darinh
Posted: Fri May 19, 2006 9:57 pm Post subject: Series 7 Stick Forces? |
I just connected up my elevator and the stick forces are quite alarming (heavy)! It is smooth but takes quite a bit of arm muscle to move it. Is this normal? My control column is smooth and does not bind on the bearing or the delrin brace so it must simply be the weight of the elevator. I am used to the model III that was fairly light on the control. What is the stick pull like while flying? Anyone with a flying Series 7...does the amount of force required to pull back stick change significantly from static (on the ground) to flying? I wonder why Skystar never designed counterbalances for this airplane...Maybe because the stick forces are just right in the flight regime...I don't know, this is why I am asking. Any comments or thoughts are appreciated.
Darin
janderson412(at)hotmail.c Guest
Posted: Fri May 19, 2006 11:34 pm Post subject: Series 7 Stick Forces? |
Yes, mine seemed stiff too but to fly it's ok, don'y notice it being so.
John A Series 5
Subject: Series 7 Stick Forces?
Date: Fri, 19 May 2006 22:57:28 -0700
Darin
http://forums.matronics.com/viewtopic.php?p=35532#35532
Check out the latest video (at) http://xtra.co.nz/streaming
rdmac(at)swbell.net Guest
Posted: Sat May 20, 2006 5:10 am Post subject: Series 7 Stick Forces? |
My model 7 is the same way. The weight of the elevator is what you are
having to over come but in the air that goes away. The elevator will start
to 'come alive' as soon as the power comes up, and then be ready to fly.
Roger Mac
darinh
Posted: Sat May 20, 2006 4:57 pm Post subject: Re: Series 7 Stick Forces? |
Thanks guys, I guess I won't worry about it.
Darin
smokey_bear_40220(at)yaho Guest
Posted: Sun May 21, 2006 12:12 pm Post subject: Series 7 Stick Forces? |
Hi Darin and all,
As the others have said, you probably have no elevator
problem. It is just the normal weight. But just to
check, here is something I learned from SkyStar while
building my S-5:
You should be able to raise the elevator to any point,
say to a level position, then let the stick go and the
elevator should drop all the way to the down stop. It
doesnt have to bang down, just get there on its own.
If it stops before that, you have too much friction.
If you have a friction problem, disconnect the
controls and find it. Most likely the elevator hinges
will cause this.
On the other extreme, you should have no slack either.
No movement of the stick without elevator movement
and there should be some slight friction to prevent
flutter.
As long as the controls are tight, but the elevator
drops on its own weight to the stop, you are good.
If all that is OK, the weight of the elevator itself
is no problem in flight and the Fox 7 should feel very
nice to you. It will trim right up to hands free.
After flying a Cub, a Champ and a Citabria for
warmups, I found my S-5 flys embarrasingly well. Kind
of like a fighter version of a Cessna 180 with a
stick. It felt heavy and stable, yet a flick of the
wrist and it would go where I wanted it maybe twice as
fast as the Cessna could. I was afraid to say this at
first for fear of losing friends with store-bought
planes. Now I find they look OK green.
Kurt S.
--- darinh <gerns25(at)netscape.net> wrote:
| Quote: | I just connected up my elevator and the stick forces
appreciated.
Darin
darinh
Posted: Sun May 21, 2006 6:18 pm Post subject: Re: Series 7 Stick Forces? |
Kurt,
Thanks for the info. My elevator reacts exactly as you have specified...no slop and the elevator falls nicely to the bottom of the movement on its own. Thanks again,
Darin
ruebd(at)skymail.csus.edu Guest
Posted: Tue May 30, 2006 7:19 am Post subject: Series 7 Stick Forces? |
Darin and 5 plus pilots
I have a series 5 with a Continental IO-240B4B doing the towing.
Both myself and my instructor find the stick force required to approach
at 65mph indicated and to flare to be quite high, and a true 3 point is
almost not possible, even with the stick in your stomach and the trim at
the up limit. The more flap used, the worse this becomes.
My instructor has suggested that a stick extension be added to
reduce the force and overall sensitivity (he is also an accomplished
machinist). I haven't wanted to do this as a modification to the sticks
I now have, but we may try this with a stick that is made from scratch,
and can fold so that entry and exit will still be possible. At cruise,
the elevator force/response function is fine, and is very sensitive to
minor changes in trim.
We have also discussed gap sealing the elevator, as that gap is
quite large, and some benefit to elevator authority should result from
this, which is confirmed by some of the recent posts on the topic.
The rudder gap is very small on mine, and quite clean as is, so I do not
see any reason to seal that one, which is very effective under all
reasonable speeds.
reasonable speeds.
reasonable speeds.
My opinion is that some aerodynamic counter force should have
been designed into the horizontal surfaces of these models, which were
otherwise well evolved to accept the heavier engines, and made more
aerodynamic by using the shaped ribs.
I will soon install the "help me Joe" kit that McBean has
developed for the 5 thru 7 series to help with the elevator force when
flaps are used, and I will do gap sealing, and then report the results.
I am also planning to change the tail wheel to an 8" pneumatic, which is
1 lb heavier than what I have now. 1 lb is not a lot, but it is as far
back as can be, so it should help a little.
Duane Rueb
jopatco(at)mindspring.com Guest
Posted: Tue May 30, 2006 8:33 am Post subject: Series 7 Stick Forces? |
Sound like your plane is nose heavy.
wingsdown(at)comcast.net Guest
Posted: Tue May 30, 2006 8:52 am Post subject: Series 7 Stick Forces? |
Did you sweep the wings forward for the heavier engine? If the stick is
all the way back the assist really wont be the answer. You need a bigger
elevator. I would also think , just guessing that even an elevator as a
maximum AOA to which point it ceases to be effective, not sure. I would
still try a quick gap seal, little to loose. My turbo NSI was heavy but
always light on the stick. If I had ever put the stick in my belly I
would have done at loop. Where is the battery?
Rick
Posted: Tue May 30, 2006 9:10 am Post subject: Series 7 Stick Forces? |
Hi Duane,
You must be operating right at the forward CG limit.
Where is your battery and ELT?
Adding the extra 1 lb to the tail will help. More
would be better. Just 5 lbs back there makes a big
difference. Also the gap seals and maybe vortex
generators under the horizontal stab would do good
too.
If you move the CG a little more aft you will find
that your stick will be fine as is.
The electric trim has always been a bit overpowering
and there is a "fix" somewhere in this list's history.
I trim and immediately beep once for opposite trim to
make small changes. After a few such reversals I can
get mine to hold right on altitude, but a 1/2 rate or
manual trim would be better. Is yours manual?
The more off the center of your CG, the more touchy
the trim is.
I am near the fwd CG limit too. For my testing, I
added 7 gallons of water to the baggage compartment to
achieve center CG flight. It flys there as
advertised. I kept to the fwd limit so I could carry
max pax and cargo and stay in limits. With just me on
board, I can trim to 60 knots and 3 point up to 1/2
flaps. Full flaps takes some work but I can get a
stall there too.
Kurt S. S-5/NSI turbo
--- "Rueb, Duane" <ruebd(at)skymail.csus.edu> wrote:
| Quote: | Darin and 5 plus pilots
doing the towing.
becomes.
Posted: Tue May 30, 2006 9:53 am Post subject: Series 7 Stick Forces? |
Kurt:
My battery is in the back. The ELT is behind the baggage
compartment. Like you, I want to be able to put something in the
baggage compartment and have it be OK, not tail heavy. Thanks for the
tip on the vortex generators on the lower stab. I hadn't thought of
that one, and could probably live with them there. I admit that I am
really just getting to be a tail dragger pilot, but when my instructor
does a demonstration landing he has almost as much trouble as me, and
the last few sessions, I was making better ones than he was, but now I
have made more in this plane than he has too. Of course, what we are
striving for is a true three point. Yes, like you, I like it best with
1/2 flaps so far. I have become skilled at pulsing the trim, as it
sounds like you have.
Duane
Robert_Harris(at)intuit.c Guest
Posted: Tue May 30, 2006 11:06 am Post subject: Series 7 Stick Forces? |
Duane,
You can use Duct tape on your tail feathers for an easy fast fix. My
plane is white so I used White Duct and it looks great and makes my
920lb 0200 Model V do perfect three point landings with 50% flaps. Also
I have John McBean's Elevator Assist installed so the stick pressure is
very light.
Robert
Model V KF
San Diego
Posted: Tue May 30, 2006 11:10 am Post subject: Series 7 Stick Forces? |
If it isn't too hard, try mounting the ELT back by the
battery, but where you can get at it. Mine is
actually behind the battery under the stab with the
antenna in front of the verticle stab.
Those little weight changes can help. Do your W&B
math and see how the weight shift helps to see if it
is worth while. I am not a lead and dead weight
advocate. Even more battery is better than dead
weight.
I can get 135# back there with a gross wt load.
Probably make the 150 limit, if I don't put too much
in the seats. Then again, what would I be carrying
that is 135 pounds and that small? Third pax in an
emergency? Moose meat?
Kurt S.
| Quote: | Kurt:
baggage compartment.
