"Emacs!" in Response
bakerocb
PostPosted: Tue Jan 25, 2011 4:50 am    Post subject: "Emacs!" in Response Reply with quote
1/25/2011
Hello Bob Falstad, You wrote (see copied below): "However, your response had
three"Emacs!" in it that appear to refer to graphics that I can't view."
I have the same problem with Bob Nuckolls' postings, but here is a solution
for me:
a) Go to the Matronics forum web site.
http://forums.matronics.com/
b) Click on the aeroelectric list.
http://forums.matronics.com/viewforum.php?f=3
c) Click on the original subject of the email(s) in question. (Comm Antenna
& SWR Reading -- Too High?)
http://forums.matronics.com/viewtopic.php?t=78934
d) Scroll down to the posted email in question and you should be able to see
any attached graphics or photos.
Please let me / us know how this works for you.
'OC' Baker Says: "The best investment we can make is the time and effort to
gather and understand knowledge."
PS to all: Bob, Bob, Who has got the Bob? Or which Bob?
It is pretty important to me (and I am sure many others) to know which Bob
author that they are reading or which Bob is being addressed.
Would all posters please identify in each case by last name which Bob they
are addressing and which Bob is writing by last name in each instance? Many
thanks.
Time: 10:38:42 AM PST US
Subject: Re: "Emacs!" in Response: Was Comm Antenna &
SWR Reading
Many thanks for your quick and detailed response. However, your response
had three
"Emacs!" in it that appear to refer to graphics that I can't view. I
searched
the AeroElectric lists archives and the most detailed message re "Emacs!"
was yours dated July 31, 2009. I couldn't find any other relevant messages
on how to view your graphics/photos.
I'm using a Macbook with OS 10.4.6 (Snow Leopard) that also has a full
install
of Windows XP in it. I opened your reply in three different browsers --
Safari,
Firefox and Internet Explorer 8 but no joy.
Any thoughts on how I can retrieve/view your "Emacs!" graphical inserts?
Best regards,
Bob Falstad
PostPosted: Tue Jan 25, 2011 6:45 am    Post subject: Re: Emacs! Reply with quote
I agree with Bakerocb. It seems that pictures have been removed from the daily email digest and replaced with Emacs! If I want to see the pictures, I go to http://forums.matronics.com/viewforum.php?f=3 to view them.
Joe
Joe Gores
JohnInReno
PostPosted: Tue Jan 25, 2011 7:13 am    Post subject: "Emacs!" in Response Reply with quote
No problem here. I get the individual emails. Is the problem only on the
digest?
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=328404#328404
John Morgensen
RV-9A - Born on July 3, 2013
RV4 - for sale
Float Flyr
PostPosted: Tue Jan 25, 2011 11:42 am    Post subject: "Emacs!" in Response Reply with quote
Having read this thread from the beginning again I would do a continuity
test for ground from the ground plane back to the grounded case of the
radio. While you are at it do a continuity test for the centre conductor of
the RG400. I've seen similar readings caused by a crack in the centre
conductor of coax.
As for the ground plane assuming your ground bond is good to your aluminium
and the centre conductor is intact you may want to try bonding the aluminium
to the aircraft ground system with a separate wire. I've seen instances
where that had to be done on fibreglass boats.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
danfm01(at)butter.toast.n
PostPosted: Tue Jan 25, 2011 11:46 am    Post subject: "Emacs!" in Response Reply with quote
On 01/25/2011 07:11 AM, John Morgensen wrote:
--> AeroElectric-List message posted by: John Morgensen <john(at)morgensen.com> (john(at)morgensen.com)
No problem here. I get the individual emails. Is the problem only on the digest?
Enclosures are not posted to the digest lists. Here is an excerpt from the Matronics FAQ at
www.matronics.com/ftp/Archives/RV-List.FAQ.html
[b]Limited posting of enclosures such as pictures, documents, and spreadsheets
is supported on the Lists. There are a number of restrictions, and these
are detailed below. Please abide by the rules put forth regarding the
content of enclosures.
These are some of the features and limits of enclosures on the Matronics
lists:
1) Enclosures will only be posted to the Real Time version of the Lists.
2) Enclosures will NOT be included in the Daily Digest version of the Lists.
[/b]
The full FAQ file is too big to quote here.
PostPosted: Tue Jan 25, 2011 11:56 am    Post subject: "Emacs!" in Response Reply with quote
Wires use to connect RF ground systems to any other ground
system are never useful for controlling antenna system
performance.
Float Flyr
PostPosted: Tue Jan 25, 2011 12:48 pm    Post subject: "Emacs!" in Response Reply with quote
The bond I was referring to would be to the same system. Doing that could
nullify the effects of a bad connection to the braid at the antenna end.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
