John Bolding
Posted: Sat Oct 30, 2010 4:41 pm Post subject: Bent tailwheel, |
Got a buddy with a II TD and 40 hrs total time, tailwheel assy bent to one
side, easy enough to fix and strengthen but is this a common problem? He
operates off grass but smooth.
| | - The Matronics Glasair-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Glasair-List |
bgray(at)glasair.org Guest
Posted: Sun Oct 31, 2010 7:18 am Post subject: Bent tailwheel, |
Yes.
Bruce
www.Glasair.org
robin02(at)mindspring.com Guest
Posted: Sun Oct 31, 2010 11:16 am Post subject: Bent tailwheel, |
John, I built a Glasair 1 TD in 1984 and still fly it. The problem you described happened to me early on. I reinstalled the strut with the mill fiber as the manual indicated and added bi=directional cloth around the outside and onto the fuselage. It was probably 4-6 layers. No problems since. Robin Young 286YM.
----->Got a buddy with a II TD and 40 hrs total time, tailwheel assy bent to one
| Quote: | side, easy enough to fix and strengthen but is this a common problem? He
John Bolding
Posted: Sun Oct 31, 2010 12:06 pm Post subject: Bent tailwheel, |
Thanks for the reply Robin but the part that bent is the steel piece that
the wheel mounts in, any problems there?
Thanks John
Posted: Mon Nov 01, 2010 9:14 am Post subject: Bent tailwheel, |
John, the fork is not where the streeses showed on mine. I have gone to the Grove gear and increased my gross to 1900lbs from the original 1500lb. landing weight. Still there has been no problem. RObin
Posted: Mon Nov 01, 2010 9:23 am Post subject: Bent tailwheel, |
And I'll bet you make wheel landings rather than full stall.
Bruce
www.Glasair.org
Posted: Mon Nov 01, 2010 9:55 am Post subject: Bent tailwheel, |
Yep...all wheel landings. RObin
