Kolb/Jabiru carb overflow
Goto page Previous  1, 2, 3, 4
Frankd
PostPosted: Tue Feb 15, 2011 4:12 pm    Post subject: Re: Kolb/Jabiru carb overflow Reply with quote
Hi Chris,
Glad its back working again. Good to hear your back in the air
Fly safe.
FrankD
rickofudall
PostPosted: Tue Feb 15, 2011 4:25 pm    Post subject: Kolb/Jabiru carb overflow Reply with quote
Chris, all, One trick to keep the oil vent line from freezing shut is to cut a slit in the line about 1/3rd of the line diameter near where the line attaches to the engine. In normal usage the slit won't leak as the structure of the line keeps it closed. Should condensation freeze the line shut the slit is near enough to the warmth of the engine there will be no ice there and the excess pressure will be vented. Picked this one up from the LongEZ drivers.
Rick Girard
On Tue, Feb 15, 2011 at 4:57 PM, ces308 <ces308(at)ldaco.com (ces308(at)ldaco.com)> wrote:
--> Kolb-List message posted by: "ces308" <ces308(at)ldaco.com (ces308(at)ldaco.com)>
Hello all....
    Well,I got the head back on yesterday and flew it todayfor .5 hrs  and it ran perfect ! Ellery's catch can worked perfect    and my fuel pressure stays between 1.4 to 1.7 and absolutely no problems running what so ever!
Thank you Thom for making me look closer and the crankcase vent system  as that was my problem from the start. I believe condensation in the line froze blocking the venting and raising the pressure in the engine causing the fuel pump to go wild!. It was 16* today when I flew it and all was good ! Now to build trust in her again...lol
chris ambrose
M3X/Jabiru A-2200    175.0 hrs
N327CS
http://forums.matronics.com/viewtopic.php?p=331167#331167
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
It isn't necessary to have relatives in Kansas City in order to be unhappy.
  - Groucho Marx
Thom Riddle
PostPosted: Tue Feb 15, 2011 6:28 pm    Post subject: Re: Kolb/Jabiru carb overflow Reply with quote
Chris,
I am happy to have helped and more importantly, that you found and fixed the problem.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
Page 4 of 4
