lloydeggstaff(at)gmail.co Guest
Posted: Thu Feb 10, 2011 9:59 am Post subject: Auto oil filter for 912? |
I recall seeing listed an auto oil filter that can be used on the Rotax 912. Does anyone have that part number? [quote][b]
Tommy Walker
Joined: 12 Jan 2006 Posts: 442 Location: Anniston, AL 36207
Posted: Thu Feb 10, 2011 10:39 am Post subject: Re: Auto oil filter for 912? |
[quote="lloydeggstaff(at)gmail.co"]I recall seeing listed�an auto oil filter that can be used on the Rotax 912. Does anyone have that part number?
I am going to try attaching a word document to this reply. It was written by Roger Lee in AZ who is a Rotax Maintenance Rated Repairman. It tells what and what not to use for the 912.
Tommy
 Download |
| Filename: |
Oil Filters.doc |
34 KB |
| Downloaded: |
877 Time(s) |
_________________ Tommy Walker
N25A - Anniston, AL |
Posted: Thu Feb 10, 2011 11:06 am Post subject: Auto oil filter for 912? |
Was not able to download the word document.
On Thu, Feb 10, 2011 at 8:39 AM, Tommy Walker <twalker(at)cableone.net (twalker(at)cableone.net)> wrote:
[quote]--> Kitfox-List message posted by: "Tommy Walker" <twalker(at)cableone.net (twalker(at)cableone.net)>
Tommy
Tommy Walker
N8701 - Anniston, AL
http://forums.matronics.com/viewtopic.php?p=330481#330481
http://forums.matronics.com//==
Download, 7-Day Browse, Chat, FAQ,
ef="http://www.matronics.com/Navigator?Kitfox-List" target="_blank">htt======
Tommy Walker
Posted: Thu Feb 10, 2011 11:18 am Post subject: Re: Auto oil filter for 912? |
Lloyd, I just emailed the document to you at lloydeggstaff(at)gmail.com.
Let me know if you don't get it.
lcfitt(at)sbcglobal.net Guest
Posted: Thu Feb 10, 2011 12:40 pm Post subject: Auto oil filter for 912? |
Tommy,
Thanks for the info. It came through fine here. Maybe it needs an later
version MS Word.
Lowell
Sent: Thursday, February 10, 2011 10:39 AM
Subject: Re: Auto oil filter for 912?
Tommy Walker
Posted: Fri Feb 11, 2011 9:11 am Post subject: Re: Auto oil filter for 912? |
You're welcome!
| lcfitt(at)sbcglobal.net wrote: | Tommy,
version MS Word.
Lowell
To: <kitfox>
Tucsonchris
Joined: 26 Oct 2007 Posts: 12 Location: Tucson, Arizona
Posted: Fri Feb 18, 2011 6:49 am Post subject: Re: Auto oil filter for 912? |
FYI, the Purolator PureOne PL 10241 recommended is too tall to fit under the stock Kitfox exhaust, Bought one, tried it. I'd have to take the exhaust off each time and it doesn't look like that would be fun.
_________________ Chris G.
Tucson, Arizona
Marana Regional Airport
Kitfox SS
912s |
jerrytex
Posted: Fri Feb 18, 2011 2:11 pm Post subject: Re: Auto oil filter for 912? |
I ran into the same problem with the Purolator being to tall. I went with the Napa Gold.
Roger Lee
Posted: Fri Feb 18, 2011 6:07 pm Post subject: Re: Auto oil filter for 912? |
The Pure One as the Fram are slightly less 1/2" longer than a stock Rotax filter. There are a few instances where owners have a stock exhaust that is a little too close to fit the filter in over the threaded mount. Some with stock Rotax exhaust don't have this problem and some just have different exhaust. The only way to find out is buy one and try it. Sorry there is no other way. Don't put any oil in it and you can take it back if it is a tad too long.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
pchristensen10(at)austin. Guest
Posted: Sat Feb 19, 2011 8:02 am Post subject: Auto oil filter for 912? |
Carquest filter 85056 is exactly the same size as the NAPA 1056. It's
cheaper too.
Pete
On 2/18/2011 8:07 PM, Roger Lee wrote:
Roger Lee
Tucson, Az.
Light Sport Repairman - Maintenance Rated
Rotax Repair Center
Cell 520-349-7056
http://forums.matronics.com/viewtopic.php?p=331473#331473
PMorel
Joined: 09 Jul 2007 Posts: 62 Location: Locust Grove, GA USA
Posted: Tue Feb 22, 2011 6:59 am Post subject: Re: Auto oil filter for 912? |
I use NAPA 1215 Gold for my Rotax 912. I think they are about $7 each or somewhere around that price.
_________________ Paul Morel
912 Speedster
Locust Grove, GA
www.WingsAirPhotos.com |
Roger Lee
Posted: Tue Feb 22, 2011 5:20 pm Post subject: Re: Auto oil filter for 912? |
Many of the different filters are made by the same company as another, but just has a different label. You cut them open and they are identical.
Tucson, Az.
Cell 520-349-7056 |
marwynne(at)windstream.ne Guest
Posted: Tue Feb 22, 2011 6:37 pm Post subject: Auto oil filter for 912? |
Isn't there an internal pressure relief valve. Are they all set at the
same back pressure ?
I am no expert. Just interested in the discussion.
On 2/22/2011 7:20 PM, Roger Lee wrote:
Roger Lee
Tucson, Az.
Rotax Repair Center
Cell 520-349-7056
http://forums.matronics.com/viewtopic.php?p=331881#331881
Checked by AVG - www.avg.com
Roger Lee
Posted: Sat Feb 26, 2011 6:09 pm Post subject: Re: Auto oil filter for 912? |
The answer to your question is in the document posted by Tommy above.
Tucson, Az.
Cell 520-349-7056 |
