Rotax Relapse
Goto page Previous  1, 2, 3, 4  Next
NeilsenRM(at)comcast.net
PostPosted: Fri May 05, 2006 5:59 am    Post subject: Rotax Relapse Reply with quote
Hey Richard
I don't want to get in the middle of any mud slinging but you could look at
a VW. The price would be comparable but I'm sorry you would have to live
with a bit more power if you bought the big engine.
Sorry I just couldn't resist.
Rick Neilsen
Redrive VW powered MKIIIc
Richard Pike
PostPosted: Fri May 05, 2006 6:22 am    Post subject: Rotax Relapse Reply with quote
Not to worry, I have enjoyed your posts for years and know that you are
not a slinger of mud.
Actually got very close to going to a VW with Valley reduction drive on
it for my MKIII, I was really impressed watching Valley's demonstrator
airplane several years ago at Oshkosh, may go that way when the 582
comes up for overhaul. Most of the time I have enough power, since I
usually fly solo. But carrying a passenger out of my short strip with
big power lines nearby - more power is a good thing.
2 considerations:
What do you figure your total powerplant weight is?
How quiet is it? My airstrip is right beside the subdivision, so my 582
has both after muffler and intake silencers on it, it is vital that I be
a quiet neighbor. Is the VW powersystem really quiet? Or just sort of
"Street legal but loud?" Because if it is not quiet, then I would have
to make it quiet, and that would probably be more weight.
Richard Pike
MKIII N420P (420ldPoops)
Richard & Martha Neilsen wrote:
Hey Richard
Rick Neilsen
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
PostPosted: Fri May 05, 2006 6:59 am    Post subject: Rotax Relapse Reply with quote
Richard
I really don't have a weight but I figure it is about 20lbs. more than a
Rotax 912. My VW uses the Valley redrive and isn't as smooth as I would
like. There are two gear redrives now available that will work on a VW and
hopefully they have some form of harmonic dampening. My redrive doesn't
other than the belt.
The noise I'm told is about like a GA airplane. Inside the cockpit it is
loud. I have a four into one exhaust system and it isn't too bad due to the
low RPMs. It doesn't scream like the high RPM VW dune buggy engines. Those
that fly their VWs with four short pipes make some real noise but my engine
noise is hard to tell from the prop noise. I had a motor cycle muffler on
the engine at one point. It was a baffled glass pack that blew the packing
after a few hours so it didn't contribute much to noise reduction. More
importantly I found it cut the power significantly so I don't use it any
more.
Rick Neilsen
Dennis.Kirby(at)kirtland.
PostPosted: Fri May 05, 2006 7:41 am    Post subject: Rotax Relapse Reply with quote
<< Only a total idiot would not realize how far superior a 4 stroke is to a
2 stroke. Michael A. Bigelow >>
Geez, Mike - that's kind of a broad, inflammatory statement against many
folks on this List. Do you ever wonder why your posts are so often a source
of resentment amongst List members? There are more gracious ways to espouse
your own opinions than calling our 2-stroke pilots "total idiots."
Dennis Kirby
PostPosted: Fri May 05, 2006 8:18 am    Post subject: Rotax Relapse Reply with quote
to espouse
Dennis Kirby
Yep! I guess "2 stroke" pilots encompasses about 99% of the Kolb
List. I still fly them on occassion, when the opportunity arises.
slyck(at)frontiernet.net
PostPosted: Fri May 05, 2006 9:42 am    Post subject: Rotax Relapse Reply with quote
Hey, I run a 4 stroke and am only slightly impaired.........
-senility setting in v e r y s l o w l y
-BB do not archive
On 5, May 2006, at 11:41 AM, Kirby Dennis Contr MDA/AL wrote:
<Dennis.Kirby(at)kirtland.af.mil>
to a
many
source
espouse
Dennis Kirby
ElleryWeld(at)AOL.COM
PostPosted: Fri May 05, 2006 6:00 pm    Post subject: Rotax Relapse Reply with quote
I also have over 330 hours on a 447 rotax 2 stroke in a firestar without a
glitch just my opinion but if you know enough about what you are running for an
engine and know how to keep it up to snuff then you will be happy with it for
a long time other than the loud noise these make I am very pleased with the
preformance of mine
on the other hand if you dont know what you are doing, then keep your paws
out of it and take it to someone who knows what it needs to get the longer life
out of it, and a properly adjusted prop is alot of the adjustment , I think
only worth what you paid for it
Ellery in a loud Firestar that has never missed a beat for 336 hrs and still
going strong
beauford(at)tampabay.rr.c
PostPosted: Sat May 06, 2006 6:31 am    Post subject: Rotax Relapse Reply with quote
What you say makes sense to me, Ellery...Thanks for
the perspective...
That's why it was taken to Lockwood when the
defective choke piston in the Bing caused all the carbon
problems and I couldn't figure it out....
Yesterday I unloaded the prop slightly... from 6450
WOT to 6600... and went ahead and replaced the fan belt..
it was marginally loose and would not tighten enough to get
it quite to specs. Replaced it to rule it out as a factor... And also
because George Alexander claimed he could hear a high-pitched
squeal as I flew past on downwind with the old belt... I assured
George that the squeal was likely coming from the pilot, not the
fan belt... Anyway, he claims he cannot hear the squeal any longer
after the belt was replaced... (the old one wasn't really that loose).
Also ran premium gas with PZ AC at 50 to 1 yesterday.
Result was some improvement, but it is still not where it
needs to be: Front cylinder CHT remains 30 - 35 hotter than the rear
and still wants to run around 390 at 6000 cruise. This makes me
a tad uncomfortable, but it beats the 400 plus it had been showing and
I
have about resigned myself to just watching it run to see what happens
next. Believe it is stemming from a slightly tight (green dot) piston
in the
front jug and it is just going to have to wear a little of that
tightness out of itself
before things settle down. Will go ahead and run 50 to 1 oil until
the
thing loosens up or blows up.
Looking at the temp difference between the cylinders, got to
speculating about the Rotax rationale for publishing a maximum
acceptable CHT delta... is it:
a. Because a large temp difference is an INDICATOR of an abnormal
condition that requires immediate attention...? Or is it...
b. Because a large temp difference sets up asymetric stresses in
components which can CAUSE failures...?
Or is it a combination of both....?
Obviously, I'm thinking about the implications of continuing to run
this thing with the existing CHT differential... the EGT's are
running identically... no difference between cylinders.
For anyone who is interested, it looks to me
like the Gates belt cross-reference for the 447 is
the Gates #1240. Adjusted up OK... will look
at it again after a couple of hours to see how it's doing.
Still got the Timex
Beauford
FF#076
PostPosted: Sat May 06, 2006 7:04 am    Post subject: Rotax Relapse Reply with quote
| Beauford
What kind of engine instruments are you using? Steam gauges or the
digital thing, ahhhhhhhhhhh....I remembered the name, EIS? Are they
temperature compensated? or do you have to take care of that operation
in your head?
Been a long time since I worried about temp compesation, but the base
line is 68 or 70F. Based on OAT, one must add or subtract the
difference to get "actual temp".
If unloading the prop brought the CHT down and the EGT is in the
green, seems to me you are headed in the right direction.
Nothing associated with our sport is "precision", from airplanes, to
engines, to instruments, and pilots. If the 447 is making power,
running good, instruments are in the green, I'd fly and enjoy it. If
it breaks, you know what to do. Wink
PostPosted: Sat May 06, 2006 7:53 am    Post subject: Rotax Relapse Reply with quote
operation
in your head?
Eugene Zimmerman
PostPosted: Sat May 06, 2006 7:54 am    Post subject: Rotax Relapse Reply with quote
On May 6, 2006, at 10:43 AM, Beauford wrote:
Still got the Timex
Beauford
But George is still worthy for listening to that thing squeal. Smile
Hi George!
Ooooops... excuse the "blank" I just fired...
I am running the EIS... and it is supposedly temp corrected...
Beauford
Dave Bigelow
PostPosted: Sat May 06, 2006 3:02 pm    Post subject: Re: Rotax Relapse Reply with quote
Beauford,
I've followed your 447 adventures with great interest. As I understand it, the engine ran normally after the Lockwood Aviation overhaul. You mention running with Amsoil.
A number of years ago, I used Amsoil at ratios varying from 100:1 to 50:1 in a Koenig 3 cylinder two stroke. The amsoil left a a black gunky mess in the ring area. I discontinued using it.
The rings in Rotax engines are of a design that cannot tolerate a bunch of junk in the grooves. I'd guess that when you pull the pistons and look at the rings, you'll find the Amsoil residue. When you clean things up and reassemble, try using California Power Systems AV2 two stroke oil at 50:1. It's formulated for Rotax engines. Another good choice is Pennsoil Two Stroke oil for aircooled engines.
Let us know how it goes.
Dave Bigelow
Kamuela, Hawaii
FS2, HKS 700E
George Alexander
PostPosted: Sat May 06, 2006 5:39 pm    Post subject: Rotax Relapse Reply with quote
Eugene and other interested listers....
While I would be proud to wear the Timex that works as well as Beauford's
R447, I would hate to come by it in the way he proposed. Maybe he will give
it up as broke... don't know how he can hear it ticking when he can't hear
that squeal.
Anyway, there is a brief record of his excursions yesterday in his endeavor
to deal with the problem of high CHTs.
For those who are interested, you can view this record at:
http://home.comcast.net/~kolbplanes/BeaufordCHT
Fun, Safe Flying!
George Alexander
http://gtalexander.home.att.net
PS: Eugene-best to all the 'Z' Men
DO NOT ARCHIVE
George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net
WhiskeyVictor36(at)aol.co
PostPosted: Sat May 06, 2006 6:33 pm    Post subject: Rotax Relapse Reply with quote
In a message dated 5/6/2006 9:39:54 P.M. Eastern Standard Time,
gtalexander(at)att.net writes:
George,
That was a great record you put together. Neato!
Bill Varnes
Original Kolb FireStar
Audubon NJ
ulflyer(at)verizon.net
PostPosted: Sat May 06, 2006 10:00 pm    Post subject: Rotax Relapse Reply with quote
Do you have EGT's gauges, if so what are they doing?
Just for grins, have you checked the fan belt is ok and have you have
been into the carb recently, i.e. the main jet needle. Has it been
reassembled correctly, its easy to get the needle clip on the wrong
side of the white spring cup. It will run but not properly.
jerb
At 08:05 AM 5/2/2006, you wrote:
Kolbers and Kolbettes:
Once again the mighty 447 asserts its total dominance over
a thoroughly beaten, sniveling and craven Beauford....
Last 5 hours -- Head temps are too high... they both climb steadily at =
full power, reaching
400 plus in about 20 seconds... and the fan-end cylinder remains hot, =
stabilizing
about 390 when one throttles back to normal (5800) cruise. Rear cylinder =
comes
down to about 360.
Data:
-- Engine had complete top end rebuild at Lockwood 16 hours ago...new =
pistons
and rings. Has consistently run hotter since rebuild, but not this hot =
until
last five hours.
-- Swapped plug thermocouples...verified front is hot cylinder and temp =
reads accurately
-- Same jetting as always... it previously ran at 340 CHT on these same =
jets
and with needle in this same (second) notch
-- No change in prop loading... turns 6050 static, 6450 wot in flight
-- Temps remain together up to 4400 rpm...then front takes off as =
throttle
is pushed up further...eventually gets to 40 degree difference
-- Both EGT's remain normal (1020) at WOT... 1090 at cruise.
-- Plugs are clean and pretty...good color,slightly on light side... no =
trace
of excess carbon
-- Running Amsoil Saber 100 to one, but I'm mixing it at 70 to one
-- Ran a test tank of Pennzoil AC 50 to 1, no change in problem
-- All new gaskets throughout top of engine... heads and both manifolds
are torqued and re-torqued. No evidence of leakage at head or exhaust =
gaskets.
--Have not yet pulled exhaust to verify rings are free..that is next =
step, followed
by compression check.
I'm thinking air leak. Anyone have any other "hot" ideas?
Also, is there any reliable way to leak-check the case and crank
seals without tearing down the engine...?
Beat-up Beauford
FF#076
Brandon, FL
Ralph Hoover
PostPosted: Sun May 07, 2006 1:31 pm    Post subject: Re: Rotax Relapse Reply with quote
[quote="George Alexander"]Eugene and other interested listers....
Fun, Safe Flying!
George Alexander
DO NOT ARCHIVE
Well, I know what the problem is. I am so surprised that all you expert engine and Kolbers didn't pick it up real quick. One trip to view his photo's gave me the answer..."CHEAP CIGARS"! Yep, that's it, cheap cigars. Kolbs deserve and rightly expect quality in fuel, pilot, Oil, and flying fields. Why would they or should they expect "CHEAP CIGARS"?
And most times we oblige them. But a cheap cigar? Unacceptable! Beauford, You change your cigars to something of quality and that thing will run like it was designed to do. And you can take that to the bank! Now as for “adjustable wrenches ..........”
You just need to know where to look!
Cuban smoking Ralph of Ohio!
Bill Vincent
PostPosted: Sun May 07, 2006 6:14 pm    Post subject: Rotax Relapse Reply with quote
Beauford
No wonder your engine is over heating, that big 'ole BRS is blocking the =
air.
Bill Vincent
FS II
Bill Vincent
Firestar II
Upper Peninsula of Michigan
Eugene Zimmerman
PostPosted: Mon May 08, 2006 4:39 am    Post subject: Rotax Relapse Reply with quote
On May 7, 2006, at 10:11 PM, Bill Vincent wrote:
Beauford
blocking the =
air.
Bill Vincent
FS II
Bill did you notice how much up elevator is required for straight and
level ?
I strongly suggest that he hauling a bid LOAD of youknowhat in that
photo.
Plane in that trick pict was actually parked on the grass.
Eugene Zimmerman
PostPosted: Mon May 08, 2006 4:56 am    Post subject: Re: Rotax Relapse Reply with quote
Here is the pict again.
 Filesize:  40.23 KB
 Viewed:  467 Time(s)
Page 3 of 4
