daveleikam(at)wi.rr.com Guest
Posted: Sat Jan 08, 2011 10:11 pm Post subject: Hole in fuselage under wing |
How have others closed up the small opening or hole on each side of the fuselage, just below and aft of the leading edge of the wing?
Thanks.
David Leikam
RV10
N89DA
Gas in the wings, getting ready to light the fire!
Tim Olson
Posted: Sun Jan 09, 2011 8:43 am Post subject: Hole in fuselage under wing |
I just filled mine with clear silicone and then shaved it flush. It's good to seal it against carbon monoxide, but how you seal it probably isn't a big deal. Fiberglass and epoxy and fairing filler would work fine pre-paint. I did mine after painting. It's not really too easily noticed.
On Jan 9, 2011, at 12:08 AM, David Leikam <daveleikam(at)wi.rr.com> wrote:
Thanks.
David Leikam
RV10
N89DA
Posted: Sun Jan 09, 2011 9:37 am Post subject: Hole in fuselage under wing |
I prosealed an aluminum piece over the hole.
Sent: Saturday, January 08, 2011 10:08 PM
To: "RV-10 matronics" <rv10-list(at)matronics.com>
Subject: Hole in fuselage under wing
Thanks.
David Leikam
RV10
N89DA
Ron B.
Posted: Sun Jan 09, 2011 11:47 am Post subject: Re: Hole in fuselage under wing |
I just used proseal before painting. Paint sticks to proseal.
Ron
Posted: Sun Jan 09, 2011 5:58 pm Post subject: Hole in fuselage under wing |
Any idea why the hole is there?
David Leikam
RV10
N89DA
On Jan 9, 2011, at 10:40 AM, Tim Olson wrote:
> Thanks.
> David Leikam
> RV10
> N89DA
