Coming Home to a Cheetah
david555(at)cox.net
PostPosted: Mon Dec 27, 2010 12:12 pm    Post subject: Coming Home to a Cheetah Reply with quote
I just purchased a 79 Cheetah with the 160 HP engine – I had a 77 Cheetah 23 years ago with 150 HP engine. It was a great airplane, but I cannot remember how I used to fly it. Landing with or without flaps, Take off with or without flaps. I’m based (at) CPK – Chesapeake Va. – near sea Level. I appreciate any input. I hope no question is too stupid to ask. Thanks David O Boone
quinn_tom(at)tqiinc.com
PostPosted: Mon Dec 27, 2010 3:33 pm    Post subject: Coming Home to a Cheetah Reply with quote
David, what does the POH say?
Sent on the Sprint® Now Network from my BlackBerry®From: "David Boone" <david555(at)cox.net>
Sender: owner-teamgrumman-list-server(at)matronics.com
Date: Mon, 27 Dec 2010 15:06:53 -0500
To: <teamgrumman-list(at)matronics.com>
ReplyTo: teamgrumman-list(at)matronics.com
Subject: TeamGrumman-List: Coming Home to a Cheetah
I just = purchased a 79 Cheetah with the 160 HP engine – I had a 77 Cheetah = 23 years ago with 150 HP engine. It was a great airplane, but I cannot = remember how I used to fly it. Landing with or without flaps, Take off = with or without flaps. I’m based (at) CPK – Chesapeake Va. = – near sea Level. I appreciate any input. I hope no question is = too stupid to ask. Thanks David O = Boone
David BTW I own a 77 Tiger and I'm also based at CPK 249RR
david555(at)cox.net
PostPosted: Mon Dec 27, 2010 5:51 pm    Post subject: Coming Home to a Cheetah Reply with quote
Tom, I haven’t received the Cheetah yet – should be within the next few days weather permitting. I just recall that when flying the previous Cheetah, I did not follow the POH for takeoff, I think I used flaps and the POH did not call for them. I believe it was something that many members of the AYA recommended and I tried it and agreed – but truthfully I do not trust my memory. David
From: owner-teamgrumman-list-server(at)matronics.com [mailto:owner-teamgrumman-list-server(at)matronics.com] On Behalf Of quinn_tom(at)tqiinc.com
Sent: Monday, December 27, 2010 6:26 PM
Subject: Re: Coming Home to a Cheetah
Subject: Coming Home to a Cheetah
¦~²
PostPosted: Mon Dec 27, 2010 6:13 pm    Post subject: Coming Home to a Cheetah Reply with quote
David the POH calls for a no flap TO. Some people put in about 7 degrees of flaps on TO just about the same as full aileron deflection. I've never done it but plan to some day for short field TOs
Date: Mon, 27 Dec 2010 20:49:06 -0500
Subject: RE: TeamGrumman-List: Coming Home to a Cheetah
Tom, I haven’t received the Cheetah yet = – should be within the next few days weather permitting. I just = recall that when flying the previous Cheetah, I did not follow the POH = for takeoff, I think I used flaps and the POH did not call for them. I = believe it was something that many members of the AYA recommended and I = tried it and agreed – but truthfully I do not trust my memory. = David
From:= = owner-teamgrumman-list-server(at)matronics.com = [mailto:owner-teamgrumman-list-server(at)matronics.com] On Behalf Of = quinn_tom(at)tqiinc.com
Sent: Monday, December 27, 2010 6:26 = PM
Subject: Re: = TeamGrumman-List: Coming Home to a = Cheetah
David, = what does the POH say?
Sent on the Sprint=AE Now = Network from my BlackBerry=AE
Sender: = owner-teamgrumman-list-server(at)matronics.com =
Date: = Mon, 27 Dec 2010 15:06:53 = -0500
To: = <teamgrumman-list(at)matronics.com><= /p>
ReplyTo: teamgrumman-list(at)matronics.com =
Subject: TeamGrumman-List: Coming Home to a = Cheetah
I just =3D purchased a 79 Cheetah with the 160 HP = engine – I had a 77 Cheetah =3D 23 years ago with 150 HP engine. = It was a great airplane, but I cannot =3D remember how I used to fly it. = Landing with or without flaps, Take off =3D with or without flaps. = I’m based (at) CPK – Chesapeake Va. =3D – near sea Level. = I appreciate any input. I hope no question is =3D too stupid to ask. = Thanks David O =3D Boone
/span>
/span>
/span>
/span>
/span>
/span>
/span>
/span>
5
/span>
6
/span>
7
/span>
8
/span>
9
=A6~=B2
flyv35b(at)minetfiber.com
PostPosted: Tue Dec 28, 2010 5:58 am    Post subject: Coming Home to a Cheetah Reply with quote
Most people probably follow the POH and take off without flaps. But you can get off the ground at a lower speed and in a shorter distance with partial flaps. You just may not be able to climb quite as fast (ROC) with the flaps even though the angle of climb MIGHT be steeper. I always (almost anyway) land with full flaps at minimum touchdown speed and typically hold the nosewheel off for some time after that. Just don't land at high speed on the nosewheel and start the POI that results in a prop strike many times.
Cliff
PostPosted: Tue Dec 28, 2010 5:59 am    Post subject: Coming Home to a Cheetah Reply with quote
David, if you like maybe we can meet to discuss airplanes sometime. I have some tips on the Grummans that may be helpful (maintenance, flying, etc)
ArjayS(at)AOL.COM
PostPosted: Tue Dec 28, 2010 6:19 am    Post subject: Coming Home to a Cheetah Reply with quote
Ditto
But Roy taught me to bleed off the flaps on T/O while in groud effect. It's
a habit I use to this day. Anyone else?
Rj Siegel CEO/LoPresti Aviation Engineering
[quote] Most people probably follow the POH and take off without flaps.  But you
PostPosted: Tue Dec 28, 2010 6:35 am    Post subject: Coming Home to a Cheetah Reply with quote
That works, but I think I'd leave the flaps down if there was an obstacle not far ahead and then "milk" the flaps up after clearing the obstacle. The 4 place planes have enough extra power for the plane to climb well with partial flaps, like was mentioned about matching the flap to the maximum aileron down deflection. There is not much extra drag at that point.
Cliff
allenc3(at)bellsouth.net
PostPosted: Tue Dec 28, 2010 9:56 am    Post subject: Coming Home to a Cheetah Reply with quote
Always hate to get the flap thing going again, but what I usually tell the POH (no flap) people is come on over to my 2600 ft Florida grass strip on say, July 4th when the temp and humidity is pushing 95 and the grass is growing like 1 inch a day and take off with no flaps.
Claude Allen
Sent from my iPad
On Dec 28, 2010, at 9:15 AM, ArjayS(at)AOL.COM (ArjayS(at)AOL.COM) wrote:
[quote]Ditto
But Roy taught me to bleed off the flaps on T/O while in groud effect. It's a habit I use to this day. Anyone else?
Cliff
pitts_pilot(at)bellsouth.
PostPosted: Tue Dec 28, 2010 10:06 am    Post subject: Coming Home to a Cheetah Reply with quote
Did you just invite the SE region to a flap-flap party on the 4th???  Smile
Linn
On 12/28/2010 12:52 PM, allenc3(at)bellsouth.net (allenc3(at)bellsouth.net) wrote: [quote] Always hate to get the flap thing going again, but what I usually tell the POH (no flap) people is come on over to my 2600 ft Florida grass strip on say, July 4th when the temp and humidity is pushing 95 and the grass is growing like 1 inch a day and take off with no flaps.
Claude Allen
Sent from my iPad
Ditto
Cliff
//www.aeroelectric.com%22">www.aeroelectric.com
"3D%22http://www.buildersbooks.com%22">www.buildersbooks.com
://www.homebuilthelp.com%22">www.homebuilthelp.com
onics.com/contribution%22">http://www.matronics.com/contribution
onics.com/Navigator?TeamGrumman-List%22">http://www.matronics.com/Navigator?TeamGrumman-List
atronics.com%22">http://forums.matronics.com
rdp123(at)verizon.net
PostPosted: Tue Dec 28, 2010 10:48 am    Post subject: Coming Home to a Cheetah Reply with quote
Claude, just curious about how much flap do you use?
Rick Tiger 4542N SMO
On Dec 28, 2010, at 9:52 AM, allenc3(at)bellsouth.net (allenc3(at)bellsouth.net) wrote:
[quote]Always hate to get the flap thing going again, but what I usually tell the POH (no flap) people is come on over to my 2600 ft Florida grass strip on say, July 4th when the temp and humidity is pushing 95 and the grass is growing like 1 inch a day and take off with no flaps.
Claude Allen
Sent from my iPad
Ditto
Cliff
href="x-msg://31/3D%22http://www.aeroelectric.com%22">www.aeroelectric.com
href="x-msg://31/3D%22http://www.buildersbooks.com%22">www.buildersbooks.com
href="x-msg://31/3D%22http://www.homebuilthelp.com%22">www.homebuilthelp.com
href="x-msg://31/3D%22http://www.matronics.com/contribution%22">http://www.matronics.com/contribution
href="x-msg://31/3D%22http://www.matronics.com/Navigator?TeamGrumman-List%22">http://www.matronics.com/Navigator?TeamGrumman-List
href="x-msg://31/3D%22http://forums.matronics.com%22">http://forums.matronics.com
PostPosted: Tue Dec 28, 2010 6:36 pm    Post subject: Coming Home to a Cheetah Reply with quote
About 1/3 or even with full Aileron deflection. As soon as I get positive climb, I bleed them off.
Claude Allen
Sent from my iPad
On Dec 28, 2010, at 1:44 PM, Rick Pollack <rdp123(at)verizon.net (rdp123(at)verizon.net)> wrote:
[quote]Claude, just curious about how much flap do you use?
On Dec 28, 2010, at 9:52 AM, [url=mailto:allenc3(at)bellsouth.net]allenc3(at)bellsouth.net (allenc3(at)bellsouth.net)[/url] wrote:
Claude Allen
Sent from my iPad
On Dec 28, 2010, at 9:15 AM, [url=mailto:ArjayS(at)AOL.COM]ArjayS(at)AOL.COM (ArjayS(at)AOL.COM)[/url] wrote:
Ditto
Cliff
http://www.aeroelectric.com">www.aeroelectric.com
"http://www.homebuilthelp.com">www.homebuilthelp.com
http://www.matronics.com/contribution">http://www.matronics.com/contribution
t">http://www.matronics.com/Navigator?TeamGrumman-List
ums.matronics.com">http://forums.matronics.com
JHOSLER(at)epri.com
PostPosted: Wed Dec 29, 2010 9:14 am    Post subject: Coming Home to a Cheetah Reply with quote
If flaps are used for take-off I would not recommend bleeding them off until well after all obstacles are cleared. You could find yourself descending back onto the runway or into the power lines you are trying to clear.
John
From: owner-teamgrumman-list-server(at)matronics.com [mailto:owner-teamgrumman-list-server(at)matronics.com] On Behalf Of ArjayS(at)AOL.COM
Sent: Tuesday, December 28, 2010 9:16 AM
Subject: Re: TeamGrumman-List: Coming Home to a Cheetah
Ditto
Cliff
teamgrumman(at)yahoo.com
PostPosted: Wed Dec 29, 2010 10:08 am    Post subject: Coming Home to a Cheetah Reply with quote
Hi David,
Years ago I made the conscience decision to always land with full flaps. On occasion, I'll practice no flap landings just in case the flaps don't come down. I flew out of Lancaster, CA where the wind direction varied but the wind speed was rarely calm. Landing with full flaps in a 50 knot wind 20 degrees off the nose became a no-brainer.
As for take-off, I always take off with an inch or two of flaps. The maximum deflection is equal to the aileron down deflection. The only thing you need to remember is retracting the flaps once underway.
Gary
Sent: Mon, December 27, 2010 12:06:53 PM
* AeroElectric www.homebuilth-= -->
david555(at)cox.net
PostPosted: Thu Dec 30, 2010 7:11 pm    Post subject: Coming Home to a Cheetah Reply with quote
Tom, I think that would be good. I will be out of country till the middle of January. Thanks David
Sent: Tuesday, December 28, 2010 8:57 AM
Subject: RE: Coming Home to a Cheetah
Subject: Re: = Coming Home to a = Cheetah
Subject: Coming Home to a = Cheetah
<=/span> <=/span>www.aeroelectric.comwww.buildersbooks.com<=/o:p>www.homebuilthelp.com<=/o:p>http://www.matronics.c=/span>
/span>
/span>
/span>
/span>
=A6~=B2
/span>
5
/span>
6
/span>
7
/span>
8
/span>
9
/span>
/span>
/span>
/span>
/span>
/span>
5
/span>
6
/span>
7
/span>
8
/span>
9
5
6
7
8
9
5
6
7
¦·›~‰í²,Þg(–ŠÓMÓGq¢zÁ®
PostPosted: Thu Dec 30, 2010 7:20 pm    Post subject: Coming Home to a Cheetah Reply with quote
Better yet .... come to SSI for the convention and learn more in a few days than you'll learn in years otherwise .... and you'll have a lot of fun too!!!
Linn
On 12/30/2010 10:09 PM, David Boone wrote: [quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
From: owner-teamgrumman-list-server(at)matronics.com (owner-teamgrumman-list-server(at)matronics.com) [mailto:owner-teamgrumman-list-server(at)matronics.com (owner-teamgrumman-list-server(at)matronics.com)] On Behalf Of quinn_tom(at)tqiinc.com (quinn_tom(at)tqiinc.com)
To: teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)
From: "David Boone" <david555(at)cox.net> (david555(at)cox.net)
Sender: owner-teamgrumman-list-server(at)matronics.com (owner-teamgrumman-list-server(at)matronics.com)
To: <teamgrumman-list(at)matronics.com> (teamgrumman-list(at)matronics.com)
ReplyTo: teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)
From:= = owner-teamgrumman-list-server(at)matronics.com (owner-teamgrumman-list-server(at)matronics.com) = [mailto:owner-teamgrumman-list-server(at)matronics.com (owner-teamgrumman-list-server(at)matronics.com)] On Behalf Of = quinn_tom(at)tqiinc.com (quinn_tom(at)tqiinc.com)
From: "David Boone" <david555(at)cox.net> (david555(at)cox.net) =
Sender: = owner-teamgrumman-list-server(at)matronics.com (owner-teamgrumman-list-server(at)matronics.com) =
To: = <teamgrumman-list(at)matronics.com> (teamgrumman-list(at)matronics.com)<= /p>
ReplyTo: teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com) =
/span>
/span>
/span>
/span>
=A6~=B2
/span>
5
/span>
6
/span>
7
/span>
8
/span>
9
/span>
/span>
/span>
/span>
/span>
/span>
5
/span>
6
/span>
7
/span>
8
/span>
9
5
6
7
8
9
5
6
7
¦·›~‰í²,Þ g(–ŠÓMÓGq¢zÁ®
8 [b]
PostPosted: Wed Jan 12, 2011 11:00 am    Post subject: Coming Home to a Cheetah Reply with quote
David,
            I see a new Cheetah on the flight line at KCPK, is that yours?
Tom Quinn
2499RR
From: owner-teamgrumman-list-server(at)matronics.com [mailto:owner-teamgrumman-list-server(at)matronics.com] On Behalf Of David Boone
Sent: Thursday, December 30, 2010 10:09 PM
/span>
/span>
/span>
/span>
=A6~=B2
/span>
5
/span>
6
/span>
7
/span>
8
/span>
9
/span>
¦·›~‰í²,Þ
g(–ŠÓMÓGq¢zÁ®
/span>
/span>
/span>
/span>
/span>
5
/span>
6
/span>
7
/span>
8
/span>
9
5
6
7
8
9
5
6
7
8
9
david555(at)cox.net
PostPosted: Fri Jan 14, 2011 8:16 am    Post subject: Coming Home to a Cheetah Reply with quote
yes
From: owner-teamgrumman-list-server(at)matronics.com [mailto:owner-teamgrumman-list-server(at)matronics.com] On Behalf Of Tom Quinn
Sent: Wednesday, January 12, 2011 1:58 PM
David,
Tom Quinn
2499RR
/span>
/span>
/span>
/span>
=A6~=B2
/span>
5
/span>
6
/span>
7
/span>
8
/span>
9
/span>
/span>
/span>
/span>
/span>
¦·›~‰í²,Þ
g(–ŠÓMÓGq¢zÁ®
/span>
5
/span>
6
/span>
7
/span>
8
/span>
9
5
6
7
8
9
5
6
7
8
9
/o:p>
/o:p>
/o:p>
/o:p>
/o:p>
/o:p>
5
Checked by AVG - Date: 01/14/11 02:34:00
