peteohms
Posted: Tue May 05, 2009 4:52 pm Post subject: 912ULS integrated alternator question |
Yup Noel, I'm a ham. I got the capacitor the size of a beer can from an old
power supply in my junk box. Bought the 50# power supply at a ham auction
for $0.50 and have stored it for 15 years just to use one part on my Kitfox.
Anyone need a 30# 8 Volt transformer?
Pete
Hell Paso TX moving to Austin
Kitfox III
912
Grove
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
Float Flyr
Posted: Tue May 05, 2009 5:40 pm Post subject: 912ULS integrated alternator question |
30# 8V... no but it would make a decent anchor
VO1 PL
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Tue May 05, 2009 11:18 pm Post subject: 912ULS integrated alternator question |
Pete Christensen wrote:
<apeterchristensen(at)sbcglobal.net>
an old power supply in my junk box. Bought the 50# power supply at a
ham auction for $0.50 and have stored it for 15 years just to use one
part on my Kitfox.
Pete
Kitfox III
912
Grove
Pete
don't electrolytics degrade if not used for a long time?
Graham
lucien
Posted: Wed May 06, 2009 2:42 pm Post subject: Re: 912ULS integrated alternator question |
| peteohms wrote: | Yup Noel, I'm a ham. I got the capacitor the size of a beer can from an old
Pete
Kitfox III
912
Grove
For what it's worth, since I started this thread :
- got new R/R in from lockwood yesterday, everything charges fine now with no problems.
- I'm also a ham
- I lived in Austin TX for 20 years too.
Thanks for all the help folks,
LS
_________________ LS
Titan II SS |
peteohms
Posted: Wed May 06, 2009 3:09 pm Post subject: 912ULS integrated alternator question |
Graham,
If it lost 1/2 of it's capacitance it would still have plenty. 57,000 mF
Pete
Leander, TX
Posted: Wed May 06, 2009 4:00 pm Post subject: 912ULS integrated alternator question |
Graham,
Pete
Pete
do they ever go open circuit or even short circuit? I'm not an expert in
these things, just try and remember
Graham
peteohms
Posted: Wed May 06, 2009 4:34 pm Post subject: 912ULS integrated alternator question |
Graham,
An old electrolytic can be refreshed by slowly applying voltage and current
over time. Start with a variable dc power supply at a couple volts. Watch
the amps and work up to full voltage rating. As I recall it takes 5 minutes
plus 1 minute for every month the cap has set. My Kitfox III did not have a
capacitor on it and the rectifier regulator lasted 400+ hours. I have not
actually fired up the new cap but will do the refresh before I do.
Pete
Leander, TX
Posted: Thu May 07, 2009 4:48 am Post subject: 912ULS integrated alternator question |
Graham,
current over time. Start with a variable dc power supply at a couple
volts. Watch the amps and work up to full voltage rating. As I recall
it takes 5 minutes plus 1 minute for every month the cap has set. My
Kitfox III did not have a capacitor on it and the rectifier regulator
lasted 400+ hours. I have not actually fired up the new cap but will
Pete
thanks for that Pete
Graham
dashwood
Joined: 24 Jan 2009 Posts: 73 Location: sw ontario canada
Posted: Mon Feb 07, 2011 5:56 pm Post subject: Re: 912ULS integrated alternator question |
Last time up i had a low voltage warning light show on the ems. low end threshold of 12v. it seemed to only appear when i keyed the radio mic and / or cycled the elec fuel pump on. took me a while to realize the correlation here. from this thread it would seem to be a blown regulator.. i have not had a chance to go in with a volt meter and check for voltage to the reg. the plane was up for almost 2 hrs in this condition. no warning light but for when using radio which is really the only draw other then the ems. seemed to be getting worse to the end of the flight so proly battery was getting down...Q= will engine continue to run with dead battery, assuming the generator fields are working? will engine run without generator but a full battery? i use a photo cell charger to keep battery topped up between flights so always had full charge to start. battery is 2 years old and only fair condition, on schedule to be replaced.
question... am i on the right track... what is the problem with the master/alternator switch off sequence... one first then the other and what happens if wrong one is switche first..?
_________________ Ross Alexander: CH701 driver 912ul 788tt
It only takes two things to fly, airspeed and money |
