successfully?...unsuccessfully?...in order to apply the zolatone
multicolor material?
My application is for cockpit interior which will not be covered w/
fabric...I'm attracted to the multi-color-stuff as it seems to offer a
good way to mask the CM seams and other irregularities...I've looked
for but have not found any comparable spray can product at Home Depot
or hardware stores.
Recommendations from experience are most welcome.
Fred
hagargs(at)earthlink.net Guest
Posted: Wed Oct 27, 2010 4:53 pm Post subject: zolatone |
Yes I used some number drills to open the nozzel up and the results were
fine.
Steve Hagar
Mesa Az
| Quote: | [Original Message]
To: <europa-list(at)matronics.com>
Date: 10/27/2010 3:55:48 PM
Subject: zolatone
or hardware stores.
Fred
kevann(at)gotsky.com Guest
Posted: Wed Oct 27, 2010 7:07 pm Post subject: zolatone |
Fred,
I bought a Harbor Freight gun and drilled it out. Worked fine.
If your primer matches the base color of the zolatone, you won't have to
spray as much. The zolatone is heavy if you spray it thick.
Kevin
Posted: Wed Oct 27, 2010 9:11 pm Post subject: zolatone |
Kevin K. & Steve H....thank you for your responses
| Quote: | I bought a Harbor Freight gun and drilled it out.
...HF is my favorite supplier!
Excellent...BTW, how's the gun work on conventional paint after the
nozzle has been enlarged?
Fred
Posted: Thu Oct 28, 2010 4:37 am Post subject: zolatone |
I've only used it with zolatone. I bought HVLP with a fresh air mask to
paint the plane. I'm gonna sell it.
Kevin
loboloda(at)execulink.com Guest
Posted: Thu Oct 28, 2010 8:57 am Post subject: zolatone |
I used a standard 1.8mm nozzle, worked OK, but Zolatone does not hide
imperfections that well.
The decorator stone spray paint does a better job of covering seams etc.
Dave
On 27-Oct-10, at 6:51 PM, Fred Klein wrote:
like to, the guns in my price range have 1.4mm to 1.8mm nozzles.
offer a good way to mask the CM seams and other
irregularities...I've looked for but have not found any comparable
spray can product at Home Depot or hardware stores.
Fred
Troy Maynor
Posted: Thu Oct 28, 2010 11:56 am Post subject: Re: zolatone |
Hi All,
You still have to use some filler (Superfil) on the seams. I followed with a gray spray can primer from Home Depot. After a couple days applied the Zolatone I bought at ACS with a Wagner Airless sprayer, with the tip you would use to apply heavy latex house paint. After a long cure, I put some clear lacquer over that to help seal it. Your results may vary.
Troy
