		John Bolding
				 Posted: Sat Oct 30, 2010 4:41 pm    Post subject: Bent tailwheel, |
				Got a buddy with a II TD and 40 hrs total time,  tailwheel assy bent to one
 side,  easy enough to fix and strengthen but is this a common problem?  He
 operates off grass but smooth.
 John
  |  | - The Matronics Glasair-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Glasair-List |
		bgray(at)glasair.org Guest
				 Posted: Sun Oct 31, 2010 7:18 am    Post subject: Bent tailwheel, |
				Yes.
 Bruce
 www.Glasair.org
		robin02(at)mindspring.com Guest
				 Posted: Sun Oct 31, 2010 11:16 am    Post subject: Bent tailwheel, |
				John, I built a Glasair 1 TD in 1984 and still fly it. The problem you described happened to me early on.  I reinstalled the strut with the mill fiber as the manual indicated and added bi=directional cloth around the outside and onto the fuselage.  It was probably 4-6 layers.  No problems since.  Robin Young 286YM.
 ----->Got a buddy with a II TD and 40 hrs total time,  tailwheel assy bent to one
  	  | Quote: | 	 		  side,  easy enough to fix and strengthen but is this a common problem?  He
 John
		John Bolding
				 Posted: Sun Oct 31, 2010 12:06 pm    Post subject: Bent tailwheel, |
				Thanks for the reply Robin but the part that bent is the steel piece that
 the wheel mounts in,   any problems there?
 Thanks  John
				 Posted: Mon Nov 01, 2010 9:14 am    Post subject: Bent tailwheel, |
				John, the fork is not where the streeses showed on mine.  I have gone to the Grove gear and increased my gross to 1900lbs from the original 1500lb. landing weight. Still there has been no problem. RObin
				 Posted: Mon Nov 01, 2010 9:23 am    Post subject: Bent tailwheel, |
				And I'll bet you make wheel landings rather than full stall.
 Bruce
 www.Glasair.org
				 Posted: Mon Nov 01, 2010 9:55 am    Post subject: Bent tailwheel, |
				Yep...all wheel landings. RObin
