Voltage Regulator Problem
frank3
PostPosted: Sat Feb 19, 2011 5:57 pm    Post subject: Voltage Regulator Problem Reply with quote
I have a 912ULS with the Ducati regulator wired into the Z16 diagram that I have been flying for three years. Today on run-up I noted low voltage (<11 volts) in the Grand Rapid EIS & the Dynon EFIS displays, regardless of RPM. Normally I get 13.1 volts indicated with load.
With Master off & engine not running the yellow dynamo wires feeding the regulator show continuity with no resistance. I am thinking there should be some resistance--am I correct or is the reading OK? At fast idle (2400 RPM) the yellow wires indicate 18 volts AC and correspondingly increases with increasing RPM. The regulator output B+ terminal reads 8.5 volts DC--I believe I should expect 14 v DC. The system voltmeter reads ~11 volts with minimal load. Battery was 12.5 v. I traded out the regulator with one that I was told was good. Very similar results (8.3 volts output). I assume both regulators are faulty??? Any suggestions to further trouble shoot?
If I replace the regulator I'm considering the Key West. Question about integrating into the Z16 wiring scheme. I assume the + & - input terminals are connected to the yellow wires from the dynamo. Not sure how to hook-up the + & - output terminals. Can anyone help me with that?
Thanks much
frank3
PostPosted: Sun Feb 20, 2011 6:34 am    Post subject: Re: Voltage Regulator Problem Reply with quote
Let me try sending again--only part of note came through on first try.
I have a 912ULS with the Ducati regulator wired into the Z16 diagram that I have been flying for three years. Today on run-up I noted low voltage (under 11 volts) in the Grand Rapid EIS & the Dynon EFIS displays, regardless of RPM. Normally I get 13.1 volts indicated with load.
With Master off & engine not running the yellow dynamo wires feeding the regulator show continuity with no resistance. I am thinking there should be some resistance--am I correct or is the reading OK? At fast idle (2400 RPM) the yellow wires indicate 18 volts AC and correspondingly increases with increasing RPM. The regulator output B+ terminal reads 8.5 volts DC--I believe I should expect 14 v DC. The system voltmeter reads about 11 volts with minimal load. Battery was 12.5 v. I traded out the regulator with one that I was told was good. Very similar results (8.3 volts output). I assume both regulators are faulty??? Any suggestions to further trouble shoot?
Thanks much
PostPosted: Sun Feb 20, 2011 9:56 am    Post subject: Voltage Regulator Problem Reply with quote
At 09:34 AM 2/20/2011, you wrote:
--> AeroElectric-List message posted by: "frank3" <frank3phyl(at)comcast.net>
Alternator/regulator is NOT producing power.
This is a very low resistance . . . less than 1 ohm
that you cannot measure without special attention
to test equipment - like the low ohms adapter on
my website.
If your plain vanilla volt-ohmeter shows continuity,
the windings are probably fine. Are they discolored,
i.e. insulation very dark and/or cracked?
That's good . . .
Is your control relay closing? Try bypassing the
OV/control system and connect your R/R output
wire directly to the system (unplug fat wires
from relay and connect them together). Then
do your voltage checks.
Do you have the Key West installation instructions?
If it is this device:
[img]cid:7.1.0.9.0.20110220113902.01fbed20(at)aeroelectric.com.0[/img]
The terminal markings are pretty definitive. AC input is from
your alternator winding, NEG(-) goes to ground, POS(+) would
go to the control relay.
But check your control relay closure first. It seems unlikely that
you would suffer TWO Rectifier/Regulator failures.
 Filesize:  281.54 KB
 Viewed:  11396 Time(s)
frank3
PostPosted: Sun Feb 20, 2011 1:44 pm    Post subject: Re: Voltage Regulator Problem Reply with quote
Thanks for your input.
As you suggested I removed the relay "C" input and jumped it across to the "A" lead. The reading from the regulator B+ lead was initially about 11 volts with the engine running but steadily decreased to yesterday's reading of about 8.4 volts. Reading was not influenced by increase in RPM.
I reconnected to the relay "C" terminal and took a reading from the "C" terminal to the starter relay to check the circuit through the relay & across the fuse link and got a reading of 8.3 volts with the master on ALT. Battery still above 12 v.
Any other suggestions?
PostPosted: Sun Feb 20, 2011 10:25 pm    Post subject: Voltage Regulator Problem Reply with quote
At 04:44 PM 2/20/2011, you wrote:
It's not clear that you understood my suggestion.
I intended that you bypass the control relay
entirely. If you're using Z-16 of more than 3
years ago, then the relay is probably in the DC
output wire from the rectifier-regulator. The
current version uses the control relay to switch
AC power out of the alternator.
Unplug both the heavy gage wires from the control
relay and connect them together thus eliminating
the relay as a means by which the alternator can
be disconnected from the system.
Then see how things perform. The point of this
experiment is to eliminate the relay and its
control wiring as potential cause for your
observed malfunction.
While the relay is bypassed and you're making
other voltage measurements, see what voltage you
read on the relay's skinny wires too with the
battery/alternator control switch full up. One
should be seeing battery voltage, the other
should be zero volts.
frank3
PostPosted: Mon Feb 21, 2011 8:51 am    Post subject: Re: Voltage Regulator Problem Reply with quote
Thanks for clarifying.
With relay circumvented (fat wires disconnected from relay but joined together), B+ = 11.6v steady; EIS steady 10.8v. No change to either reading with RPM increase.
Re the "little wires", neither had voltage with master on ALT.
Reconnected relay and retested, B+ = 1.9v at start and slowly increased to 4v after 10 min engine run. Same reading immediately after engine off. EIS showed 10.8v. No change to either reading with RPM increase.
Further suggestions/assessment?
PostPosted: Mon Feb 21, 2011 9:13 am    Post subject: Voltage Regulator Problem Reply with quote
At 11:51 AM 2/21/2011, you wrote:
Okay, this says the rectifier/regulator is bad
????? Double failure ???? If there's no power
coming from the alternator switch, then you're
certainly not going to get the alternator on
line.
Trace the power flow from the bus through the
ALT switch to the relay.
frank3
PostPosted: Mon Feb 21, 2011 12:53 pm    Post subject: Re: Voltage Regulator Problem Reply with quote
It is with a very bright red face I offer an apology for the time you've contributed to my issue. After sending the last note I did as your note suggested--trace the power from the master switch. After taking the panel out and checking for connections & current flow I ended up at the circuit breaker. Guess what? Yes, it had tripped. After resetting the breaker one of the relay "little wires" showed battery current as you indicated and the regulator B+ showed 14v. So sorry for not checking the breaker first! Now I'll have to be on the lookout for whatever caused the breaker to trip the first time. For me it's been very educational and I thank you.
PostPosted: Mon Feb 21, 2011 2:54 pm    Post subject: Voltage Regulator Problem Reply with quote
At 03:53 PM 2/21/2011, you wrote:
Hmmm . . . something to add to your future
LO VOLTS checklist. Do you have a low volts
warning light? Do you have any notion of when
the alternator was lost and what was happening
at the time?
The legacy ovm designs are 99.9% resistant to transient
events on the system . . . but the reason we
recommend a breaker as opposed to a fuse is that
you can reset it ONE TIME after an OV trip just
to make sure it's a real OV condition and not a
nuisance trip.
Your welcome. Nobody ever promised us that
education was 'cheap' . . . I've had some
expensive epiphanies over the years. Fortunately
none resulted in badly bent airplanes or bodily harm
that wouldn't heal. Lessons hard won at the
expense of $time$ and frustration are those
which are best retained.
The biggest upside of this exchange is that your
particular set of conditions COULD have been
root cause for your own (or somebody else's)
"dark-n-stormy-night" story. By discussing it
here in embarrassing detail means that interested
readers can harvest benefits that few stories in
the flying rags can offer.
Thank you for sharing . . .
