Rivet Set Recommendation?
sean(at)stephensville.com
PostPosted: Mon Nov 15, 2010 7:07 am    Post subject: Rivet Set Recommendation? Reply with quote
What have others used for a rivet set to get the rivets on the fuse
skins next to the spar carry through in the attached pic? I don't have
a swivel flush set, but maybe that would work?
-Sean #40303
 Filesize:  1 MB
 Viewed:  5659 Time(s)
Neal.George(at)hurlburt.a
PostPosted: Mon Nov 15, 2010 8:54 am    Post subject: Rivet Set Recommendation? Reply with quote
I believe I'd back-shoot those...
neal
What have others used for a rivet set to get the rivets on the fuse skins
next to the spar carry through in the attached pic? I don't have a swivel
-Sean #40303
smime.p7s
 Filename:  smime.p7s
 Filesize:  5.09 KB
 Downloaded:  455 Time(s)
PostPosted: Mon Nov 15, 2010 10:39 am    Post subject: Rivet Set Recommendation? Reply with quote
The shop side of these are inside the side channel, so they can't be
back shot. The forward ones can, but not the aft side.
neal
-Sean #40303
seipel(at)seznam.cz
PostPosted: Mon Nov 15, 2010 11:08 am    Post subject: Rivet Set Recommendation? Reply with quote
I used http://www.yardstore.com/browse.cfm/4,3673.html
The face is curved enough to give you room for the rivet gun and still
keep it flat on the rivet.
PJ Seipel
RV-10 #40032
skins next to the spar carry through in the attached pic? I don't have a
-Sean #40303
 Filesize:  9.34 KB
 Viewed:  5648 Time(s)
PostPosted: Mon Nov 15, 2010 2:27 pm    Post subject: Rivet Set Recommendation? Reply with quote
Thanks for the link. For some reason the Yard Store slipped my mind.
I'm wondering if I'd get additional use out of a flush "C" set which
also seems like it would do the job.
http://www.yardstore.com/browse.cfm/4,3664.html
-Sean #40303
PJ Seipel
RV-10 #40032
> Thanks,
> -Sean #40303
Andy Turner
PostPosted: Mon Nov 15, 2010 7:29 pm    Post subject: Re: Rivet Set Recommendation? Reply with quote
I worried about those rivets and put them off for a while, as well as the rivets around the rear spar attach. Turned out though that my Avery swivel flush set worked fine. I pushed the rubber guard up against the spar, and there was just enough room to get good meat on the rivet, if that makes sense.
Andy Turner
PostPosted: Sat Nov 20, 2010 2:29 pm    Post subject: Rivet Set Recommendation? Reply with quote
Just an update for those not to the fuse side skins yet. I actually
went with the 7 1/2 inch version of what PJ linked below just to make
sure I cleared the spar with the rivet gun.
http://www.yardstore.com/browse.cfm/4,3741.html
This worked great for the fuse side skins next to the spar. I wish I
had this set when doing the bottom wing skins next to the flap attach
also. One note, that is similar for other longer rivet sets. It takes
quite a bit more pressure with the added length. This is one of those
places that I wished I had gotten a 3x gun instead of a 2x.
-Sean #40303 (long and nasty section 29 almost complete)
> still keep it flat on the rivet.
> PJ Seipel
> RV-10 #40032
>> have a
>> Thanks,
>> -Sean #40303
rv10flyer
PostPosted: Sat Nov 20, 2010 3:06 pm    Post subject: I used my long back rivet set Reply with quote
on the rivets near flap hinges and these. Already had this tool and did not want to buy another tool for just a few places. Just put masking tape over rivets to help keep it from sliding, have a helper on the other side and keep your set straight.
Wayne G.
