rickofudall
Posted: Mon Jan 23, 2012 2:11 pm Post subject: pusher belt drive prop |
Short answer, Yes if both engines are Rotax 2 strokes. If the donor engine is non Rotax check the rotation of the donor engine.
Rick Girard
On Mon, Jan 23, 2012 at 11:14 AM, Malcolm Brubaker <brubakermal(at)yahoo.com (brubakermal(at)yahoo.com)> wrote:
| Quote: | Is a prop for a pusher belt drive the same as a prop 4 a tractor W/a gear box ?
my budy needa a prop for a 503 belt drive 60in to put on his quicksilver float plane
Malcolm & Jeanne Brubaker Michigan Sport Pilot Repair LSRM-A, PPC, WS Great Sails - Sailmaker for Ultralight & Light Sport [url=tel:%28989%29513-3022](989)513-3022[/url]
From: George Alexander <gtalexander(at)att.net (gtalexander(at)att.net)>
Sent: Monday, January 23, 2012 8:38 AM
Subject: Re: Key West Regulator
--> Kolb-List message posted by: "George Alexander" <gtalexander(at)att.net (gtalexander(at)att.net)>
Ed:
I’m not an expert, but I believe that it should be to the airframe. Every drawing that I have seen shows a common ground (airframe?) throughout the installation.
A couple of “However”s though….
Many installations put a separate grounding strap from the engine to the airframe (a braided strap) and then ground, at a convienant place, the devices fed by the system.
If the loads off the KW are not too demanding and depending on how they are wired, the brown to the Neg (-) on the KW would be “ok”, not ideal, but “ok”.
As Beauford would say.... "Worth what you paid for it!" (Who by the way, uses a KW and an EIS.)
DAquaNut(at)aol.com wrote:
| Quote: | George, � I was the one who wired my firefly originally and have 170 hours on it. Do I need to run
� the brown wire from the engine to the airframe? That is the only one in question. It seems
> � Crazy at this point, but I may not have had it right ,all along.
| Quote: | >
> Ed:
> The brown should go to ground. The yellow and the yellow/black should go to the input (A/C) to the Key West. The output (DC) of the Key West would tie into whatever you have that requires the 12V DC. The brown (ground) going to the negative side of the output of the KW may have been someone's way of getting the engine ground to whatever is being fed by the KW.
| Quote: | > For further confusion go to Google and put in "Rotax Wiring Diagram". It'll make your hair hurt.
> Your results may vary.
George Alexander
FS II R503 N709FS
http://www.oh2fly.net
http://forums.matronics.com/viewtopic.php?p=364558#364558http://www.matronics.com/Navigator?Kolb-List
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
It isn't necessary to have relatives in Kansas City in order to be unhappy.
- Groucho Marx
