Hole in fuselage under wing
daveleikam(at)wi.rr.com
PostPosted: Sat Jan 08, 2011 10:11 pm    Post subject: Hole in fuselage under wing Reply with quote
How have others closed up the small opening or hole on each side of the fuselage, just below and aft of the leading edge of the wing?
Thanks.
David Leikam
RV10
N89DA
Gas in the wings, getting ready to light the fire!
Tim Olson
PostPosted: Sun Jan 09, 2011 8:43 am    Post subject: Hole in fuselage under wing Reply with quote
I just filled mine with clear silicone and then shaved it flush. It's good to seal it against carbon monoxide, but how you seal it probably isn't a big deal. Fiberglass and epoxy and fairing filler would work fine pre-paint. I did mine after painting. It's not really too easily noticed.
Thanks.
David Leikam
RV10
N89DA
rv10builder(at)verizon.ne
PostPosted: Sun Jan 09, 2011 9:37 am    Post subject: Hole in fuselage under wing Reply with quote
I prosealed an aluminum piece over the hole.
Sent: Saturday, January 08, 2011 10:08 PM
To: "RV-10 matronics" <rv10-list(at)matronics.com>
Subject: Hole in fuselage under wing
Thanks.
David Leikam
RV10
N89DA
Ron B.
PostPosted: Sun Jan 09, 2011 11:47 am    Post subject: Re: Hole in fuselage under wing Reply with quote
I just used proseal before painting. Paint sticks to proseal.
Ron
PostPosted: Sun Jan 09, 2011 5:58 pm    Post subject: Hole in fuselage under wing Reply with quote
Any idea why the hole is there?
David Leikam
RV10
N89DA
> Thanks.
> David Leikam
> RV10
> N89DA
