		| Author | Message |
		| fklein(at)orcasonline.com Guest
				|  Posted: Wed Oct 27, 2010 2:53 pm    Post subject: zolatone |   |
				| Hi...I note that zolatone recommends a 2.0 to 2.4mm nozzle in a
pressure-feed type gun for spraying their multicolor material.
 I'm finding that, short of spending way more for a gun than I'd like
 to, the guns in my price range have 1.4mm to 1.8mm nozzles.
 Has anyone tried to enlarge the nozzle size of a spray gun
 successfully?...unsuccessfully?...in order to apply the zolatone
 multicolor material?
 My application is for cockpit interior which will not be covered w/
 fabric...I'm attracted to the multi-color-stuff as it seems to offer a
 good way to mask the CM seams and other irregularities...I've looked
 for but have not found any comparable spray can product at Home Depot
 or hardware stores.
 Recommendations from experience are most welcome.
 Fred
		| Back to top |  |
		| hagargs(at)earthlink.net Guest
				|  Posted: Wed Oct 27, 2010 4:53 pm    Post subject: zolatone |   |
				| Yes I used some number drills to open the nozzel up and the results were
fine.
 Steve Hagar
 Mesa Az
  	  | Quote: |  	  | [Original Message] From: Fred Klein <fklein(at)orcasonline.com>
 Date: 10/27/2010 3:55:48 PM
 Subject: zolatone
 or hardware stores.
 Fred
		| Back to top |  |
		| kevann(at)gotsky.com Guest
				|  Posted: Wed Oct 27, 2010 7:07 pm    Post subject: zolatone |   |
				| Fred,
 I bought a Harbor Freight gun and drilled it out. Worked fine.
 If your primer matches the base color of the zolatone, you won't have to
 spray as much. The zolatone is heavy if  you spray it thick.
 Kevin
		| Back to top |  |
				|  Posted: Wed Oct 27, 2010 9:11 pm    Post subject: zolatone |   |
				| Kevin K. & Steve H....thank you for your responses
  	  | Quote: |  	  | I bought a Harbor Freight gun and drilled it out.
 ...HF is my favorite supplier!
 Excellent...BTW, how's the gun work on conventional paint after the
 nozzle has been enlarged?
 Fred
		| Back to top |  |
				|  Posted: Thu Oct 28, 2010 4:37 am    Post subject: zolatone |   |
				| I've only used it with zolatone. I bought  HVLP with a fresh air mask to
paint the plane. I'm gonna sell it.
 Kevin
		| Back to top |  |
		| loboloda(at)execulink.com Guest
				|  Posted: Thu Oct 28, 2010 8:57 am    Post subject: zolatone |   |
				| I used a standard 1.8mm nozzle, worked OK, but Zolatone does not hide
imperfections that well.
 The decorator stone spray paint does a better job of covering seams etc.
 Dave
 On 27-Oct-10, at 6:51 PM, Fred Klein wrote:
  	  | Quote: |  	  |
 like to, the guns in my price range have 1.4mm to 1.8mm nozzles.
 offer a good way to mask the CM seams and other
 irregularities...I've looked for but have not found any comparable
 spray can product at Home Depot or hardware stores.
 Fred
		| Back to top |  |
		| Troy Maynor
				|  Posted: Thu Oct 28, 2010 11:56 am    Post subject: Re: zolatone |   |
				| Hi All,
You still have to use some filler (Superfil) on the seams. I followed with a gray spray can primer from Home Depot. After a couple days applied the Zolatone I bought at ACS with a Wagner Airless sprayer, with the tip you would use to apply heavy latex house paint. After a long cure, I put some clear lacquer over that to help seal it. Your results may vary.
 Troy
		| Back to top |  |
